11-26-2020, 12:31 | #1 (permalink) |
Insane Poster Join Date: Oct 2011 Location: colombo Age: 37
Member: 1679180 Status: Offline Sonork: 100.1679235 Thanks Meter: 2 | why this error Setting bus width to 8 Bit Setting frequence to 42 Mhz EMMC Device Information : EMMC CID: 90014A48384734749201023920A763C3 EMMC CSD: D02701320F5903FFFFFFFFE78A40002B EMMC Manufacture Name: SKHYNIX , EMMC NAME: H8G4t , EMMC NAME (HEX): 483847347400 , S/N: 023920A7 , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 6/2016 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H8G4t_023920A7_20201126_155858.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Error writing at address: 0001D1FFBE00 , error: -4 , DATA RCV CRC Error ... Retry #1 Error writing at address: 0001D1FFBE00 , error: -4 , DATA RCV CRC Error ... Retry #2 Writing PIT at address: 000000004400 GPT-partitioning done Unpacking file: sboot.bin Unpacking file: param.bin Unpacking file: boot.img Unpacking file: recovery.img Unpacking file: modem.bin Unpacking file: system.img Unpacking file: cache.img Unpacking file: hidden.img Partition name: BOOTLOADER Filename: sboot.bin , Offset: 000000000000 , filesize: 1411344 bytes eMMC switching to ROM2 Erasing partition... Writing partition... Error writing at address: 000000000000 , error: -4, DATA RCV CRC Error ... Retry #1 Error writing at address: 000000000000 , error: -4, DATA RCV CRC Error ... Retry #2 Error writing at address: 000000000000 , error: -4, DATA RCV CRC Error ... Retry #3 Too many errors. Writing has been stopped |
11-27-2020, 17:44 | #3 (permalink) | |
Junior Member Join Date: Apr 2011 Location: I.R. Hamedan
Member: 1558581 Status: Offline Sonork: 100.1617318 Thanks Meter: 1 | Quote:
EMMC is definitely broken Even if the DUMP write steps are done on EMMC After installing and turning on the phone, The device encounters a regiment | |
The Following User Says Thank You to IRAN GSM For This Useful Post: |
