04-11-2020, 13:41 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: GOOD
Member: 388862 Status: Offline Thanks Meter: 107 | x27_pd1838 not work???help me!!!!!!!!!! Box API Version: 3308 FS Driver Version: 11062019 SQLite Version: 3.30.1 FSCK Engine Version: 11062019 ESE DB Version: 11062019 System Util Version: 11062019 System: Windows NT 6.1 (Build 7601, Service Pack 1) / 64 BIT CPU: Intel(R) Pentium(R) CPU G620 @ 2.60GHz !!FOR BETA-TESTERS ONLY!! Z3X Card Serial: AACC2836 EasyJtag Plus Box Found at: COM33 EasyJtag Plus Box Firmware: 2.50 Source: Qualcomm 9008 EMMC/UFS/Manual Generation: GPT [QC/SAMS/BCM/INTEL/MTK] Box Voltage set to: 2800 mV Scanner Thread Created.. Config: 101111111110111 Setup HiPower CLK: OFF Connecting To EasyJtag Plus Box: 2800mV/21MHz/8BIT EasyJtag Plus Box Found! Result: 0/OK EasyJtag Plus S/N: 5B0DF49404C29B41 EasyJtag Plus Box FirmWare: 2.50 Box Bus Width = 8 BIT Box Hardware = EasyJtag 2nd Generation Use Qlm 9008 (EDL) Mode.. Please Connect Qlm Device in 9008 (EDL) Mode.. Selected Primary Memory Type: AUTO Waiting For Device.. Found Device: Path: \\?\usb#vid_05c6&pid_9008#6&2c24ce2e&0&5#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Desc: Qualcomm HS-USB QDLoader 9008 HWID: USB\VID_05C6&PID_9008&REV_0000 Name: Qualcomm HS-USB QDLoader 9008 (COM10) Vendor: Qualcomm Incorporated Trying Connect to Device.. Open Port OK Sahara OK, Get Data.. Read Qualcomm CPU Info OK S/N: 0x53AE66A4 HW ID: 0x000950E100730003 HASH: 0xA7DF3FXeGAdvWCNVmG7ABSRycQFmdDeEE6BHPD08CFD7169B EDB84424C862B SBL : 0x00000000 DEV HASH: 0x0000008785D6 CPU : SnapDragon 675 [SM6150] Using Qlm Loader: prog_firehose_ddr.elf Sending Loader.. Loader Size: 664244 bytes Loader CheckSum: 0x9EE8C2B2 Loader Info: HASH: 0x2C0A52FFBD8DB687B56F6A98D8840F46597A4DDE6D9DC8D0 0039873CE6D74F60 CERT Cnt: 6 Wait.. Loader Sent, Run FireHose.. Get Memory Type.. [AUTO] Detected Memory: UFS FireHose Config Info: MSM, Memory: UFS, Ver: 1 Ext Info: 0x00002000/0x00100000/0xFFFFFFFF/0x00001000 FireHose Configure OK Get Protocol Type.. log value=INFO: Calling handler for read log value=ERROR: The operation is not allowed for read... response value=NAK rawmode=false Init Device Fail. Break.. Scanner Thread Terminated Elapsed: 00:00:06:061 Found 0 Partition(s).. Search Partitions Fail.. Check Qlm Device and Try Again.. |
04-11-2020, 13:46 | #2 (permalink) |
Member: 388862 Status: Offline Thanks Meter: 107 | EasyJtag Suite Classic ver.: 3.6.2.4 / wxWidgets 3.1.3-W-U started. OS ver.: Windows 7 (build 7601, Service Pack 1), 64-bit edition. Admin rights OK Autorun Agent ver:1.0.0.0 Crash Reporting ver:1.4.0.3 EasyJTAG SPI Plugin ver:1.1.1.12 Android ADB API ver:2.0.0.0 FTDI API ver:3.2.4.0 LibUSB API ver:1.2.6.0 Visual C++ Runtime ver:10.0.30319.1 Setting box Pinout ... Box Drivers version: 3.0.0.0 Z3X Card Serial : XXXXXX , ver: 22 Z3X Card Activation [JTAGPLUS] : ACTIVATED Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : NOT ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED Found 2 serial devices COM1 ACPI\PNP0501 通信端口 (C COM33 USB\VID_1781&PID_AAAC&REV_0100&MI_00 Easy Jtag Plus Control Port (COM33) Selected pinout: GEN2 ISP Pinout Change EasyJTAG Pinout OK Found 3 devices COM1 ACPI\PNP0501 通信端口 (C COM10 USB\VID_05C6&PID_9008&REV_0000 Qualcomm HS-USB QDLoader 9008 (COM10) COM33 USB\VID_1781&PID_AAAC&REV_0100&MI_00 Easy Jtag Plus Control Port (COM33) QC Core Version 2.10 Using Port :COM10 Detecting Device mode... Using EDL Programmer :\Z3X\EmmcManager-1.18-04-04-2020\x27_pd1838\prog_firehose_ddr.elf Sahara Connectting To Device Sahara Downloading flash programmer: D:\Z3X\EmmcManager-1.18-04-04-2020\x27_pd1838\prog_firehose_ddr.elf Waiting for flash programmer to boot Detecting Device mode... Device Class: sahara Device Protocol: firehose Emergency Mode: true Reading QC Device information... Firehose protocol already booted Selected Qualcomm Interface Failed to load partition Operation status: 0 Success QC Core Version 2.10 Using Port :COM10 Detecting Device mode... Connecting to device without external programmers... Device Class: sahara Device Protocol: firehose Emergency Mode: true Error call virtual function open_wrapper Warning! Can't open source to read GPT Partition info not found Operation status: -4 COM port read error... |
