08-04-2020, 01:30 | #1 (permalink) |
Insane Poster Join Date: Oct 2017
Member: 2772222 Status: Offline Thanks Meter: 9 | XT1672/Cedric Stuck in Fastboot after change eMMC Objective: Change eMMC cause Health report is very BAD. Historic: Device was in EDL/QDLoader 9008 . Boot repair Done using Easy Jtag. Now: Device is working properly, but I want change eMMC for a new one. Same Model as older: KMQX10013M-B419. I did Dump from ROM1 , ROM2-3 (is blank). I know about CID partition and it is safe. But after write eMMC device stuck in fastboot mode. Dont accept any command to flash. I already checked CID partition from the dump and from the new eMMC and are the same file. (Use HxD software to campare). Questions: 1)Is not possible change this eMMC? 2)is there a memory parity with the processor? (RPMB area) Log New eMMC: Code: Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 24 MHz CMD Pullup Level: 2131 mV CMD Active Level: 2332 mV EMMC Device Information : EMMC CID: 150100515831334D42072242023C7477 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QX13MB , HEX: 515831334D42 , S/N: 2242023C , rev. 0x07 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 7/2017 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 8276 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX13MB_2242023C_20200803_205245.extcsd EMMC Init completed. Scanning soft partitions Partition table not found Get firmware version Firmware info not found Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 24 MHz CMD Pullup Level: 2126 mV CMD Active Level: 2333 mV EMMC Device Information : EMMC CID: 150100515831334D42072242023C7477 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QX13MB , HEX: 515831334D42 , S/N: 2242023C , rev. 0x07 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 7/2017 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 8276 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX13MB_2242023C_20200803_205547.extcsd EMMC Init completed. Operation: Writing all eMMC Regions... Operation: Writing BootConfig ... Reg: 179 Value: 0x38 Reg: 177 Value: 0x00 Reg: 162 Value: 0x01 Done Writing to: ROM2 , start: 0x000000000000 , size: 0x000000400000 Filename: EMMC_QX13MB_ROM2_000000000000_000000400000 OS567.bin eMMC switching to ROM2 Writing partition... Done writing partition. Write speed: 685.90 KB/s Writing to: ROM3 , start: 0x000000000000 , size: 0x000000400000 Filename: EMMC_QX13MB_ROM3_000000000000_000000400000 OS567.bin eMMC switching to ROM3 Writing partition... Done writing partition. Write speed: 687.12 KB/s Writing to: ROM1 , start: 0x000000000000 , size: 0x000020000000 Filename: EMMC_QX13MB_ROM1_000000000000_000020000000 OS567.bin eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 2547.50 KB/s All done time: [00:03:40:862] Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 24 MHz CMD Pullup Level: 2120 mV CMD Active Level: 2277 mV EMMC Device Information : EMMC CID: 150100515831334D42072242023C7477 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QX13MB , HEX: 515831334D42 , S/N: 2242023C , rev. 0x07 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 7/2017 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 8276 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX13MB_2242023C_20200803_210149.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: sbl1, [000000020000 - 0000000A0000], size: 000000080000 (512. KB) Partition: rpm, [0000000A0000 - 0000000E0000], size: 000000040000 (256. KB) Partition: tz, [000000120000 - 0000002E0000], size: 0000001C0000 (1.75 MB) Partition: devcfg, [000000320000 - 000000340000], size: 000000020000 (128. KB) Partition: aboot, [000000360000 - 0000004E0000], size: 000000180000 (1.50 MB) Partition: cmnlib, [0000004E0000 - 000000520000], size: 000000040000 (256. KB) Partition: cmnlib64, [000000520000 - 000000560000], size: 000000040000 (256. KB) Partition: keymaster, [000000560000 - 0000005A0000], size: 000000040000 (256. KB) Partition: prov, [0000005A0000 - 0000005D0000], size: 000000030000 (192. KB) Partition: sbl1bak, [0000005E0000 - 000000660000], size: 000000080000 (512. KB) Partition: rpmbak, [000000660000 - 0000006A0000], size: 000000040000 (256. KB) Partition: tzbak, [0000006E0000 - 0000008A0000], size: 0000001C0000 (1.75 MB) Partition: devcfgbak, [0000008E0000 - 000000900000], size: 000000020000 (128. KB) Partition: abootbak, [000000920000 - 000000AA0000], size: 000000180000 (1.50 MB) Partition: cmnlibbak, [000000AA0000 - 000000AE0000], size: 000000040000 (256. KB) Partition: cmnlib64bak, [000000AE0000 - 000000B20000], size: 000000040000 (256. KB) Partition: keymasterbak, [000000B20000 - 000000B60000], size: 000000040000 (256. KB) Partition: provbak, [000000B60000 - 000000B90000], size: 000000030000 (192. KB) Partition: modem, [000000BA0000 - 000006FA0000], size: 000006400000 (100. MB) Partition: fsc, [000006FA0000 - 000006FA0400], size: 000000000400 (1.00 KB) Partition: ssd, [000006FA0400 - 000006FA2400], size: 000000002000 (8.00 KB) Partition: dsp, [000006FA2400 - 000007FA2400], size: 000001000000 (16.0 MB) Partition: DDR, [000007FC0000 - 000007FC8000], size: 000000008000 (32.0 KB) Partition: sec, [000007FC8000 - 000007FCC000], size: 000000004000 (16.0 KB) Partition: utags, [000007FE0000 - 000008060000], size: 000000080000 (512. KB) Partition: utagsBackup, [000008060000 - 0000080E0000], size: 000000080000 (512. KB) Partition: modemst1, [0000080E0000 - 0000082E0000], size: 000000200000 (2.00 MB) Partition: modemst2, [0000082E0000 - 0000084E0000], size: 000000200000 (2.00 MB) Partition: fsg, [0000084E0000 - 000008CE0000], size: 000000800000 (8.00 MB) Partition: persist, [000008CE0000 - 00000ACE0000], size: 000002000000 (32.0 MB) Partition: frp, [00000ACE0000 - 00000AD60000], size: 000000080000 (512. KB) Partition: cid, [00000AD60000 - 00000AD80000], size: 000000020000 (128. KB) Partition: logo, [00000AD80000 - 00000BD80000], size: 000001000000 (16.0 MB) Partition: carrier, [00000BD80000 - 00000CD80000], size: 000001000000 (16.0 MB) Partition: metadata, [00000CD80000 - 00000CE00000], size: 000000080000 (512. KB) Partition: kpan, [00000CE00000 - 00000D600000], size: 000000800000 (8.00 MB) Partition: boot, [00000D600000 - 00000E600000], size: 000001000000 (16.0 MB) Partition: recovery, [00000E600000 - 00000F619000], size: 000001019000 (16.1 MB) Partition: misc, [00000F620000 - 00000F720000], size: 000000100000 (1.00 MB) Partition: limits, [00000F720000 - 00000F728000], size: 000000008000 (32.0 KB) Partition: mota, [00000F740000 - 00000F7C0000], size: 000000080000 (512. KB) Partition: dip, [00000F7C0000 - 00000F8C0000], size: 000000100000 (1.00 MB) Partition: syscfg, [00000F8C0000 - 00000F940000], size: 000000080000 (512. KB) Partition: logs, [00000F940000 - 00000FB40000], size: 000000200000 (2.00 MB) Partition: apdp, [00000FB40000 - 00000FB80000], size: 000000040000 (256. KB) Partition: msadp, [00000FB80000 - 00000FBC0000], size: 000000040000 (256. KB) Partition: dpo, [00000FBC0000 - 00000FBC2000], size: 000000002000 (8.00 KB) Partition: padA, [00000FBE0000 - 000010000000], size: 000000420000 (4.13 MB) Partition: sp, [000010000000 - 000010800000], size: 000000800000 (8.00 MB) Partition: hw, [000010800000 - 000011000000], size: 000000800000 (8.00 MB) Partition: oem, [000011000000 - 00003A000000], size: 000029000000 (656. MB) Partition: cache, [00003A000000 - 00004A000000], size: 000010000000 (256. MB) Partition: system, [00004A000000 - 000122000000], size: 0000D8000000 (3.38 GB) Partition: userdata, [000122000000 - 000747BFBE00], size: 000625BFBE00 (24.5 GB) GPT header successfully parsed Get firmware version Firmware info not found Code: G:\MaximoAssisTec\Motorola\Software\MFastboot1\MFastboot>mfastboot devices 2242023c fastboot G:\MaximoAssisTec\Motorola\Software\MFastboot1\MFastboot>mfastboot getvar all version: 0.5 version-bootloader: moto-msm8937-B8.31(*) product: cedric board: cedric secure: yes hwrev: P5 radio: 8 storage-type: emmc emmc: 32GB SAMSUNG QX13MB RV=08 PV=07 FV=0000000000000007 ram: 2GB SAMSUNG LP3 DIE=8Gb M5=01 M6=05 M7=00 M8=1F cpu: MSM8937 serialno: 2242023c cid: 0xDEAD channelid: 0x00 uid: 0000000000000000000000000000 securestate: oem_locked iswarrantyvoid: n/a max-download-size: 535822336 reason: Failed to initialize partition table imei: 000000000000000 meid: date: 01-01-1970 sku: 000000000000000 carrier_sku: battid: iccid: cust_md5: max-sparse-size: 268435456 current-time: ro.build.fingerprint: poweroffalarm: 0 ro.build.version.full: ro.build.version.qcom: version-baseband: kernel.version: sbl1.git: sbl1.git rpm.git: rpm.git tz.git: tz.git devcfg.git: devcfg.git keymaster.git: keymaster.git cmnlib.git: cmnlib.git cmnlib64.git: cmnlib64.git prov.git: prov.git aboot.git: git=MBM-NG-VB8.31-0-g0b9dae9 frp-state: no protection (err) ro.carrier: current-slot: slot-suffixes: _a slot-count: 1 slot-successful:_a: INVALID slot-successful:_b: INVALID slot-bootable:_a: INVALID slot-bootable:_b: INVALID slot-retry-count:_a: unknown slot-retry-count:_b: unknown all: listed above finished. total time: 0.063s G:\MaximoAssisTec\Motorola\Software\MFastboot1\MFastboot>mfastboot oem partition ... OKAY [ 0.004s] finished. total time: 0.004s G:\MaximoAssisTec\Motorola\Software\MFastboot1\MFastboot>mfastboot oem cid_prov_req ... CID prov request failed, dbval_rsp 55 FAILED (remote failure) finished. total time: 0.016s G:\MaximoAssisTec\Motorola\Software\MFastboot1\MFastboot>mfastboot flash partition gpt.bin sending 'partition' (45 KB)... OKAY [ 0.005s] writing 'partition'... Validating 'gpt.default.xml' Image primary_gpt failed validation Preflash validation failed Cancelling 'gpt.default.xml' FAILED (remote failure) finished. total time: 0.041s G:\MaximoAssisTec\Motorola\Software\MFastboot1\MFastboot>mfastboot flash bootloader bootloader.img sending 'bootloader' (5179 KB)... OKAY [ 0.177s] writing 'bootloader'... Validating 'bootloader.default.xml' Invalid partition name aboot Invalid partition name rpm Invalid partition name tz Invalid partition name devcfg Invalid partition name cmnlib Invalid partition name cmnlib64 Invalid partition name keymaster Invalid partition name prov Invalid partition name sbl1 Cancelling 'bootloader.default.xml' FAILED (remote failure) finished. total time: 0.288s |
The Following User Says Thank You to JefMaximo For This Useful Post: |
08-04-2020, 15:00 | #2 (permalink) |
Member: 2772222 Status: Offline Thanks Meter: 9 | To help won analize i repeated the same process with old eMMc. In log i change the color in some commands to we see the difference. Log old eMMC: Code: Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 24 MHz CMD Pullup Level: 2119 mV CMD Active Level: 2332 mV EMMC Device Information : EMMC CID: 150100515831334D4207CC1CDA544499 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QX13MB , HEX: 515831334D42 , S/N: CC1CDA54 , rev. 0x07 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 4/2017 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 46714 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX13MB_CC1CDA54_20200804_094001.extcsd EMMC Init completed. Warning: Health report is very BAD Device Life Time Estimation (MLC) [269]: 0x0B Exceeded its maximum estimated device life time Device Life Time Estimation (SLC) [268]: 0x0B Exceeded its maximum estimated device life time Pre EOL information [267]: 0x01 Normal Scanning soft partitions Partition table not found Get firmware version Firmware info not found Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 24 MHz CMD Pullup Level: 2119 mV CMD Active Level: 2332 mV EMMC Device Information : EMMC CID: 150100515831334D4207CC1CDA544499 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QX13MB , HEX: 515831334D42 , S/N: CC1CDA54 , rev. 0x07 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 4/2017 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 46714 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX13MB_CC1CDA54_20200804_094546.extcsd EMMC Init completed. Warning: Health report is very BAD Device Life Time Estimation (MLC) [269]: 0x0B Exceeded its maximum estimated device life time Device Life Time Estimation (SLC) [268]: 0x0B Exceeded its maximum estimated device life time Pre EOL information [267]: 0x01 Normal Operation: Writing all eMMC Regions... Operation: Writing BootConfig ... Reg: 179 Value: 0x38 Reg: 177 Value: 0x00 Reg: 162 Value: 0x01 Done Writing to: ROM2 , start: 0x000000000000 , size: 0x000000400000 Filename: EMMC_QX13MB_ROM2_000000000000_000000400000 OS567.bin eMMC switching to ROM2 Writing partition... Done writing partition. Write speed: 680.17 KB/s Writing to: ROM3 , start: 0x000000000000 , size: 0x000000400000 Filename: EMMC_QX13MB_ROM3_000000000000_000000400000 OS567.bin eMMC switching to ROM3 Writing partition... Done writing partition. Write speed: 682.65 KB/s Writing to: ROM1 , start: 0x000000000000 , size: 0x000020000000 Filename: EMMC_QX13MB_ROM1_000000000000_000020000000 OS567.bin eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 2688.93 KB/s All done time: [00:03:30:155] Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 24 MHz CMD Pullup Level: 2119 mV CMD Active Level: 2332 mV EMMC Device Information : EMMC CID: 150100515831334D4207CC1CDA544499 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QX13MB , HEX: 515831334D42 , S/N: CC1CDA54 , rev. 0x07 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 4/2017 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 46714 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX13MB_CC1CDA54_20200804_094939.extcsd EMMC Init completed. Warning: Health report is very BAD Device Life Time Estimation (MLC) [269]: 0x0B Exceeded its maximum estimated device life time Device Life Time Estimation (SLC) [268]: 0x0B Exceeded its maximum estimated device life time Pre EOL information [267]: 0x01 Normal Scanning soft partitions GPT header is found and is valid Partition: sbl1, [000000020000 - 0000000A0000], size: 000000080000 (512. KB) Partition: rpm, [0000000A0000 - 0000000E0000], size: 000000040000 (256. KB) Partition: tz, [000000120000 - 0000002E0000], size: 0000001C0000 (1.75 MB) Partition: devcfg, [000000320000 - 000000340000], size: 000000020000 (128. KB) Partition: aboot, [000000360000 - 0000004E0000], size: 000000180000 (1.50 MB) Partition: cmnlib, [0000004E0000 - 000000520000], size: 000000040000 (256. KB) Partition: cmnlib64, [000000520000 - 000000560000], size: 000000040000 (256. KB) Partition: keymaster, [000000560000 - 0000005A0000], size: 000000040000 (256. KB) Partition: prov, [0000005A0000 - 0000005D0000], size: 000000030000 (192. KB) Partition: sbl1bak, [0000005E0000 - 000000660000], size: 000000080000 (512. KB) Partition: rpmbak, [000000660000 - 0000006A0000], size: 000000040000 (256. KB) Partition: tzbak, [0000006E0000 - 0000008A0000], size: 0000001C0000 (1.75 MB) Partition: devcfgbak, [0000008E0000 - 000000900000], size: 000000020000 (128. KB) Partition: abootbak, [000000920000 - 000000AA0000], size: 000000180000 (1.50 MB) Partition: cmnlibbak, [000000AA0000 - 000000AE0000], size: 000000040000 (256. KB) Partition: cmnlib64bak, [000000AE0000 - 000000B20000], size: 000000040000 (256. KB) Partition: keymasterbak, [000000B20000 - 000000B60000], size: 000000040000 (256. KB) Partition: provbak, [000000B60000 - 000000B90000], size: 000000030000 (192. KB) Partition: modem, [000000BA0000 - 000006FA0000], size: 000006400000 (100. MB) Partition: fsc, [000006FA0000 - 000006FA0400], size: 000000000400 (1.00 KB) Partition: ssd, [000006FA0400 - 000006FA2400], size: 000000002000 (8.00 KB) Partition: dsp, [000006FA2400 - 000007FA2400], size: 000001000000 (16.0 MB) Partition: DDR, [000007FC0000 - 000007FC8000], size: 000000008000 (32.0 KB) Partition: sec, [000007FC8000 - 000007FCC000], size: 000000004000 (16.0 KB) Partition: utags, [000007FE0000 - 000008060000], size: 000000080000 (512. KB) Partition: utagsBackup, [000008060000 - 0000080E0000], size: 000000080000 (512. KB) Partition: modemst1, [0000080E0000 - 0000082E0000], size: 000000200000 (2.00 MB) Partition: modemst2, [0000082E0000 - 0000084E0000], size: 000000200000 (2.00 MB) Partition: fsg, [0000084E0000 - 000008CE0000], size: 000000800000 (8.00 MB) Partition: persist, [000008CE0000 - 00000ACE0000], size: 000002000000 (32.0 MB) Partition: frp, [00000ACE0000 - 00000AD60000], size: 000000080000 (512. KB) Partition: cid, [00000AD60000 - 00000AD80000], size: 000000020000 (128. KB) Partition: logo, [00000AD80000 - 00000BD80000], size: 000001000000 (16.0 MB) Partition: carrier, [00000BD80000 - 00000CD80000], size: 000001000000 (16.0 MB) Partition: metadata, [00000CD80000 - 00000CE00000], size: 000000080000 (512. KB) Partition: kpan, [00000CE00000 - 00000D600000], size: 000000800000 (8.00 MB) Partition: boot, [00000D600000 - 00000E600000], size: 000001000000 (16.0 MB) Partition: recovery, [00000E600000 - 00000F619000], size: 000001019000 (16.1 MB) Partition: misc, [00000F620000 - 00000F720000], size: 000000100000 (1.00 MB) Partition: limits, [00000F720000 - 00000F728000], size: 000000008000 (32.0 KB) Partition: mota, [00000F740000 - 00000F7C0000], size: 000000080000 (512. KB) Partition: dip, [00000F7C0000 - 00000F8C0000], size: 000000100000 (1.00 MB) Partition: syscfg, [00000F8C0000 - 00000F940000], size: 000000080000 (512. KB) Partition: logs, [00000F940000 - 00000FB40000], size: 000000200000 (2.00 MB) Partition: apdp, [00000FB40000 - 00000FB80000], size: 000000040000 (256. KB) Partition: msadp, [00000FB80000 - 00000FBC0000], size: 000000040000 (256. KB) Partition: dpo, [00000FBC0000 - 00000FBC2000], size: 000000002000 (8.00 KB) Partition: padA, [00000FBE0000 - 000010000000], size: 000000420000 (4.13 MB) Partition: sp, [000010000000 - 000010800000], size: 000000800000 (8.00 MB) Partition: hw, [000010800000 - 000011000000], size: 000000800000 (8.00 MB) Partition: oem, [000011000000 - 00003A000000], size: 000029000000 (656. MB) Partition: cache, [00003A000000 - 00004A000000], size: 000010000000 (256. MB) Partition: system, [00004A000000 - 000122000000], size: 0000D8000000 (3.38 GB) Partition: userdata, [000122000000 - 000747BFBE00], size: 000625BFBE00 (24.5 GB) GPT header successfully parsed Get firmware version Firmware info not found Log Fastboot Code: G:\MaximoAssisTec\Motorola\Software\MFastboot1\MFastboot>mfastboot devices cc1cda54 fastboot G:\MaximoAssisTec\Motorola\Software\MFastboot1\MFastboot>mfastboot getvar all version: 0.5 version-bootloader: moto-msm8937-B8.31 product: cedric board: cedric secure: yes hwrev: P5 radio: 8 storage-type: emmc emmc: 32GB SAMSUNG QX13MB RV=08 PV=07 FV=0000000000000007 ram: 2GB SAMSUNG LP3 DIE=8Gb M5=01 M6=05 M7=00 M8=1F cpu: MSM8937 serialno: cc1cda54 cid: 0x0032 channelid: 0x19 uid: 322A661700000000000000000000 securestate: oem_locked iswarrantyvoid: no max-download-size: 535822336 reason: Reboot mode set to fastboot imei: 000000000000000 meid: date: 01-01-1970 sku: 000000000000000 carrier_sku: battid: iccid: cust_md5: max-sparse-size: 268435456 current-time: ro.build.fingerprint: poweroffalarm: 0 ro.build.version.full: ro.build.version.qcom: version-baseband: kernel.version: sbl1.git: git=MBM-NG-VB8.31-0-g77d3670 rpm.git: git=bd76357-dirty tz.git: git=3f87a46 devcfg.git: git=3f87a46 keymaster.git: git=3f87a46 cmnlib.git: git=3f87a46 cmnlib64.git: git=3f87a46 prov.git: git=3f87a46 aboot.git: git=MBM-NG-VB8.31-0-g0b9dae9 frp-state: protected (77) ro.carrier: current-slot: slot-suffixes: _a slot-count: 1 slot-successful:_a: INVALID slot-successful:_b: INVALID slot-bootable:_a: INVALID slot-bootable:_b: INVALID slot-retry-count:_a: unknown slot-retry-count:_b: unknown all: listed above finished. total time: 0.060s G:\MaximoAssisTec\Motorola\Software\MFastboot1\MFastboot>mfastboot oem partition ... sbl1: offset=128KB, size=512KB rpm: offset=640KB, size=256KB tz: offset=1152KB, size=1792KB devcfg: offset=3200KB, size=128KB aboot: offset=3456KB, size=1536KB cmnlib: offset=4992KB, size=256KB cmnlib64: offset=5248KB, size=256KB keymaster: offset=5504KB, size=256KB prov: offset=5760KB, size=192KB sbl1bak: offset=6016KB, size=512KB rpmbak: offset=6528KB, size=256KB tzbak: offset=7040KB, size=1792KB devcfgbak: offset=9088KB, size=128KB abootbak: offset=9344KB, size=1536KB cmnlibbak: offset=10880KB, size=256KB cmnlib64bak: offset=11136KB, size=256KB keymasterbak: offset=11392KB, size=256KB provbak: offset=11648KB, size=192KB modem: offset=11904KB, size=102400KB fsc: offset=114304KB, size=1KB ssd: offset=114305KB, size=8KB dsp: offset=114313KB, size=16384KB DDR: offset=130816KB, size=32KB sec: offset=130848KB, size=16KB utags: offset=130944KB, size=512KB utagsBackup: offset=131456KB, size=512KB modemst1: offset=131968KB, size=2048KB modemst2: offset=134016KB, size=2048KB fsg: offset=136064KB, size=8192KB persist: offset=144256KB, size=32768KB frp: offset=177024KB, size=512KB cid: offset=177536KB, size=128KB logo: offset=177664KB, size=16384KB carrier: offset=194048KB, size=16384KB metadata: offset=210432KB, size=512KB kpan: offset=210944KB, size=8192KB boot: offset=219136KB, size=16384KB recovery: offset=235520KB, size=16484KB misc: offset=252032KB, size=1024KB limits: offset=253056KB, size=32KB mota: offset=253184KB, size=512KB dip: offset=253696KB, size=1024KB syscfg: offset=254720KB, size=512KB logs: offset=255232KB, size=2048KB apdp: offset=257280KB, size=256KB msadp: offset=257536KB, size=256KB dpo: offset=257792KB, size=8KB padA: offset=257920KB, size=4224KB sp: offset=262144KB, size=8192KB hw: offset=270336KB, size=8192KB oem: offset=278528KB, size=671744KB cache: offset=950272KB, size=262144KB system: offset=1212416KB, size=3538944KB userdata: offset=4751360KB, size=25784303KB OKAY [ 0.057s] finished. total time: 0.058s G:\MaximoAssisTec\Motorola\Software\MFastboot1\MFastboot>mfastboot oem cid_prov_req ... 0001dddddddddddddddd000000000000 00000000000000000000000000000000 00000000000000000000000000000000 00000000000000000000000000000000 0000f182674a411542067be6092530b7 f6db000100f0000100000062322a6617 00000000000000000000000000000000 00000000000000000000000000000000 0000dddddddddddddddd000631313131 31313131313131313131313131313131 0000ffffffffffffffffffffffffffff ffffffffffff OKAY [ 0.013s] finished. total time: 0.013s G:\MaximoAssisTec\Motorola\Software\MFastboot1\MFastboot>mfastboot flash partition gpt.bin sending 'partition' (45 KB)... OKAY [ 0.005s] writing 'partition'... Validating 'gpt.default.xml' Committing 'gpt.default.xml' - flashing 'gpt_main0.bin' to 'partition:0' Flashing primary GPT image... Flashing backup GPT image... OKAY [ 0.085s] finished. total time: 0.091s G:\MaximoAssisTec\Motorola\Software\MFastboot1\MFastboot>mfastboot flash bootloader bootloader.img sending 'bootloader' (5179 KB)... OKAY [ 0.165s] writing 'bootloader'... Validating 'bootloader.default.xml' Committing 'bootloader.default.xml' - flashing 'emmc_appsboot.mbn' to 'aboot' - flashing 'rpm.mbn' to 'rpm' - flashing 'tz.mbn' to 'tz' - flashing 'devcfg.mbn' to 'devcfg' - flashing 'cmnlib.mbn' to 'cmnlib' - flashing 'cmnlib64.mbn' to 'cmnlib64' - flashing 'keymaster.mbn' to 'keymaster' - flashing 'prov.mbn' to 'prov' - flashing 'sbl1.mbn' to 'sbl1' OKAY [ 0.552s] finished. total time: 0.718s Comparation and questions: 1) The serial number change. With original eMMC cc1cda54. With New eMMC 2242023c . Where the serial number is alocated? Why the serial number changed? 2) CID is mounted in Old eMMC but in New says Dead. I checked using HxD software and both partions are the same after write. Why says dead? 3) Channelid changed. Old eMMC 0x19 and New eMMC 0x00. I dont Know what is Channelid. 4)UID changed: Old eMMC 322A661700000000000000000000 and New eMMC 0000000000000000000000000000. I dont Know what is UID. 5) Boot partitions: Sbl1, Rpm, Tz, Devcfg, Keymaster, Cmlib, Cmlib64, Prov, Aboot and FRP. Look the difference. 6) Device answere with Old eMMC: Oem partitios Oem cid_prov_req And flash device with gpt and bootloader. OBS: Motorola represente 22.06% in Brazil. This fault (Stuck in fastboot mode or Bricked) is very common after change eMMC or boot repair. |
08-08-2020, 02:26 | #4 (permalink) |
Freak Poster Join Date: Jul 2013 Location: egypt alexandria
Member: 1972033 Status: Offline Thanks Meter: 32 | bro old emmc RPMB section is not clean or clean or wat .... in new emmc RPMB clean or not? |
The Following User Says Thank You to nour2014 For This Useful Post: |
08-08-2020, 02:27 | #5 (permalink) |
Member: 1972033 Status: Offline Thanks Meter: 32 | i see in old and new emmc RPMB is not clean u need emmc have RPMB clean and try again |
