07-26-2020, 11:38 | #1 (permalink) |
Insane Poster Join Date: Nov 2014 Location: Manila, Philippines
Member: 2287078 Status: Offline Thanks Meter: 6 | y91 vivo 1817 dead phone problem was password I try android frp clear clear/ping/gst pass now phone wont power on ...stone dead. how to revive this? |
07-26-2020, 14:37 | #2 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
If you device not boot after you action, it's may be: 1) you may be damage PCB (device board) 2) you may be damage boot or system partition (you action is not be only press "Remove pass" button) if you demage PCB - you need use microscope and restore it if you damage boot or system partition of eMMC/UFS - you need restore it via original firmware or dump file (with dump file you need backup secure partition before) | |
The Following User Says Thank You to layder For This Useful Post: |
07-28-2020, 08:09 | #4 (permalink) | |
Member: 2287078 Status: Offline Thanks Meter: 6 | Quote:
I wonder if there's a full dump firmware of this y91 vivo 1817 that i can download. I would appreciate if you could share that file. I'm using the old hardware easy jtag not the plus version. | |
07-30-2020, 07:41 | #5 (permalink) |
Member: 2287078 Status: Offline Thanks Meter: 6 | Is it possible to flash and revive this using my old hardware and easy jtag plus software? i have already firmware Vivo_Y91_PD1818F_EX_A_1.8.25_LA.UM.6.6.2.R1-04200-89XX.0_QFIL is this setup ok? I can flash y91 using my old hardware and easy jtag plus software? should i proceed to write now? Do i need boot config file? or proceed to write? Last edited by layder; 07-30-2020 at 10:23. Reason: merge posts |
07-30-2020, 10:25 | #6 (permalink) | |
it's needed when you replace eMMC | |
07-30-2020, 11:49 | #7 (permalink) |
Member: 2287078 Status: Offline Thanks Meter: 6 | i did not replace emmc. Y91 went qualcom mode and not power on after android frp clear clear/ping/gst pass so i think i need to flash... am i doing right if i flash it now with the settings in the picture? |
07-30-2020, 18:18 | #8 (permalink) | |
if the program does not require you to have a file there, then you can do it without it | |
