IQ Doctor iq-doctorbox |
05-28-2011, 08:08 | #1 (permalink) |
No Life Poster Join Date: May 2011 Location: WeChat : Razib_Dits
Member: 1582197 Status: Offline Sonork: Whatapps : Razibbsl Thanks Meter: 808 | Post here all successfuly flashed, unlocked and repaired phones with IQ Doctor DA_LIB_VER_3.2.2.8 It is sensing the pinout fast,please hold on the phone Power key RXD=21 TXD=22 Connecting...Please hold on the POWER key until the red gauge is going... BB:6226, HardwareVer:8A02, SoftwareVer:8A01 Loading boot... INT_SYSRAM_BOOT test completed. Nor Flash ID: 0001227E22022201 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Get Project ID from phone... Project ID: MAUI.08B.W09.08.MP.V2 Changing baudrate to 921600... Done. Formatting Flash... AutoFormat address: start=0x00E00000, size=0x00200000 All Done |
The Following User Says Thank You to SoniaTel For This Useful Post: |
05-28-2011, 08:23 | #3 (permalink) |
Member: 1582197 Status: Offline Sonork: Whatapps : Razibbsl Thanks Meter: 808 | nitializing... DA_LIB_VER_2.4.4.7 It is sensing the pinout fast... D-=2 D+=3 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM11 Connected...sending boot... FDL test...OK ArmBootMode: 6600700538E3A000_01 Wait for init SB... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Read info is done. CPU: SC6600L/WT6226A Flash: NOR_TV00560002EDGB Set FLASH Parameters... Settings have been completed! Connect and search Security Code... Privacy protect: 1629 Theft proof: 123456 PhoneLock: 12345 Done. |
05-28-2011, 13:59 | #4 (permalink) |
Member: 1582197 Status: Offline Sonork: Whatapps : Razibbsl Thanks Meter: 808 | Initializing... DA_LIB_VER_3.2.2.8 It is sensing the pinout fast... D-=2 D+=3 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM33 Connected...sending boot... FDL test...OK ArmBootMode: 6600700900005A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Read info is done. CPU: SC6600L7 Flash: NOR_ST_M58WR064KT setting the Flash Parameters... Settings have been completed! Connect and search Security Code... Privacy protect: 0 Privacy protect: 9 PhoneLock: 430 Privacy protect: 1234 PhoneLock: 72287 PhoneLock: 063 Done. |
05-28-2011, 14:01 | #5 (permalink) |
Member: 1582197 Status: Offline Sonork: Whatapps : Razibbsl Thanks Meter: 808 | Initializing... DA_LIB_VER_3.2.2.8 It is sensing the pinout fast... D-=2 D+=3 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM33 Connected...sending boot... FDL test...OK ArmBootMode: 6600700900025A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Read info is done. CPU: SC6600L7 Flash: NOR_ST_M58WR064KT setting the Flash Parameters... Settings have been completed! Reading Flash... Saved file to: C:\Documents and Settings\Razib\Desktop\Nokia Nony S208+ All Done. Reading Project Version... Platform Version: MOCOR_09A.W10.25_P1_L6230T_B200_MULTI_R1.01_201011 08 Project Version: SC6600L_sp6601l_trisim MMI Version: SC6600L_sp6601l_trisim BASE Version: BASE_TRISIM_R1.0.2022 HW Version: SC6600L_sp6601l Project Bulid Time: 11-8-2010 12:21:43 |
05-28-2011, 14:09 | #6 (permalink) |
Member: 1582197 Status: Offline Sonork: Whatapps : Razibbsl Thanks Meter: 808 | Initializing... DA_LIB_VER_3.2.2.8 It is sensing the pinout fast... D-=2 D+=3 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM33 Connected...sending boot... FDL test...OK ArmBootMode: 6600700900005A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Read info is done. CPU: SC6600L7 Flash: NOR_ST_M58WR064KT setting the Flash Parameters... Settings have been completed! Unlocking all blocks before program/erase... Unlock Done. Programming... Compare Image: Enable All Done. |
05-29-2011, 06:55 | #7 (permalink) |
05-29-2011, 09:04 | #8 (permalink) |
Member: 1582197 Status: Offline Sonork: Whatapps : Razibbsl Thanks Meter: 808 | Initializing... DA_LIB_VER_2.4.4.7 It is sensing the pinout fast... D-=9 D+=8 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM11 Connected...sending boot... FDL test...OK ArmBootMode: 660080002C42A0FF_01 Wait for init SB... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Read info is done. CPU: SC6600R Flash: NAND_HY27XS08121M Set FLASH Parameters... Settings have been completed! Connect and search Security Code... Privacy protect: 102201 PhoneLock: 45678 Privacy protect: 9 Done. |
05-30-2011, 06:10 | #10 (permalink) |
05-30-2011, 09:08 | #12 (permalink) |
Member: 1582197 Status: Offline Sonork: Whatapps : Razibbsl Thanks Meter: 808 | Initializing... DA_LIB_VER_3.2.2.8 It is sensing the pinout fast,please hold on the phone Power key RXD=21 TXD=22 Connecting...Please hold on the POWER key until the red gauge is going... BB:6226, HardwareVer:8A02, SoftwareVer:8A01 Loading boot... INT_SYSRAM_BOOT test completed. Nor Flash ID: 0001227E22022201 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Get Project ID from phone... Project ID: MAUI.08B.W09.08.MP.V2 Changing baudrate to 921600... Done. Formatting Flash... AutoFormat address: start=0x00E00000, size=0x00200000 All Done |
05-30-2011, 12:45 | #13 (permalink) |
Member: 1582197 Status: Offline Sonork: Whatapps : Razibbsl Thanks Meter: 808 | Initializing... DA_LIB_VER_3.2.2.8 It is sensing the pinout fast,please hold on the phone Power key RXD=6 TXD=7 Connecting...Please hold on the POWER key until the red gauge is going... BB:6253, HardwareVer:8A00, SoftwareVer:8A02 Loading boot... INT_SYSRAM_BOOT test completed. Nor Flash ID: 00EC225400000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI... H/W detection ok. Get Project ID from phone... Project ID: 7512AC_GH_S218_F4A_V05_110309 Changing baudrate to 921600... Done. Formatting Flash... AutoFormat address: start=0x00740000, size=0x000C0000 All Done |
05-30-2011, 12:53 | #14 (permalink) |
05-30-2011, 12:53 | #15 (permalink) |
Member: 1582197 Status: Offline Sonork: Whatapps : Razibbsl Thanks Meter: 808 | Initializing... DA_LIB_VER_3.2.2.7 It is sensing the pinout fast,please hold on the phone Power key RXD=6 TXD=7 Connecting...Please hold on the POWER key until the red gauge is going... BB:6253, HardwareVer:8A00, SoftwareVer:8A02 Loading boot... INT_SYSRAM_BOOT test completed. Nor Flash ID: 00EC225400000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI... H/W detection ok. Get Project ID from phone... Project ID: 7512AC_GH_S218_F4A_V05_110309 |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
