02-24-2002, 00:31 | #1 (permalink) |
No Life Poster Join Date: Apr 2001 Location: UK Age: 49
Member: 4217 Status: Offline Thanks Meter: 28 | Guide to making Z7 software 100% on all versions! If phone reads unsuccesful, a slight change to the id will sort the problem.<br />The second to last digit/letter is all you need to alter. <br />Keep changing the letter/digit til another code is displayed.<br />I have found that you can enter A to F or 0 to 9.<br />Most of the time the codes will stay the same just keep changing the digit/letter til the code alters. Good luck i have had success with this so hope it helps. Dont forget to rate me. |
02-26-2002, 10:21 | #7 (permalink) |
No Life Poster Join Date: Jul 2001
Member: 5389 Status: Offline Thanks Meter: 1 | Hi<br /> I dont understand this can somebody help me,when I read the phone its apear this:<br /> sim..11280105 id..12033C15BAE9<br /> wap..57091087 imei. not avail.<br /> What to change here,and after changing do you push get codes.<br /> Thanks Regards |
02-28-2002, 09:22 | #8 (permalink) |
Junior Member Join Date: Dec 2001 Location: uk
Member: 8011 Status: Offline Thanks Meter: 0 | Hi, Change your id code (12033C15BAE9) letter "E" befor 9 to "F" (12033C15BAF9) and click get code it should give you diffrent sim code. if sim code is still same keep changing same letter replacing it with letter A-F 0r 0-9 till you get the diffrent code. enjoy and rate dolaghan |
03-07-2002, 02:43 | #11 (permalink) |
No Life Poster Join Date: Jul 2001 Location: London, UK
Member: 5324 Status: Offline Thanks Meter: 7 | this did not work for me, i did get 2 other codes by following your method but both codes still gave unseccesfull on phone display, any other advice regards nick |
03-08-2002, 09:09 | #12 (permalink) |
Freak Poster Join Date: Jul 2001 Location: Birmingham - UK
Member: 5378 Status: Offline Thanks Meter: 0 | same her bluelights. after changing the second from last i got 2 other differest codes. The first unsuccessful, i had to wait about 6 minutes for the phone to go back to normal. then when the second code entered it also said unsuccesful and then the phone cant get back to normal. how long do i have to wait??? |
Guide to Making Mutton Dishes III (????????-3) (box packing VCD) (China) (Region ALL) | IPMART | ipmart WebShop | 0 | 03-27-2010 11:10 |
guide to make mt-box dct4 10 pin cable by yourself !@gopalhot@ | gopalhot | Nokia Hardware & Hardware Repair | 0 | 06-08-2009 12:58 |
Make your F3 clip support all versions | snsoftkiller | Smart-Clip | 1 | 01-13-2008 06:31 |
Can someone please explain how to make Z7 Soft 100% | unlockgod | Sony | 0 | 02-18-2002 11:13 |
