10-06-2004, 10:15 | #1 (permalink) |
Junior Member Join Date: Oct 2004
Member: 85240 Status: Offline Thanks Meter: 0 | Z5 unlock cable question I bought a cable for a SIM-locked Z5 (please see http://www.pecmobiledata.co.uk/acata..._Sony_257.html for a picture). The description says it can be used to unlock the phone. I have tried two pieces of software to no avail - the Z5logger way and also a bit of software that takes the IMEI as an input and resets everything. Neither of them work - could it be that I am using the wrong cable, since it would seem that the PC is not communicationg with the phone? Thanks, JoshM |
10-09-2004, 21:59 | #2 (permalink) |
Freak Poster Join Date: Dec 2001 Location: Edinburgh UK
Member: 7958 Status: Offline Thanks Meter: 6 | nope ...this cable is no good...did you download the prog from one of my other posts?? cable should have a 9v battery connector attatched to max232 interface...you could do this yourself |
10-09-2004, 22:02 | #3 (permalink) |
Member: 7958 Status: Offline Thanks Meter: 6 | 3+6 is connected to 9V+ve 1+4 is connected to 9v-ve if you have it connected up correctly when program says ...."press red button" it should come up and say "z5 detected" this program used 100's of times on win 98se without any problem. |
10-10-2004, 20:26 | #4 (permalink) | |
No Life Poster Join Date: Jul 2004 Age: 46
Member: 74084 Status: Offline Thanks Meter: 8 | Quote:
I don't understand fine how to modify my cable! Pls, If possible for you to post a real picture of modificate cable? Thanks in advance for your help! | |
a dumb question on W600i unlock cable | zerorigin | Cruiser Suite | 3 | 01-08-2006 10:17 |
Unlock Cable Question, help please.................... | Ben5016 | Samsung Flashers, Software, Firmware. | 4 | 02-21-2004 06:00 |
Z5 fax cable help | EP3SK | Sony | 4 | 09-09-2003 12:31 |
z5 dont power after after z5 unlocker v2.0 | sergioems | Sony | 0 | 07-19-2003 21:53 |
I need Z5 flashing cables with ext. power supply! | NUGSM | Main Sales Section | 0 | 09-13-2001 11:08 |
