03-23-2024, 10:27 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: gsmchaudhrayarshad Age: 43
Member: 328688 Status: Offline Thanks Meter: 2,283 | A057f u2 mdm issue [Answered] Welcome to Octoplus Samsung Software v.4.2.8.4 Work ID: 00000000018F4C7C Starting Unlock MDM (Mar.2024) Selected model: SM-A057F Make factory data reset and connect the phone on first page of activation stage to PC via USB. Phone must be in Setup Wizard mode Connect powered-on device to PC! Searching modem port... Not found Unlock MDM (Mar.2024) failed Execution time 7 second(s) Performed by 4.2.8.4 Software version. Work ID: 000000000205B8E9 Starting Unlock MDM (Mar.2024) Selected model: SM-A057F Make factory data reset and connect the phone on first page of activation stage to PC via USB. Phone must be in Setup Wizard mode Connect powered-on device to PC! Searching modem port... Not found Unlock MDM (Mar.2024) failed Execution time 7 second(s) Performed by 4.2.8.4 Software version. Work ID: 000000000205B8F5 Starting Unlock MDM (Mar.2024) Selected model: SM-A057F Make factory data reset and connect the phone on first page of activation stage to PC via USB. Phone must be in Setup Wizard mode Connect powered-on device to PC! Searching modem port... OK Input IMEI: 354860723756168 Input SN: R7AX102QS5T Connecting to server... Username: CH_ARSHAD Your balance: 0 credits Sending device information.. OK Choose unlock method! QR code method choosen! Please check device using this QR before unlocking! Follow these steps : 1. In Android Setup Wizard mode tap on the blank space 6 times. 2. Scan this QR code to install MDM Guard service on your device. 3. Connect to Wi-Fi. 4. Follow the instructions on the screen. 5. Allow USB debugging mode when prompt appears on the screen. Searching ADB devices... Press "OK" button on the device to allow USB debugging OK QR Code is scanned Reading info... Detected model: SM-A057F Fingerprint: samsung/a05snndxx/a05s:13/TP1A.220624.014/A057FXXS2AWL5:user/release-keys Firmware compiled date: Wed Dec 20 19:42:46 KST 2023 PDA version: A057FXXS2AWL5 CSC version: A057FOJM2AWL5 SW version: A057FXXS2AWL5 Build number: 25641239 Phone SN: R7AX102QS5T Android version: 13 (TP1A.220624.014) Sales code: XFA Carrier Id: XFA Country: SOUTH AFRICA HW platform: qcom HW Chip: bengal HW Modem: REV1.0 Security patch level: 2023-11-01 Warranty Void: 0 Codename: a05snndxx SIM 1 status: ABSENT SIM 2 status: ABSENT Modem board: SM6225 Starting exploit... Activating service... Security level is too high to use method #1! Using method #2 Warning: After rebooting the device, a MDM lock may appear. MDM Guard service will turn off the screen and the MDM lock will disappear. This may happen a few times after reboot. MDM Guard service was activated. Complete the Setup Wizard on the device. MDM Guard service will restrict OTA updates on your device to prevent relock. Unlock MDM (Mar.2024) done Execution time 7 minute(s) 40 second(s) Performed by 4.2.8.4 Software version. |
03-24-2024, 07:34 | #2 (permalink) |
Member: 328688 Status: Offline Thanks Meter: 2,283 | after 5 try still same lock comeback after mint Welcome to Octoplus Samsung Software v.4.2.8.4 Work ID: 00000000018FBCB2 Starting Unlock MDM (Mar.2024) Selected model: SM-A057F Make factory data reset and connect the phone on first page of activation stage to PC via USB. Phone must be in Setup Wizard mode Connect powered-on device to PC! Searching modem port... OK Input IMEI: 354860723756168 Input SN: R7AX102QS5T Connecting to server... Username: CH_ARSHAD Your balance: 0 credits Sending device information.. OK Choose unlock method! QR code method choosen! Please check device using this QR before unlocking! Follow these steps : 1. In Android Setup Wizard mode tap on the blank space 6 times. 2. Scan this QR code to install MDM Guard service on your device. 3. Connect to Wi-Fi. 4. Follow the instructions on the screen. 5. Allow USB debugging mode when prompt appears on the screen. Searching ADB devices... Press "OK" button on the device to allow USB debugging OK QR Code is scanned Reading info... Detected model: SM-A057F Fingerprint: samsung/a05snndxx/a05s:13/TP1A.220624.014/A057FXXS2AWL5:user/release-keys Firmware compiled date: Wed Dec 20 19:42:46 KST 2023 PDA version: A057FXXS2AWL5 CSC version: A057FOJM2AWL5 SW version: A057FXXS2AWL5 Build number: 25641239 Phone SN: R7AX102QS5T Android version: 13 (TP1A.220624.014) Sales code: XFA Carrier Id: XFA Country: SOUTH AFRICA HW platform: qcom HW Chip: bengal HW Modem: REV1.0 Security patch level: 2023-11-01 Warranty Void: 0 Codename: a05snndxx SIM 1 status: ABSENT SIM 2 status: ABSENT Modem board: SM6225 Starting exploit... Activating service... Security level is too high to use method #1! Using method #2 Warning: After rebooting the device, a MDM lock may appear. MDM Guard service will turn off the screen and the MDM lock will disappear. This may happen a few times after reboot. MDM Guard service was activated. Complete the Setup Wizard on the device. MDM Guard service will restrict OTA updates on your device to prevent relock. Unlock MDM (Mar.2024) done Execution time 11 minute(s) 28 second(s) Performed by 4.2.8.4 Software version. |
