04-24-2017, 11:31 | #1 (permalink) |
No Life Poster Join Date: Apr 2016
Member: 2561651 Status: Offline Sonork: 100.******* Thanks Meter: 292 | A510F FRP rest latest sec.. Hello,. 1st you should have this combination from octo support , download this one file COMBINATION_FAC_FA51_A510FXXU3API1_FAC_CL9213193_Q B10877732.oct After Flash combination. complete the all steps , FRP via OCTO after complete FRP REST option , goto setting and rest factory data now flash the STOCK rom, MOST IMPORTANT thing, your Devices is still in FRP ON mode so after flash STOCK rom dont factory data rest ,JUST leave it to ON after you should be on Device LOCK screen don,t scroll the lock screen GOTO setting via notification panel and REST factory DATA , That,s it Br Mr .:ALE:.a Last edited by Octopus box; 04-24-2017 at 11:56. |
The Following User Says Thank You to .:D:. For This Useful Post: |
04-24-2017, 11:31 | #2 (permalink) |
Member: 2561651 Status: Offline Sonork: 100.******* Thanks Meter: 292 | HERE,S THE ALL OPERATION LOG,S INFO : 4/24/2017 2:48:47 PM > Selected firmware file: COMBINATION_FAC_FA51_A510FXXU3API1_FAC_CL9213193_Q B10877732.oct WARN : 4/24/2017 2:49:02 PM > Please put the phone into Download Mode and connect USB cable. WARN : 4/24/2017 2:49:02 PM > To put SM-A510F into Download Mode, You have to perform the following steps: WARN : 4/24/2017 2:49:02 PM > 1. Reconnect the battery. WARN : 4/24/2017 2:49:02 PM > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 4/24/2017 2:49:02 PM > 3. When phone turns on, press "Volume+" key. INFO : 4/24/2017 2:49:03 PM > Found phone on WARN : 4/24/2017 2:49:03 PM > Advanced mode! INFO : 4/24/2017 2:49:19 PM > Firmware write started. INFO : 4/24/2017 2:49:19 PM > Writing BOOTLOADER section... INFO : 4/24/2017 2:49:21 PM > BOOTLOADER section has been written successfully. INFO : 4/24/2017 2:49:21 PM > Writing BOOT section... INFO : 4/24/2017 2:49:24 PM > BOOT section has been written successfully. INFO : 4/24/2017 2:49:24 PM > Firmware writing successfully completed. INFO : 4/24/2017 2:49:24 PM > Performed by 2.5.1 Software version. WARN : 4/24/2017 2:50:31 PM > Please put the phone into Download Mode and connect USB cable. WARN : 4/24/2017 2:50:32 PM > To put SM-A510F into Download Mode, You have to perform the following steps: WARN : 4/24/2017 2:50:32 PM > 1. Reconnect the battery. WARN : 4/24/2017 2:50:32 PM > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 4/24/2017 2:50:32 PM > 3. When phone turns on, press "Volume+" key. INFO : 4/24/2017 2:50:32 PM > Found phone on WARN : 4/24/2017 2:50:32 PM > Advanced mode! INFO : 4/24/2017 2:50:33 PM > Firmware write started. INFO : 4/24/2017 2:50:33 PM > Writing BOOTLOADER section... INFO : 4/24/2017 2:50:36 PM > BOOTLOADER section has been written successfully. ERROR : 4/24/2017 2:50:36 PM > Writing Firmware Failed INFO : 4/24/2017 2:50:36 PM > Performed by 2.5.1 Software version. WARN : 4/24/2017 2:51:32 PM > Please put the phone into Download Mode and connect USB cable. WARN : 4/24/2017 2:51:32 PM > To put SM-A510F into Download Mode, You have to perform the following steps: WARN : 4/24/2017 2:51:32 PM > 1. Reconnect the battery. WARN : 4/24/2017 2:51:32 PM > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 4/24/2017 2:51:32 PM > 3. When phone turns on, press "Volume+" key. INFO : 4/24/2017 2:51:32 PM > Found phone on WARN : 4/24/2017 2:51:32 PM > Advanced mode! INFO : 4/24/2017 2:51:34 PM > Firmware write started. INFO : 4/24/2017 2:51:34 PM > Writing BOOTLOADER section... INFO : 4/24/2017 2:51:36 PM > BOOTLOADER section has been written successfully. INFO : 4/24/2017 2:51:36 PM > Writing PARAM section... INFO : 4/24/2017 2:51:38 PM > PARAM section has been written successfully. INFO : 4/24/2017 2:51:38 PM > Writing CM section... INFO : 4/24/2017 2:51:40 PM > CM section has been written successfully. INFO : 4/24/2017 2:51:41 PM > Writing BOOT section... INFO : 4/24/2017 2:51:43 PM > BOOT section has been written successfully. INFO : 4/24/2017 2:51:43 PM > Writing RECOVERY section... INFO : 4/24/2017 2:51:46 PM > RECOVERY section has been written successfully. INFO : 4/24/2017 2:51:46 PM > Writing SYSTEM section... INFO : 4/24/2017 2:52:50 PM > SYSTEM section has been written successfully. INFO : 4/24/2017 2:52:50 PM > Writing PERSDATA section... INFO : 4/24/2017 2:52:52 PM > PERSDATA section has been written successfully. INFO : 4/24/2017 2:52:52 PM > Writing RADIO section... INFO : 4/24/2017 2:52:57 PM > RADIO section has been written successfully. INFO : 4/24/2017 2:52:57 PM > Writing CACHE section... INFO : 4/24/2017 2:52:59 PM > CACHE section has been written successfully. INFO : 4/24/2017 2:52:59 PM > Firmware writing successfully completed. INFO : 4/24/2017 2:52:59 PM > Performed by 2.5.1 Software version. INFO : 4/24/2017 2:54:44 PM > ----------------------------------------------------------------------------------- INFO : 4/24/2017 2:54:45 PM > Platform: Samsung Android INFO : 4/24/2017 2:54:45 PM > Selected port: COM5 INFO : 4/24/2017 2:54:45 PM > Selected model: SM-A510F WARN : 4/24/2017 2:54:47 PM > Connecting to server... INFO : 4/24/2017 2:54:52 PM > Connecting to server...Ok! INFO : 4/24/2017 2:54:52 PM > Checking resource files... INFO : 4/24/2017 2:54:57 PM > Downloading resources... INFO : 4/24/2017 2:56:52 PM > All necessary resource files have been downloaded successfully. WARN : 4/24/2017 2:56:52 PM > Please put the phone into Download Mode and connect USB cable. WARN : 4/24/2017 2:56:54 PM > To put SM-A510F into Download Mode, You have to perform the following steps: WARN : 4/24/2017 2:56:54 PM > 1. Reconnect the battery. WARN : 4/24/2017 2:56:54 PM > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 4/24/2017 2:56:54 PM > 3. When phone turns on, press "Volume+" key. INFO : 4/24/2017 2:56:54 PM > Waiting for phone... INFO : 4/24/2017 2:57:43 PM > Firmware write started. INFO : 4/24/2017 2:57:43 PM > Writing Boot section... INFO : 4/24/2017 2:57:46 PM > Boot section has been written successfully. INFO : 4/24/2017 2:57:46 PM > Searching for a phone (waiting for ADB device)... INFO : 4/24/2017 2:58:21 PM > Reading info... ERROR : 4/24/2017 2:58:23 PM > Proper android device not found. Make shure that "USB debug" option on the device is turned on. ERROR : 4/24/2017 2:58:23 PM > Proper android device not found. Make shure that "USB debug" option on the device is turned on. INFO : 4/24/2017 2:58:23 PM > Resetting FRP lock.. WARN : 4/24/2017 2:58:41 PM > FRP lock is successfully reseted! BINF : 4/24/2017 2:58:41 PM > Goto "Menu->Settings->Backup and reset" and make "Factory data reset" INFO : 4/24/2017 2:58:41 PM > Performed by 2.5.1 Software version. INFO : 4/24/2017 3:02:40 PM > Selected AP file: C:\Users\Ale\Desktop\A510FXXS3BPI8_A510FOXX3BPI1_A 510FXXS3BPI1_HOME.tar.md5 WARN : 4/24/2017 3:02:41 PM > Please put the phone into Download Mode and connect USB cable. WARN : 4/24/2017 3:02:41 PM > To put SM-A510F into Download Mode, You have to perform the following steps: WARN : 4/24/2017 3:02:41 PM > 1. Reconnect the battery. WARN : 4/24/2017 3:02:41 PM > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 4/24/2017 3:02:41 PM > 3. When phone turns on, press "Volume+" key. INFO : 4/24/2017 3:02:41 PM > Found phone on WARN : 4/24/2017 3:02:41 PM > Advanced mode! INFO : 4/24/2017 3:02:43 PM > Firmware write started. INFO : 4/24/2017 3:02:43 PM > Writing BOOT section... INFO : 4/24/2017 3:02:46 PM > BOOT section has been written successfully. INFO : 4/24/2017 3:02:46 PM > Writing CACHE section... INFO : 4/24/2017 3:02:53 PM > CACHE section has been written successfully. INFO : 4/24/2017 3:02:53 PM > Writing CM section... INFO : 4/24/2017 3:02:55 PM > CM section has been written successfully. INFO : 4/24/2017 3:02:55 PM > Writing HIDDEN section... INFO : 4/24/2017 3:02:57 PM > HIDDEN section has been written successfully. INFO : 4/24/2017 3:02:57 PM > Writing RADIO section... INFO : 4/24/2017 3:03:01 PM > RADIO section has been written successfully. INFO : 4/24/2017 3:03:01 PM > Writing RECOVERY section... INFO : 4/24/2017 3:03:05 PM > RECOVERY section has been written successfully. INFO : 4/24/2017 3:03:05 PM > Writing BOOTLOADER section... INFO : 4/24/2017 3:03:07 PM > BOOTLOADER section has been written successfully. INFO : 4/24/2017 3:03:07 PM > Writing SYSTEM section... INFO : 4/24/2017 3:05:02 PM > SYSTEM section has been written successfully. INFO : 4/24/2017 3:05:02 PM > Firmware writing successfully completed. INFO : 4/24/2017 3:05:02 PM > Performed by 2.5.1 Software version. |
The Following 2 Users Say Thank You to .:D:. For This Useful Post: |
