04-15-2015, 08:19 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Age: 57
Member: 137980 Status: Offline Thanks Meter: 168 | after repair imei now base band unkown imei null Welcome to Octoplus/Octopus Box Samsung software version 1.9.0 ----------------------------------------------------------------------------------- To connect SM-N900T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect GT-N7100 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Connect usb cable to phone. 6. Go to dial window. 7. Enter *#9090# number. 8. Set speed to 115200. 9. Go to dial window. 10. Enter "*#7284#" number. 11. Set "UART" radio button to "MODEM" value. 12. Set "USB" radio button to "PDA" value 13. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM11 Selected model: GT-N7100 ADB server killed. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Write IMEI failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM33 Selected model: GT-N7100 Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: GT-N7100 Firmware compiled date: Tue May 6 16:41:13 KST 2014 PDA version: N7100XXUFNE1 CSC version: N7100ODDFNE1 SW version: N7100DDDMG1 Phone IMEI: 004999010640000 Phone SN: RF1D831NN3F Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-GT-N7100-Unknown15-04-2015_12-40-50-.asec file Cheking security type... New security type is detected Old IMEI: 004999-01-064000-0 New IMEI: 356555-05-068674-3 Repairing IMEI ... Executing exploit... Exploit has been executed successfully Repairing network. Please wait, this can take some time... Network is successfully repaired Phone will restart now. Please don't disconnect cable! IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) |
04-15-2015, 08:30 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Do the next: 1. Re-flash the phone. 2. Make Repair EFS. 3. Write one of the service IMEIs from the Software list (not any IMEI, that You want). To finish the "Repair IMEI" operation, restart the phone via phone's menu (via "Power ON" button, don't disconnect the battery, this is important). 4. Write Firmware again. 5. Post here the result. |
