04-14-2015, 06:29 | #1 (permalink) |
No Life Poster Join Date: Apr 2012 Location: Black Market Age: 39
Member: 1744748 Status: Offline Thanks Meter: 752 | Android 5.0 - S5 & Note 4 variants Wipe Efs via menu. connect via UART cable Tape the battery... Write Imei with Ocotpus Box -- Manual select com port.... Have done more than 10 phones using this technique.... really hoping usb solution would be available soon.... For note 4 - you would have to restore nv items to repair network.... N910W8 Model - on 5.0.1 INFO : 4/7/2015 1:55:01 PM > Platform: Samsung Android INFO : 4/7/2015 1:55:01 PM > Selected port: COM218 INFO : 4/7/2015 1:55:01 PM > Selected model: SM-N910A INFO : 4/7/2015 1:57:32 PM > Selected file: I:\Certifications \SM-N910xx_3545xxxxxxxxx - Octopus.cert WARN : 4/7/2015 1:57:33 PM > Powered on perform the following steps: WARN : 4/7/2015 1:57:33 PM > 1. Connect phone via UART cable to the Box. WARN : 4/7/2015 1:57:33 PM > 2. Note: phone screen must be active INFO : 4/7/2015 1:57:33 PM > Connecting to phone, please wait... INFO : 4/7/2015 1:57:38 PM > Found phone on COM218 INFO : 4/7/2015 1:57:38 PM > Phone connected successfully INFO : 4/7/2015 1:57:38 PM > Checking Certificate file... INFO : 4/7/2015 1:57:38 PM > Certificate file successfully checked INFO : 4/7/2015 1:57:38 PM > Writing new phone IMEI... INFO : 4/7/2015 1:57:50 PM > Checking certificate compatibility... INFO : 4/7/2015 1:57:50 PM > Certificate is compatible INFO : 4/7/2015 1:57:50 PM > Writing Certificate... INFO : 4/7/2015 1:57:58 PM > Certificate has been written successfully INFO : 4/7/2015 1:57:58 PM > Please, restart the phone to apply changes Galaxy S5 G900W8 Model - 5.0 - INFO : 4/6/2015 7:20:36 PM > Platform: Samsung Android INFO : 4/6/2015 7:20:36 PM > Selected port: COM218 INFO : 4/6/2015 7:20:36 PM > Selected model: SM-G900W8 INFO : 4/6/2015 7:20:40 PM > Selected file: I:\Certifications \SM-G900W8 cert - 35xxxxxxxxxxxxx.cert WARN : 4/6/2015 7:20:43 PM > Powered on perform the following steps: WARN : 4/6/2015 7:20:43 PM > 1. Connect phone via UART cable to the Box. WARN : 4/6/2015 7:20:43 PM > 2. Note: phone screen must be active INFO : 4/6/2015 7:20:43 PM > Connecting to phone, please wait... INFO : 4/6/2015 7:20:48 PM > Found phone on COM218 INFO : 4/6/2015 7:20:48 PM > Phone connected successfully INFO : 4/6/2015 7:20:48 PM > Checking Certificate file... INFO : 4/6/2015 7:20:48 PM > Certificate file successfully checked INFO : 4/6/2015 7:20:48 PM > Writing new phone IMEI... INFO : 4/6/2015 7:20:59 PM > Checking certificate compatibility... INFO : 4/6/2015 7:20:59 PM > Certificate is compatible INFO : 4/6/2015 7:21:00 PM > Writing Certificate... INFO : 4/6/2015 7:21:07 PM > Certificate has been written successfully INFO : 4/6/2015 7:21:07 PM > Please, restart the phone to apply changes |
The Following 9 Users Say Thank You to ysr84 For This Useful Post: |
04-14-2015, 11:53 | #3 (permalink) |
Banned Join Date: Mar 2015
Member: 2371548 Status: Offline Thanks Meter: 27 | If you are wiping the efs files via service menu no need to root. Writing cert via uart and writing the qcn do not require root. I am for sure now that the reason we cannot write certs via usb is because lollipop creates a new EFS version (just like when phones went from 4.1.2/4.2.2 to 4.3) and that new efs version can only be read by lollipop modems. Until we can figure out the new format/security of the new efs verison writing certs via usb will not be possible..that is why both z3x and octopus cannot read the imei from the phone. |
The Following 4 Users Say Thank You to iowahawk For This Useful Post: |
04-14-2015, 15:05 | #4 (permalink) | |
Freak Poster Join Date: Jan 2005 Age: 45
Member: 107932 Status: Offline Thanks Meter: 21 | Quote:
04-14-2015, 16:48 | #5 (permalink) |
Member: 1744748 Status: Offline Thanks Meter: 752 | Don't worry what Octopus is saying plug in your UART cable ... don't forget to tape the Battery.... and profit... |
The Following User Says Thank You to ysr84 For This Useful Post: |
04-14-2015, 23:56 | #7 (permalink) |
Insane Poster Join Date: Sep 2010
Member: 1390160 Status: Offline Thanks Meter: 8 | Did all the steps but not working: Platform: Samsung Android Selected port: COM4 Selected model: SM-G900A Selected file: Cert-SM-G900A_XXXXXXXXXXXXXXX_00000000000 cert Proper android device not found. Make shure that "USB debug" option on the device is turned on. Certificate has been written successfully Please, restart the phone to apply changes Now the computer won't see the device (tried two different computers) |
04-15-2015, 03:15 | #8 (permalink) | |
Member: 1744748 Status: Offline Thanks Meter: 752 | Quote:
use Octopus verysion 1.81 and select model N910A always works for me... | |
04-15-2015, 03:17 | #9 (permalink) |
Member: 1744748 Status: Offline Thanks Meter: 752 | Manual select and tape the battery terminal.... use Octopus verysion 1.81 and select model N910A always works for me... |
04-15-2015, 11:02 | #11 (permalink) |
Member: 107932 Status: Offline Thanks Meter: 21 | Tested working solution thank you ysr84. Platform: Samsung Android Selected port: COM6 Selected model: SM-N910A Selected file: C:\Users\Todd\Desktop\Cert-SM-G900A_ 3531100XXXXXXXX.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Found phone on COM6 Phone connected successfully Checking Certificate file... Certificate file successfully checked Writing new phone IMEI... Checking certificate compatibility... Certificate is compatible Writing Certificate... Certificate has been written successfully Please, restart the phone to apply changes Last edited by aya186; 04-15-2015 at 11:11. |
The Following User Says Thank You to aya186 For This Useful Post: |
04-15-2015, 14:29 | #13 (permalink) | |
04-15-2015, 15:53 | #14 (permalink) |
Member: 1390160 Status: Offline Thanks Meter: 8 | Thanks ysr84 That worked like a charm, even on 1.9.2! Platform: Samsung Android Selected port: COM1 Selected model: SM-N910A Selected file: C:\Users\tigueraje\Downloads\Octoplus\Cert-SM-G900A_XXXXXXXXXXXXXXX_00000000000 cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Found phone on COM13 Phone connected successfully Checking Certificate file... Certificate file successfully checked Writing new phone IMEI... Checking certificate compatibility... Certificate is compatible Writing Certificate... Certificate has been written successfully Please, restart the phone to apply changes |
04-15-2015, 22:01 | #15 (permalink) |
Freak Poster Join Date: May 2010
Member: 1298793 Status: Offline Thanks Meter: 21 | greeting, i have the same phone , i already clean imei for some reason i have chosen mode sm-n910a and sm-n910t and phone is not connecting via uart. in orde to write cert file . can you give me a hint . |
