04-17-2015, 16:27 | #1 (permalink) |
No Life Poster Join Date: Feb 2004 Location: PaKiStAn Age: 44
Member: 51639 Status: Offline Thanks Meter: 76 | Bug or something other problem Octopus team Selected port: COM250 Selected model: SGH-T889 Reading info, please wait... Detected phone model: SGH-T889 Firmware compiled date: Tue Nov 19 16:58:51 KST 2013 PDA version: T889UVUCMK7 CSC version: T889TMBCMK7 SW version: T889UVUCMK7 Phone IMEI: 354212050796484 Phone SN: RV1CA7FDVCB Android version: 4.3 (JSS15J) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM250 Selected model: SGH-T889 Reading info... Phone was not found on the selected port! Reading QCN failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM250 Selected model: SGH-T889 Reading info... Phone was not found on the selected port! Writing QCN failed Model SGH-T889 can not be detected in Main Tab nor in IMEI tab but can be detected in android/efs tab but cannot do any thing like qcn efs etc in IMEI tab you cannot read the phone but you can change imei which usually stuck after UART connection (may be driver problem) |
04-17-2015, 16:42 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | To connect SGH-T889 phone, you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "MODEM" value. 8. Go to "Qualcomm USB Settings". 9. Select "DM+MODEM+ADB". 10. Press Home button. 11. Go to dial window. 12. Enter "*#9090#" number. 13. Select "DM/UM over HS-USB". 14. Restart phone. 15. Press "Read Info" buttton at the "Main" tab in the Software. Also, try to select correct COM port manually ans read info. |
