Which cert compatible with G850W ? Hi, Is the G850F cert in support area compatible with G850W thanks |
Hello. Yes, You can try to write this IMEI Certificate. |
I did is not compatible the cert ! too bad ! |
Post here full Software log with Write Cert procedure. |
INFO : 2015/01/21 15:20:52 > Platform: Samsung Android INFO : 2015/01/21 15:20:53 > Selected port: COM228 INFO : 2015/01/21 15:20:53 > Selected model: SM-G870A INFO : 2015/01/21 15:21:09 > Selected file: C:\g850f\Cert-SM-G850F-355210060328784-RF8F90BLAFZ.cert INFO : 2015/01/21 15:21:10 > Detected phone model: SM-G850W INFO : 2015/01/21 15:21:10 > Firmware compiled date: Wed Sep 17 12:51:18 KST 2014 INFO : 2015/01/21 15:21:11 > PDA version: G850WVLU1ANI4 INFO : 2015/01/21 15:21:11 > CSC version: G850WOYA1ANI4 INFO : 2015/01/21 15:21:12 > SW version: G850WVLU1ANI4 INFO : 2015/01/21 15:21:13 > Phone IMEI: Unknown INFO : 2015/01/21 15:21:13 > Phone SN: R38FA0015VD INFO : 2015/01/21 15:21:13 > Android version: 4.4.4 (KTU84P) INFO : 2015/01/21 15:21:14 > Checking Root: INFO : 2015/01/21 15:21:14 > Phone is Rooted. INFO : 2015/01/21 15:21:14 > Checking Certificate file... INFO : 2015/01/21 15:21:14 > Certificate file successfully checked INFO : 2015/01/21 15:21:14 > Writing Certificate... INFO : 2015/01/21 15:21:14 > Phone connected successfully INFO : 2015/01/21 15:21:14 > Writing new phone IMEI... INFO : 2015/01/21 15:21:56 > Checking certificate compatibility... ERROR : 2015/01/21 15:21:56 > Certificate is not compatible INFO : 2015/01/21 15:21:56 > Writing Certificate... WARN : 2015/01/21 15:23:01 > Phone will restart now. Please don't disconnect cable! INFO : 2015/01/21 15:23:01 > Certificate has been written successfully INFO : 2015/01/21 15:23:01 > Please, restart the phone to apply changes |
After operation cert fail when dial *#0011# and emergency call only Thanks |
As You can see in your Software log, You have selected incorrect model: Quote:
Ask mr. ysr84 here: http://forum.gsmhosting.com/vbb/f684...-cert-1905688/, maybe, he can give You his IMEI Certificate file for SM-G850W, and write it. |
