04-17-2015, 09:05 | #1 (permalink) |
No Life Poster Join Date: Apr 2013 Location: Ordu TÜRKİYE
Member: 1918391 Status: Offline Thanks Meter: 73 | E1205Y repair not work Welcome to Octoplus/Octopus Box Samsung software version 1.9.2 ----------------------------------------------------------------------------------- Platform: Samsung Spreadtrum Selected port: COM4 Selected model: GT-E1205Y Selected port: USB To connect GT-E1205Y, perform the following steps: 1. Disconnect phone's battery. 2. Press and hold central button and connect the USB cable. 3. Connect the battery. Connecting... Phone found. Sending mainloader... Mainloader send successfully Reading NV section section... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\Security-GT-E1205Y_17-04-2015_10-57-14-.nv file Repairing IMEI. Please wait... IMEI successfully repaired. ----------------------------------------------------------------------------------- Platform: Samsung Spreadtrum Selected port: COM4 Selected model: GT-E1205Y Selected port: USB To connect GT-E1205Y, perform the following steps: 1. Disconnect phone's battery. 2. Press and hold central button and connect the USB cable. 3. Connect the battery. Connecting... Phone found. Sending mainloader... Mainloader send successfully Reading NV section section... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\Security-GT-E1205Y_17-04-2015_11-00-51-.nv file Repairing IMEI. Please wait... IMEI successfully repaired. cant repair. |
04-17-2015, 09:10 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | What is the IMEI now in the phone exactly? The propblemn can be with phone's firmware. Please read out Full flash from the phone ("Read FullFlash" buton in the Software), upload it somewhere and post here link, we will research and try to prepare test Software version for You. Also, try to write Full flash from the Support Area and then make Repair IMEI. Write here the result. |
04-17-2015, 09:24 | #3 (permalink) |
Member: 1918391 Status: Offline Thanks Meter: 73 | Bin:e1205yjvnb2 csc:e1205yojvnb2 turkish turkce full flash http://www.filedropper.com/e1205yjvn...ojvnb2octoplus needed this fw's repair solution because languages different |
04-17-2015, 09:26 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | OK, we will research. What is the IMEI now in the phone exactly? Is it correct or danaged? Also, try to write Full flash from the Support Area and then make Repair IMEI. Post here the result. |
04-17-2015, 09:44 | #7 (permalink) |
Member: 1918391 Status: Offline Thanks Meter: 73 | ----------------------------------------------------------------------------------- Platform: Samsung Spreadtrum Selected port: COM4 Selected model: GT-E1205Y Selected port: USB To connect GT-E1205Y, perform the following steps: 1. Disconnect phone's battery. 2. Press and hold central button and connect the USB cable. 3. Connect the battery. Connecting... Phone found. Sending mainloader... Mainloader send successfully Writing Full Flash Full Flash write successfully ----------------------------------------------------------------------------------- Platform: Samsung Spreadtrum Selected port: COM4 Selected model: GT-E1205Y Selected port: USB To connect GT-E1205Y, perform the following steps: 1. Disconnect phone's battery. 2. Press and hold central button and connect the USB cable. 3. Connect the battery. Connecting... Phone found. Sending mainloader... Mainloader send successfully Reading NV section section... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\Security-GT-E1205Y_17-04-2015_11-41-29-.nv file Repairing IMEI. Please wait... IMEI successfully repaired. repair working this flash file GT-E1205Y_FullFlash.ful succesfull. |
04-17-2015, 09:46 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Ok, thanks for report. We will research your Full flash, why IMEI was not repaired with it, and say You the result. |
04-18-2015, 20:21 | #9 (permalink) |
Member: 1918391 Status: Offline Thanks Meter: 73 | E1205YJVNB2 - Download - 4shared - celal ata? Here orginal flash file if problem sloved please add support files |
08-04-2015, 12:01 | #10 (permalink) |
Member: 1918391 Status: Offline Thanks Meter: 73 | problem not sloved. same as more than 20 phones not repairing wirite nv fail Platform: Samsung Spreadtrum Selected port: COM235 Selected model: GT-E1205Y Selected port: USB To connect GT-E1205Y, perform the following steps: 1. Disconnect phone's battery. 2. Press and hold central button and connect the USB cable. 3. Connect the battery. Connecting... Phone found. Sending mainloader... Mainloader send successfully Reading NV section section... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung\BACKUP\Security-GT-E1205Y_04-08-2015_14-04-13-.nv file Repairing IMEI. Please wait... Write IMEI failed Platform: Samsung Spreadtrum Selected port: COM235 Selected model: GT-E1205Y Selected port: USB To connect GT-E1205Y, perform the following steps: 1. Disconnect phone's battery. 2. Press and hold central button and connect the USB cable. 3. Connect the battery. Connecting... Phone found. Sending mainloader... Mainloader send successfully Firmware write started. Writing BOOT section... BOOT section has been written successfully. Writing PS section... PS section has been written successfully. Writing CSC section... Writing Firmware Failed |
08-04-2015, 12:17 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please install latest Software version and try to perform "Repair IMEI" operation again. If problem remains the same - close the Software and upload latest *.log and *.logx files from "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG" folder. Post here download link, we will check where might be the problem. |
08-12-2015, 11:11 | #12 (permalink) |
Member: 1918391 Status: Offline Thanks Meter: 73 | and today again i cant repair 1205y. Here logs not work fullflash and other solutions. https://mega.nz/#!to8FmRIJ!Bb4uxLyCp...OrvRodEoRpNup0 |
08-18-2015, 09:29 | #13 (permalink) |
Member: 1918391 Status: Offline Thanks Meter: 73 | I must be stupid. im already have spd tool. already using other china phones. with same driver. i m not any try orginal samsung phone. method working. problem resloved by official tool. (writeimei R1.5.9.1) phone on. and spd diag port driver installed (1.5.6.1) windows 7 and 10 tested working with all firimwares |
