04-18-2016, 00:42 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Santiago de Cuba Age: 46
Member: 220595 Status: Offline Thanks Meter: 355 | G360F, emergency calls only. After properly repairing necessary regions. wipe EFS, Write CERt , write QCN, the phone always shows emergency calls only. Imei CERT is ok, says Pass. I noticed I can use a roaming mode SImc ard, I mean, a foreign Sim card will connect, but now a home Sim card, even though both sim cards will use the only nationwide network available here. any idea? |
04-18-2016, 11:04 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. mr.raulka2003 and mr.KGM-peshawar are right, IMEI of Cert file, which You've used might be in provider's "black" list. Try to write another Cert file. |
04-18-2016, 16:05 | #5 (permalink) | |
Member: 220595 Status: Offline Thanks Meter: 355 | Quote:
It must be something else, with a foreign sim cats it works, so if it's not a hardware issue Enviado desde mi SM-N920T mediante Tapatalk | |
04-18-2016, 16:12 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to reflash the phone, then try to find and select Network manually. If problem will remain - read out QCN from another SM-G360F, which works correctly in your region and try to use it for your phone. |
04-18-2016, 17:36 | #9 (permalink) | |
04-18-2016, 17:52 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | We recommended to read QCN of another phone, not Cert file. If IMEI of Cert file, which You've used, is not blacklisted - no need to write another Cert file. |
04-18-2016, 18:11 | #12 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | Am not sure if cert file is blacklisted or not, there is no way to be sure. I will have to find first a cert file which am sure is not blacklisted. I have writen some QCN and get the same result. I but there is something rar or different in the QCN I have written and the baseband in the phone. I will post the differences shortly. it is about the QCN file Name and the name in the phone is modem, as read with the octopus software. |
04-19-2016, 19:31 | #13 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | most QCN I find are like this: MPSS.DPM.2.0.c5-00018-M8936FAAAANUZM But this phone reports: MPSS.DPM.2.0.2.c1.7-00014-M8936FAAAANUZM-1 maybe this means something and maybe not but I would like to try a QCN matching 2.0.2.c1.7 |
04-26-2016, 17:11 | #14 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | Today I saw a similar phone g360gy and I checked *#0011# and noticed before the last line MIPI is different to the one I want to fix Look the image And here is the phone I wanna fix There is an unknown line, does it means something? Enviado desde mi SM-N920T mediante Tapatalk |
