04-16-2016, 16:18 | #1 (permalink) |
No Life Poster Join Date: May 2014
Member: 2195211 Status: Offline Thanks Meter: 4,294,967,295 | G530H no service solution ----------------------------------------------------------------------------------- To connect SM-G530H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G530H Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM256 Mode: Normal Phone model: SM-G530H Firmware compiled date: Dec 23 2014 Firmware compiled time: 12:00:00 Firmware released date: Jan 14 2015 Firmware released time: 15:44:17 Phone IMEI: 357214-06-140261-2 SW version: MPSS.DPM.1.0.c7.1-00074-M8916EAAAANVZM-1 Performed by 2.2.4 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM256 Selected model: SM-G530H Reading info... Mode: Normal Firmware compiled date: Dec 23 2014 Firmware compiled time: 12:00:00 Firmware released date: Jan 14 2015 Firmware released time: 15:44:17 SW Version: MPSS.DPM.1.0.c7.1-00074-M8916EAAAANVZM-1 Unlocking phone... Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu. Performed by 2.2.4 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM256 Selected model: SM-G530H Reading info... Mode: Normal Firmware compiled date: Dec 23 2014 Firmware compiled time: 12:00:00 Firmware released date: Jan 14 2015 Firmware released time: 15:44:17 SW Version: MPSS.DPM.1.0.c7.1-00074-M8916EAAAANVZM-1 Send SPC... SPC send successfully Writing QCN... Writing NV items... NV items write successfully Writing NV SIM1 items... NV SIM1 items write successfully Wrting EFS... EFS write successfully Writing provisioning items... Provisioning items write successfully. Writing QCN done QCN write successfully Please, restart the phone to apply changes Performed by 2.2.4 software version IMEI IS OK BUT ON BOTH SIMS THERE IS NO SERVICE |
04-18-2016, 11:08 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to reflash the phone, then try to find and select Network manually. If problem will remain - read out QCN from another SM-G530H, which works correctly in your region and try to write it into your phone. |
