04-20-2015, 10:23 | #1 (permalink) |
No Life Poster Join Date: Jul 2009 Location: chandigarh INDIA
Member: 1066865 Status: Offline Thanks Meter: 593 | g900h reset screenlock done ( but still locked ) 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Firmware write started. Writing Recovery section... Recovery section has been written successfully. Please, put the phone into Recovery Mode and connect USB cable. To put SM-G900H into Recovery Mode, please, perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume+" + "Home" + "Power ON" keys. 3. Release the "Power ON" key when the Samsung logo appears. Searching for a phone. Please wait... Can't kill external ADB references. Please, close all programs that use ADB server. Preparing phone.. Resetting Screen Lock... Reset Screen Lock successfully completed. To unlock screen please input any password or pattern! ----------------------------------------------------------------------------------- need help |
04-20-2015, 12:17 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Disconnect all other devices from PC, re-boot the PC and try to repeat the operation once again. If this will not help - only Factory reset will help to reset "Screen Lock" in this device. |
04-20-2015, 13:43 | #5 (permalink) |
Freak Poster Join Date: Aug 2009 Location: NYC
Member: 1105429 Status: Offline Thanks Meter: 118 | Does the phone needs to be rooted or if ADB must be on to remove the passcode? sometimes that we need to remove the password will not be rooted or adb enabled. will that still work? |
04-20-2015, 14:01 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | In order, to perform "Reset Screen Lock" operation for SM-G900H, You need to switch the phone to Download Mode and connect it directly to PC via micro USB cable. Additional configuration is not required. |
