04-24-2016, 22:32 | #1 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Mor
Member: 1006514 Status: Offline Thanks Meter: 640 | G928F 6.0.1 FRP done 1st download this file { SBOOT_G928F_OJ5.oct } from support and flash it phone will hang on samsung don't worry 2nd put it on download mode and reset FRP, phone will not boot up so don't worry again 3th download { g928fxxu2aoj5_g928feur2aoj2_eur_android_5.1.1.oct } and flash it. last step is to do a hard reset and voila your phone is working without any problem and you can update to the last version if you want. I posted this because many users are afraid of downgrading their phone. Code: Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Firmware writing successfully completed. Performed by 2.2.4 software version Code: Phone found. Initializing.. Resetting FRP lock..success Resetting EE lock..success Resetting Samsung Account lock..success Reset operation completed! Performed by 2.2.4 software version Code: Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Firmware writing successfully completed. Performed by 2.2.4 software version Selected firmware file: g928fxxu2aoj5_g928feur2aoj2_eur_android_ 5.1.1.oct Please put the phone into Download Mode and connect USB cable. To put SM-G928F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing CM section... CM section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. Performed by 2.2.4 software version |
The Following User Says Thank You to mrx3net For This Useful Post: |
04-25-2016, 10:51 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Thanks for good report! @nbkappa, You can use "SBOOT_G928F_OJ5" SBoot file in cases, when phone has one of the latest firmwares, which causes issues with removal of FPR lock. |
The Following 2 Users Say Thank You to Octopus box For This Useful Post: |
06-14-2016, 08:17 | #4 (permalink) |
Major Poster Join Date: Apr 2005 Location: iasi romania Age: 47
Member: 132859 Status: Offline Thanks Meter: 4 | i want to share with you what i did 1st download this file { SBOOT_G928F_OJ5.oct } from support and flash it phone will hang on samsung don't worry 2nd put it on download mode and reset FRP, phone will not boot up so don't worry again 3th download { g928fxxu2aoj5_g928feur2aoj2_eur_android_5.1.1.oct } and flash it. last step is to do a hard reset and voila your phone is working without any problem and you can update to the last version if you want. I posted this because many users are afraid of downgrading their phone. yes working...... tested |
The Following User Says Thank You to emygsm For This Useful Post: |
08-17-2016, 18:51 | #6 (permalink) |
Insane Poster Join Date: Feb 2006
Member: 237887 Status: Offline Thanks Meter: 6 | very simple solution with g928f 6.0.1 is to - flash it with this SBOOT_G928F_OJ5.oct phone hangs on logo dont worry!t - Reset FRp with octoplus when done phone restarts but hangs again - Now flash it with firmware 6.0.1 with odin or octoplus. all will be ok tested by me |
10-01-2016, 18:53 | #15 (permalink) |
Junior Member Join Date: Feb 2010 Location: in my house Age: 39
Member: 1225627 Status: Offline Sonork: papach Thanks Meter: 0 | wen i write sboot Welcome to Octoplus/Octopus Box Samsung software version 2.3.0 ----------------------------------------------------------------------------------- To connect SM-G928F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Please, select firmware file first! Selected firmware file: combination_g928f_g928fxxu1aol2_boot.oct Please put the phone into Download Mode and connect USB cable. To put SM-G928F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOT section... BOOT section has been written successfully. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing Firmware Failed Performed by 2.3.0 software version Selected firmware file: SBOOT_G928F_OJ5.oct Please put the phone into Download Mode and connect USB cable. To put SM-G928F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Writing firmware Canceled Performed by 2.3.0 software version Selected firmware file: combination_g928f_g928fxxu1aol2_boot.oct Please put the phone into Download Mode and connect USB cable. To put SM-G928F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOT section... BOOT section has been written successfully. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing Firmware Failed Performed by 2.3.0 software version Selected firmware file: SBOOT_G928F_OJ5.oct Please put the phone into Download Mode and connect USB cable. To put SM-G928F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing Firmware Failed Performed by 2.3.0 software version Selected firmware file: combination_g928f_g928fxxu1aol2_boot.oct Please put the phone into Download Mode and connect USB cable. To put SM-G928F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOT section... BOOT section has been written successfully. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing Firmware Failed Performed by 2.3.0 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G928F To put SM-G928F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock..success Resetting EE lock..success Resetting Samsung Account lock..success Operation was failed! Performed by 2.3.0 software version Selected firmware file: SBOOT_G928F_OJ5.oct Please put the phone into Download Mode and connect USB cable. To put SM-G928F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing Firmware Failed Performed by 2.3.0 software version |
