11-10-2016, 11:30 | #1 (permalink) |
No Life Poster Join Date: May 2001 Location: U.K Age: 54
Member: 4611 Status: Offline Thanks Meter: 68 | g935f firmware problems (bricked) [Solved] Dm-verity failure is also now showing. the phones turns on, but then goes straight to recovery... Any ideas please before my customer comes into the store? Last edited by Octopus box; 11-12-2016 at 12:45. |
11-10-2016, 11:48 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Try to write "g935fxxu1apd1_g935fodd1apba_bng_android_6.0.1 " firmware from the Support Area and post here the result. |
11-10-2016, 11:57 | #3 (permalink) |
Member: 4611 Status: Offline Thanks Meter: 68 | I'll download it again and have another go.. From last time I downloaded it for this phone.. It said something along the lines of "not for tihs model" or similar.. maybe the file was corrupt via download.. downloading it again now. |
11-10-2016, 14:14 | #4 (permalink) |
Member: 4611 Status: Offline Thanks Meter: 68 | Selected firmware file: g935fxxu1apd1_g935fodd1apba_bng_android_ 6.0.1.oct Please put the phone into Download Mode and connect USB cable. To put SM-G935F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on File has been created for a different phone model. Performed by 2.4.1 Software version. Flashing any other file results in Welcome to Octoplus/Octopus Box Samsung software version 2.4.1 ----------------------------------------------------------------------------------- To connect SM-G935F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected firmware file: g935fxxu1apd1_g935fodd1apba_bng_android_ 6.0.1.oct Please put the phone into Download Mode and connect USB cable. To put SM-G935F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on File has been created for a different phone model. Performed by 2.4.1 Software version. Selected firmware file: G935FXXU1APEQ_G935FUWA1APEQ_PCT_Android_6.0.1.oct Please put the phone into Download Mode and connect USB cable. To put SM-G935F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing PARAM section... PARAM section has been written successfully. Writing CM section... CM section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... Writing Firmware Failed Performed by 2.4.1 Software version. Last edited by Blartiartfast; 11-10-2016 at 14:22. |
11-10-2016, 14:24 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to perform the operation with the latest Software version and post here the result. Also, what product name is being displayed in Download Mode? |
11-10-2016, 15:12 | #6 (permalink) |
Member: 4611 Status: Offline Thanks Meter: 68 | The phone is a G935f tried to flash another G935 and the same has happened. This is after updating to the latest octopus software. Cannot get either phone to get beyond the "system" point on any software it would seem. Very odd. The file I used is G935FXXU1APEQ_G935FUWA1APEQ_PCT_Android_6.0.1 |
11-10-2016, 15:34 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | We've uploaded newest firmware for SM-G935F, "G935FXXU1BPJG_G935FITV1BPJ1_ITV_Android_6.0.1 ", into the Support Area. Try to write it and post here the result. |
11-11-2016, 17:06 | #8 (permalink) |
Member: 4611 Status: Offline Thanks Meter: 68 | Tried that.. Failed at the same spot. After using then oct file I downloaded from support the phone will not accept the system file. Tried half a dozen firmware files right up to an early 7 release.. all files fail at the same point. Any ideas? |
11-12-2016, 08:45 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Does any error appear on phone screen during write process? Are there any errors except "Dm-verity failure" in Recovery Mode? |
11-12-2016, 11:33 | #10 (permalink) |
Member: 4611 Status: Offline Thanks Meter: 68 | Sorted (by fluke I think). Used Odin and selected repartition and upadate boot.. along with a full flash.. Went straight through, and dm failure has been fixed too :-) I can go to sleep now :-) Cheers for the help. |
