G935F Repair Network Hi i havea samsung s7 edge G935fd with firmware 7.0 G935FXXU1DQCG When i try to connect to octopusbox i get stuck at Platform: Samsung Android Selected port: COM3 Selected model: SM-G935F Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. When i dont get the above msg i get Proper android device not found. Make shure that "USB debug" option on the device is turned on. Repairing network failed. I am unable to repair network to get my s7 back to getting a signal! Can any one advise were and what i can do to correct this? thanks |
I have uninstalled the program and reinstalled the APP and drivers and still says press the ok popup and nothing popsup. |
ok an update, after i root my phone my computer detects said phone but does not allow a proper connection I.E i dont get the popup to say allow MTP or anything. Seems the root is blocking my connection.. USB debugging is enabled |
g935f idem problem no work android 7 not root good no work network |
So ocotpusbox works gr8 on 6.0.1 however when i upgrade to 7.0 (any firmware) and root with the correct method. TWRP and SU it stops connecting to my PC when phones booted! however when i mount SD etc.. via TWRP it connects to my PC.. Any one with any ideas? |
Hello. Unfortunately "Repair Network" operation doesn't work for SM-G935F on Android 7.0 at the moment. To fix issue with connection You can try use different USB ports of PC motherboard for connection of the phone. |
any update on when this will be able to be done? |
Hi, you have to do the downgrade of your country's stock firmware from Android 7 nougat to Android 6.0.1, then do repair IMEI written the new IMEI code do repair network and see that the network phone part should work, beware the patch only works on the firmware written if you try to make the flash to another firmware The phone network part does not work and you have to repeat the Operation repair Network |
Currently no ETA on when the solution for Android 7 will be found. As soon as we manage to find - we'll release an update with improved methods. |
How did you manage to downgrade from 7.0? |
Hi, you have to unzip the 4 files from the firmware BL, AP. CSC, CP load them manually in the section BL AP csc cp on Odin and start the firmware flash,Or you can use octopus via advanced mode by selecting the format if in tar md5 or in octopus file, from AP, starting the Flash from IMG boot, clearing the other boxes cm bin, boot bin, Sboot bin |
Hello, thank you for the idea, I'll try it |
Here you will find a program to unpack the 4 files of the Samsung firmware Http://www.mediafire.com/file/fsj1vw...Maker_v1.0.zip |
help me? |
Try to make Factory Reset. If problem with speaker will remain - reflash the phone, make "Repair Network", then check whether speaker works correctly. |
