05-19-2017, 20:47 | #1 (permalink) |
Crazy Poster Join Date: Oct 2004 Age: 39
Member: 88146 Status: Offline Thanks Meter: 1 | G935F Repair Network When i try to connect to octopusbox i get stuck at Platform: Samsung Android Selected port: COM3 Selected model: SM-G935F Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. When i dont get the above msg i get Proper android device not found. Make shure that "USB debug" option on the device is turned on. Repairing network failed. I am unable to repair network to get my s7 back to getting a signal! Can any one advise were and what i can do to correct this? thanks |
05-20-2017, 04:40 | #3 (permalink) |
Member: 88146 Status: Offline Thanks Meter: 1 | ok an update, after i root my phone my computer detects said phone but does not allow a proper connection I.E i dont get the popup to say allow MTP or anything. Seems the root is blocking my connection.. USB debugging is enabled |
05-21-2017, 18:13 | #5 (permalink) |
Member: 88146 Status: Offline Thanks Meter: 1 | So ocotpusbox works gr8 on 6.0.1 however when i upgrade to 7.0 (any firmware) and root with the correct method. TWRP and SU it stops connecting to my PC when phones booted! however when i mount SD etc.. via TWRP it connects to my PC.. Any one with any ideas? |
05-22-2017, 08:05 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,417 | Hello. Unfortunately "Repair Network" operation doesn't work for SM-G935F on Android 7.0 at the moment. To fix issue with connection You can try use different USB ports of PC motherboard for connection of the phone. |
05-22-2017, 13:36 | #7 (permalink) | |
Member: 88146 Status: Offline Thanks Meter: 1 | Quote:
any update on when this will be able to be done? | |
05-22-2017, 13:48 | #8 (permalink) |
Product Supporter Join Date: Aug 2016
Member: 2613252 Status: Offline Thanks Meter: 1,837 | Hi, you have to do the downgrade of your country's stock firmware from Android 7 nougat to Android 6.0.1, then do repair IMEI written the new IMEI code do repair network and see that the network phone part should work, beware the patch only works on the firmware written if you try to make the flash to another firmware The phone network part does not work and you have to repeat the Operation repair Network |
05-22-2017, 13:51 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,417 | Currently no ETA on when the solution for Android 7 will be found. As soon as we manage to find - we'll release an update with improved methods. |
05-22-2017, 14:11 | #11 (permalink) |
Member: 2613252 Status: Offline Thanks Meter: 1,837 | Hi, you have to unzip the 4 files from the firmware BL, AP. CSC, CP load them manually in the section BL AP csc cp on Odin and start the firmware flash,Or you can use octopus via advanced mode by selecting the format if in tar md5 or in octopus file, from AP, starting the Flash from IMG boot, clearing the other boxes cm bin, boot bin, Sboot bin |
05-22-2017, 14:21 | #13 (permalink) |
Member: 2613252 Status: Offline Thanks Meter: 1,837 | Here you will find a program to unpack the 4 files of the Samsung firmware Http://www.mediafire.com/file/fsj1vw...Maker_v1.0.zip |
05-23-2017, 07:27 | #15 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,417 | Try to make Factory Reset. If problem with speaker will remain - reflash the phone, make "Repair Network", then check whether speaker works correctly. |
