01-24-2022, 13:15 | #1 (permalink) |
Freak Poster Join Date: Aug 2012 Location: CANADA
Member: 1800670 Status: Offline Sonork: 100.1620362 Thanks Meter: 22 | g960f incorrect code please help [Solved] Card S/N : 00004543 ----------------------------------------------------------------------------------- Work ID: 0000000002270156 Platform: Samsung Android Selected port: COM26 Selected model: SM-M105F Operation: Read info Reading info, please wait... Proper android device not found. Make sure that "USB debug" option on the device is turned on. Performed by 3.0.7 Software version. ----------------------------------------------------------------------------------- Work ID: 000000000227016D Platform: Samsung Android Selected port: COM26 Selected model: SM-M105F Operation: Read Cert - ADB Proper android device not found. Make sure that "USB debug" option on the device is turned on. Reading Certificate failed Performed by 3.0.7 Software version. ----------------------------------------------------------------------------------- Work ID: 0000000002270178 Platform: Samsung Android Selected port: COM26 Selected model: SM-M105F Operation: Read security Proper android device not found. Make sure that "USB debug" option on the device is turned on. Reading security failed. Performed by 3.0.7 Software version. Connecting to server.. Username: bahriphonewala_20 Authorization.. Checking smart card... Checking balance.. Your balance: 140 credits. Requesting history.. History not found! Requesting service status.. Service status successfully obtained! Performed by 3.0.7 Software version. ----------------------------------------------------------------------------------- Work ID: 00000000022701DE Platform: Samsung Android Selected port: COM26 Selected model: SM-G950F Operation: Reset FRP - ADB Searching for a phone (waiting for ADB device)... Operation was canceled Performed by 3.0.7 Software version. ----------------------------------------------------------------------------------- To connect SM-N930T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Work ID: 00000000022701EE Platform: Samsung Android Selected port: COM26 Selected model: SM-N930T Operation: Reset FRP - ADB Searching for a phone (waiting for ADB device)... Operation was canceled Performed by 3.0.7 Software version. Selected BOOT file: F:\samsung files\g960f\G960FXXSHFUJ3_10_ 4File_Multi CSC (OXM)\BL_G960FXXSHFUJ3_CL22256815 _QB45346441_REV01_user_low_ship.tar.md5 Selected AP file: F:\samsung files\g960f\G960FXXSHFUJ3_10_ 4File_Multi CSC (OXM)\AP_G960FXXSHFUJ3_CL22256815 _QB45346441_REV01_user_low_ship_meta_OS10.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-G960F into Download Mode, You have to perform the following steps: 1. Power off the phone. 2. Press and hold "Volume-" + "Bixby" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing PARAM section... PARAM section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Firmware writing successfully completed. Performed by 3.0.7 Software version. Selected BOOT file: F:\samsung files\m105f\BL_M105FDDU4CUF3 _CL21947068_QB41401764_REV00_user_low_ship.tar.md5 Selected AP file: F:\samsung files\m105f\AP_M105FDDU4CUF3 _CL21947068_QB41401764_REV00 _user_low_ship_meta_RKEY_OS10.tar.md5 Selected CP file: F:\samsung files\m105f\CP_M105FDDU4CUF1 _CL1986432_QB19548839_SIGNED.tar.md5 Selected CSC file: F:\samsung files\m105f \CSC_OMC_ODM_M105FODM4CUF3_CL21947068_QB41401764 _REV00_user_low_ship.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-M105F into Download Mode, You have to perform the following steps: 1. Power off the phone. 2. Press and hold "Volume-" + "Bixby" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing PARAM section... PARAM section has been written successfully. Writing CM section... CM section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing VENDOR section... VENDOR section has been written successfully. Writing USERDATA section... USERDATA section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Writing CP_DEBUG section... CP_DEBUG section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing OMR section... OMR section has been written successfully. Writing ODM section... ODM section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. Performed by 3.0.7 Software version. Selected BOOT file: F:\samsung files\g960f\G960FXXSHFUJ3_10_ 4File_Multi CSC (OXM)\BL_G960FXXSHFUJ3_CL22256815 _QB45346441_REV01_user_low_ship.tar.md5 Selected AP file: F:\samsung files\g960f\G960FXXSHFUJ3_10_ 4File_Multi CSC (OXM)\AP_G960FXXSHFUJ3_CL22256815 _QB45346441_REV01_user_low_ship_meta_OS10.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-G960F into Download Mode, You have to perform the following steps: 1. Power off the phone. 2. Press and hold "Volume-" + "Bixby" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing PARAM section... PARAM section has been written successfully. Writing UP_PARAM section... UP_PARAM section has been written successfully. Writing CM section... CM section has been written successfully. Writing KEYSTORAGE section... KEYSTORAGE section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing DQMDBG section... DQMDBG section has been written successfully. Firmware writing successfully completed. Performed by 3.0.7 Software version. Selected BOOT file: F:\samsung files\g960f\G960FXXSHFUJ3_10_ 4File_Multi CSC (OXM)\BL_G960FXXSHFUJ3_CL22256815 _QB45346441_REV01_user_low_ship.tar.md5 Selected AP file: F:\samsung files\g960f\G960FXXSHFUJ3_10_ 4File_Multi CSC (OXM)\AP_G960FXXSHFUJ3_CL22256815 _QB45346441_REV01_user_low_ship_meta_OS10.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-G960F into Download Mode, You have to perform the following steps: 1. Power off the phone. 2. Press and hold "Volume-" + "Bixby" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing PARAM section... PARAM section has been written successfully. Writing UP_PARAM section... UP_PARAM section has been written successfully. Writing CM section... CM section has been written successfully. Writing KEYSTORAGE section... KEYSTORAGE section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing DQMDBG section... DQMDBG section has been written successfully. Writing USERDATA section... USERDATA section has been written successfully. Firmware writing successfully completed. Performed by 3.0.7 Software version. ----------------------------------------------------------------------------------- Work ID: 0000000002271232 Platform: Samsung Android Selected port: COM26 Selected model: SM-G960F Operation: Read Codes - Without root(via ADB interface) Proper android device not found. Make sure that "USB debug" option on the device is turned on. Read codes failed Performed by 3.0.7 Software version. ----------------------------------------------------------------------------------- Work ID: 0000000002271276 Platform: Samsung Android Selected port: COM20 Selected model: SM-G960F Operation: Read Codes - Without root(via ADB interface) Please, press "OK" button on the phone to allow USB debugging. Detected phone model: SM-G960F Firmware compiled date: Tue Oct 19 11:22:58 KST 2021 PDA version: G960FXXSHFUJ2 CSC version: G960FOBEEFUA1 SW version: G960FXXSHFUJ2 Build number: QB20704327 Phone SN: R58K857QP0V Android version: 10 (QP1A.190711.020) Sales code: EVR Country: UK HW platform: universal9810 HW Chip: unknown HW Modem: SHANNON360 Security patch level: 2021-11-01 Warranty Void: 1 SIM 1 status: absent Codename: starltexx ----------------------------------------------------------------------------------- Connecting to server .. Username: bahriphonewala_20 Connect to server successfull. Checking smart card... Your balance: 140 credits. ----------------------------------------------------------------------------------- Checking operation...failed Device's modem G960FXXSHFUJ2 (QB20704327) is not supported! Read codes failed Performed by 3.0.7 Software version. ----------------------------------------------------------------------------------- Work ID: FFFFFFFFFFFFFFFF Platform: Samsung Android Selected port: COM20 Selected model: SM-G960F Operation: Read Codes - Any KNOX. Latest Firmwares are supported! Detected phone model: SM-G960F Firmware compiled date: Tue Oct 19 11:22:58 KST 2021 PDA version: G960FXXSHFUJ2 CSC version: G960FOBEEFUA1 SW version: G960FXXSHFUJ2 Build number: QB20704327 Phone SN: R58K857QP0V Android version: 10 (QP1A.190711.020) Sales code: EVR Country: UK HW platform: universal9810 HW Chip: unknown HW Modem: SHANNON360 Security patch level: 2021-11-01 Warranty Void: 1 SIM 1 status: absent Codename: starltexx Checking root...OK Checking device status...OK Phone will restart now. Please don't disconnect cable! Rebooting phone...OK Searching for ADB device...OK Checking root...OK Connecting to server...failedfailedfailedOK Checking smart card...OK Username: bahriphonewala_20 Authorizing...OK Checking balance...OK Your balance: 140 credits. Checking operation...OK Initializing exploit...OK Checking operation...OK Bypassing security 1...OK Bypassing security 2...OK Reseting MSL...OK Reading codes...OK FREEZE: 24750215 NET LOCK: 79115761 SUB LOCK: 00000000 SP LOCK: 00000000 CP LOCK: 00000000 SIM LOCK: 00000000 Phone will restart now. Please don't disconnect cable! Rebooting phone...OK Performed by 3.0.7 Software version. video link: https://we.tl/t-5U6yZ4bPzF |
01-24-2022, 13:38 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | We added you one more attempt, do hard reset and please download and install new Samsung software version 4.0.1 then try to repeat Read codes operation again and post here result. |
01-24-2022, 14:17 | #9 (permalink) |
Member: 1800670 Status: Offline Sonork: 100.1620362 Thanks Meter: 22 | Welcome to Octoplus Samsung Tool version 3.0.7 Card S/N : 00004543 Selected BOOT file: F:\samsung files\g960f\G960FXXSHFUJ3_10_4File_Multi CSC (OXM)\BL_G960FXXSHFUJ3_CL22256815_QB45346441_REV01 _user_low_ship.tar.md5 Selected AP file: F:\samsung files\g960f\G960FXXSHFUJ3_10_4File_Multi CSC (OXM)\AP_G960FXXSHFUJ3_CL22256815_QB45346441_REV01 _user_low_ship_meta_OS10.tar.md5 Selected CP file: F:\samsung files\g960f\G960FXXSHFUJ3_10_4File_Multi CSC (OXM)\CP_G960FXXSHFUJ2_CL2049367_QB20704327_SIGNED .tar.md5 Selected CSC file: F:\samsung files\g960f\G960FXXSHFUJ3_10_4File_Multi CSC (OXM)\CSC_OMC_OXM_G960FOXMHFUJ3_CL22256815_QB45346 441_REV01_user_low_ship.tar.md5 ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM26 Selected model: SM-G960F Port is busy Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM6 Phone connection failed No diagnostic ports found! Connecting to phone on COM5 Phone connection failed Selected action can’t be performed Performed by 3.0.7 Software version. Selected BOOT file: F:\samsung files\g960f\G960FXXSHFUJ3_10_4File_Multi CSC (OXM)\BL_G960FXXSHFUJ3_CL22256815_QB45346441_REV01 _user_low_ship.tar.md5 Selected AP file: F:\samsung files\g960f\G960FXXSHFUJ3_10_4File_Multi CSC (OXM)\AP_G960FXXSHFUJ3_CL22256815_QB45346441_REV01 _user_low_ship_meta_OS10.tar.md5 Selected CP file: F:\samsung files\g960f\G960FXXSHFUJ3_10_4File_Multi CSC (OXM)\CP_G960FXXSHFUJ2_CL2049367_QB20704327_SIGNED .tar.md5 Selected CSC file: F:\samsung files\g960f\G960FXXSHFUJ3_10_4File_Multi CSC (OXM)\CSC_OMC_OXM_G960FOXMHFUJ3_CL22256815_QB45346 441_REV01_user_low_ship.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-G960F into Download Mode, You have to perform the following steps: 1. Power off the phone. 2. Press and hold "Volume-" + "Bixby" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing PARAM section... PARAM section has been written successfully. Writing UP_PARAM section... UP_PARAM section has been written successfully. Writing CM section... CM section has been written successfully. Writing KEYSTORAGE section... KEYSTORAGE section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing VENDOR section... VENDOR section has been written successfully. Writing DQMDBG section... DQMDBG section has been written successfully. Writing USERDATA section... USERDATA section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Writing CP_DEBUG section... CP_DEBUG section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing OMR section... OMR section has been written successfully. Writing ODM section... Writing Firmware Failed Performed by 3.0.7 Software version. Selected BOOT file: F:\samsung files\g960f\G960FXXSHFUJ3_10_4File_Multi CSC (OXM)\BL_G960FXXSHFUJ3_CL22256815_QB45346441_REV01 _user_low_ship.tar.md5 Selected AP file: F:\samsung files\g960f\G960FXXSHFUJ3_10_4File_Multi CSC (OXM)\AP_G960FXXSHFUJ3_CL22256815_QB45346441_REV01 _user_low_ship_meta_OS10.tar.md5 Selected CP file: F:\samsung files\g960f\G960FXXSHFUJ3_10_4File_Multi CSC (OXM)\CP_G960FXXSHFUJ2_CL2049367_QB20704327_SIGNED .tar.md5 Selected CSC file: F:\samsung files\g960f\G960FXXSHFUJ3_10_4File_Multi CSC (OXM)\CSC_OMC_OXM_G960FOXMHFUJ3_CL22256815_QB45346 441_REV01_user_low_ship.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-G960F into Download Mode, You have to perform the following steps: 1. Power off the phone. 2. Press and hold "Volume-" + "Bixby" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. Performed by 3.0.7 Software version. |
01-24-2022, 14:24 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please, do hard reset, download and install new Samsung software version 4.0.1 then try to repeat Read codes operation again and post here result. |
01-24-2022, 14:54 | #11 (permalink) |
Member: 1800670 Status: Offline Sonork: 100.1620362 Thanks Meter: 22 | Welcome to Octoplus Samsung Software v.4.0.1.1 Work ID: 0000000002277E73 Starting Write Firmware Selected model: SM-G960F Please disable KNOX (if it is activated) in order to avoid damage! Please, make sure the phone battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a "clean" PC (without any drivers installed for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during flashing! Selected firmware files: F:/samsung files/g960f/G960FXXSHFUJ3_10_4File_Multi CSC (OXM)/BL_G960FXXSHFUJ3_CL22256815_QB45346441_REV01_user_ low_ship.tar.md5 F:/samsung files/g960f/G960FXXSHFUJ3_10_4File_Multi CSC (OXM)/AP_G960FXXSHFUJ3_CL22256815_QB45346441_REV01_user_ low_ship_meta_OS10.tar.md5 F:/samsung files/g960f/G960FXXSHFUJ3_10_4File_Multi CSC (OXM)/CP_G960FXXSHFUJ2_CL2049367_QB20704327_SIGNED.tar.m d5 F:/samsung files/g960f/G960FXXSHFUJ3_10_4File_Multi CSC (OXM)/CSC_OMC_OXM_G960FOXMHFUJ3_CL22256815_QB45346441_RE V01_user_low_ship.tar.md5 Searching ADB devices... ADB devices not found Connecting device in Download Mode... Connected successfully to port: COM6 Communicated successfully! Writing PIT section Preparing to send PIT Sending PIT in one package Finalizing PIT write PIT file sent successffully Writing BOOTLOADER section... File name: sboot.bin.lz4 Section BOOTLOADER has been written successfully Writing PARAM section... File name: param.bin.lz4 Section PARAM has been written successfully Writing UP_PARAM section... File name: up_param.bin.lz4 Section UP_PARAM has been written successfully Writing CM section... File name: cm.bin.lz4 Section CM has been written successfully Writing KEYSTORAGE section... File name: keystorage.bin.lz4 Section KEYSTORAGE has been written successfully Writing BOOT section... File name: boot.img.lz4 Section BOOT has been written successfully Writing RECOVERY section... File name: recovery.img.lz4 Section RECOVERY has been written successfully Writing SYSTEM section... File name: system.img.lz4 Section SYSTEM has been written successfully Writing VENDOR section... File name: vendor.img.lz4 Section VENDOR has been written successfully Writing DQMDBG section... File name: dqmdbg.img.lz4 Section DQMDBG has been written successfully Writing USERDATA section... File name: userdata.img.lz4 Section USERDATA has been written successfully Writing RADIO section... File name: modem.bin Section RADIO has been written successfully Writing CP_DEBUG section... File name: modem_debug.bin Section CP_DEBUG has been written successfully Writing CACHE section... File name: cache.img.lz4 Section CACHE has been written successfully Writing OMR section... File name: omr.img.lz4 Section OMR has been written successfully Writing ODM section... File name: odm.img.lz4 Section ODM has been written successfully Writing HIDDEN section... File name: hidden.img.lz4 Section HIDDEN has been written successfully Finalizing write firmware. Restarting phone... Write Firmware done Execution time 9 minute(s) 23 second(s) Performed by 4.0.1.1 Software version. |
01-24-2022, 15:43 | #13 (permalink) |
Member: 1800670 Status: Offline Sonork: 100.1620362 Thanks Meter: 22 | now its done , very strange now codes are changed well these codes are working problem solved thanks Work ID: 0000000002279023 Starting Read Codes (Nov.2020) Selected model: SM-G960F Additional resources required to continue the operation. Total resources size is 11 MB. Download now? Downloading additional resources... Devices with Unlock App (branded to T-Mobile, MetroPCS, etc.) are not supported! Make sure device requests to enter unlock code and only then perform "Read Codes" operation! Do you want to continue? Searching ADB devices... Press "OK" button on the device to allow USB debugging Reading info... Detected model: SM-G960F Fingerprint: samsung/starltexx/starlte:10/QP1A.190711.020/G960FXXSHFUJ3:user/release-keys Firmware compiled date: Wed Oct 27 13:14:16 KST 2021 PDA version: G960FXXSHFUJ3 CSC version: G960FOXMHFUJ1 SW version: G960FXXSHFUJ2 Build number: QB20704327 Phone SN: R58K857QP0V Android version: 10 (QP1A.190711.020) Sales code: DBT Country: Germany HW platform: universal9810 HW Chip: samsungexynos9810 HW Modem: MP 0.900 Security patch level: 2021-11-01 Warranty Void: 1 Codename: starltexx SIM 1 status: ABSENT SIM 2 status: ABSENT Modem board: SHANNON360 Connecting to server... Username: bahriphonewala_20 Your balance: 140 credits Your account will be charged for 80 credits. Do you want to continue? Checking network status... OK Device is rooted Starting exploit... Bypassing security 1... Bypassing security 2... Resetting MSL... Reading Codes... Rebooting device... FREEZE: 95828578 NET LOCK: 35868572 SUB LOCK: 00000000 SP LOCK: 00000000 CP LOCK: 00000000 SIM LOCK: 00000000 Read Codes (Nov.2020) done Execution time 6 minute(s) 48 second(s) Performed by 4.0.1.1 Software version. |
The Following User Says Thank You to GsmUnlockSource For This Useful Post: |
