08-11-2014, 13:07 | #1 (permalink) |
Insane Poster Join Date: Nov 2006
Member: 388447 Status: Offline Thanks Meter: 4 | GT-I9505 4.4.2 No Service 1. Flashed "I9505XXUFNA5_I9505OXAFNA5_I9505XXUFNA5_OXA_4. 4.2" 2. After That Flashed "I9505XXUFNA1-MODEM" 3. Write "GT-i9505_for_Unlock_and_IMEI_repair" 4. Then Rooted With "Root_GT-I9505_new.oct" 5. Click in SU and UNINSTALL KNOX Security 6. Reboot the phone 7. Fixed IMEI Successful 8. Imei & S/N Too Original As On Back 9. And there is a "banned" icon on top of right corner and says "No Service" 10. Repaired NVM, then Repair 3G/4G too No Success Still "No Service" 11. Flashed latest 4.4.2 Android firmware from the Support Area "I9505XXUFNB8_I9505OXAFNB8_DBT_Germany_Android_4.4 .2.oct" Still "No Service" |
08-11-2014, 13:24 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,417 | Hello. Please do the next: 1. Make Factory Reset. 2. Make Repair 3G/4G 3. Make Repair NVM. Post here Software logs with all performed operations. Also take a look at this thread: http://forum.gsmhosting.com/vbb/f684...79/index2.html |
08-11-2014, 14:41 | #3 (permalink) |
Member: 388447 Status: Offline Thanks Meter: 4 | I`ve Already Read That Post And Tried Too Here Is the Logs Links 11-08-2014_16-19-36 - Download - 4shared - Rushad Rahuman |
08-11-2014, 14:53 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,417 | Do the next: 1. Make Factory Reset. 2. Re-flash the phone with "I9505XXUFNB8_I9505OXAFNB8_DBT_Germany_Android _4.4 .2.oct" again. 3. Make Repair NVM. 4. Wait 5-10 minutes. No need to make Repair 3G/4G again, only this four steps. Then check phone's network and post results. |
08-12-2014, 06:23 | #5 (permalink) | |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | SGS4 4.4.2 without headaches Quote:
P.S. in any case there is better to unlock 4.4.2 via code reading - simply root phone and flash 4.3 modem ( so called GT-i9505_for_Unlock_and_IMEI_repair ) ... read codes and write it down. Restore ( flash back ) 4.4.2 modem ( or full latest firmware if you like as in: ) ... power phone and enter NCK when ask it ... it's simple. | |
08-12-2014, 07:41 | #7 (permalink) | |
Member: 388447 Status: Offline Thanks Meter: 4 | Quote:
It Says No Service And there is a "banned" icon on top of right corner Not Working | |
08-12-2014, 08:45 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,417 | Please do the next: 1. Write Security backup that You received during Repair IMEI operation. 2. Make Repair IMEI again. Post here results and Software log of the operations. |
08-12-2014, 09:10 | #11 (permalink) |
Member: 388447 Status: Offline Thanks Meter: 4 | ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM8 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Dec 24 2013 Firmware compiled time: 00:00:00 Firmware released date: Feb 13 2014 Firmware released time: 21:32:10 Phone IMEI: 357634-05-930182-5 SW version: M9615A-CEFWTAZM-4.0.17135 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM8 Selected model: GT-I9505 Reading info, please wait... ADB server killed. Detected phone model: GT-I9505 Firmware compiled date: Thu Feb 13 20:47:45 KST 2014 PDA version: I9505XXUFNB8 CSC version: I9505OXAFNB8 SW version: I9505XXUFNB8 Phone IMEI: 357634059301825 Phone SN: RZ1F11X965V Android version: 4.4.2 (KOT49H) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM8 Selected model: GT-I9505 Detected phone model: GT-I9505 Firmware compiled date: Thu Feb 13 20:47:45 KST 2014 PDA version: I9505XXUFNB8 CSC version: I9505OXAFNB8 SW version: I9505XXUFNB8 Phone IMEI: 357634059301825 Phone SN: RZ1F11X965V Android version: 4.4.2 (KOT49H) Writing security backup, please wait... Can't get superuser aceess. Please, repeat opperation once againe and press "Allow" button on the phone every time when superuser dialog appears. Can't get superuser aceess. Please, repeat opperation once againe and press "Allow" button on the phone every time when superuser dialog appears. Can't get superuser aceess. Please, repeat opperation once againe and press "Allow" button on the phone every time when superuser dialog appears. Phone will restart now Security write successfully. Selected firmware file: Root_GT-I9505_new.oct Please put the phone into Download Mode and connect USB cable. To put GT-I9505 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing RECOVERY section... RECOVERY section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Firmware writing successfully completed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9505 ADB server killed. Detected phone model: GT-I9505 Firmware compiled date: Thu Feb 13 20:47:45 KST 2014 PDA version: I9505XXUFNB8 CSC version: I9505OXAFNB8 SW version: I9505XXUFNB8 Phone IMEI: 357634059301825 Phone SN: RZ1F11X965V Android version: 4.4.2 (KOT49H) Writing security backup, please wait... Phone will restart now Security write successfully. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM8 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Dec 24 2013 Firmware compiled time: 00:00:00 Firmware released date: Feb 13 2014 Firmware released time: 21:32:10 Phone IMEI: 357634-05-930182-5 SW version: M9615A-CEFWTAZM-4.0.17135 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM8 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Dec 24 2013 Firmware compiled time: 00:00:00 Firmware released date: Feb 13 2014 Firmware released time: 21:32:10 SW version: M9615A-CEFWTAZM-4.0.17135 Old IMEI: 357634-05-930182-5 New IMEI: 357634-05-930182-5 Please, enter the new IMEI ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM8 Selected model: GT-I9505 ADB server killed. Detected phone model: GT-I9505 Firmware compiled date: Thu Feb 13 20:47:45 KST 2014 PDA version: I9505XXUFNB8 CSC version: I9505OXAFNB8 SW version: I9505XXUFNB8 Phone IMEI: 357634059301825 Phone SN: RZ1F11X965V Android version: 4.4.2 (KOT49H) Writing security backup, please wait... Phone will restart now Security write successfully. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM8 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Dec 24 2013 Firmware compiled time: 00:00:00 Firmware released date: Feb 13 2014 Firmware released time: 21:32:10 Phone IMEI: 356845-05-671216-7 SW version: M9615A-CEFWTAZM-4.0.17135 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM8 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Dec 24 2013 Firmware compiled time: 00:00:00 Firmware released date: Feb 13 2014 Firmware released time: 21:32:10 SW version: M9615A-CEFWTAZM-4.0.17135 Old IMEI: 356845-05-671216-7 New IMEI: 357634-05-930182-5 Creating NVM backup Reading NVM done! ADB server killed. Firmware compiled date: Thu Feb 13 20:47:45 KST 2014 PDA version: I9505XXUFNB8 CSC version: I9505OXAFNB8 SW version: I9505XXUFNB8 Phone IMEI: 356845056712167 Phone SN: RZ1F11X965V Android version: 4.4.2 (KOT49H) Cheking Root Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-GT-I9505-356845056712167-12-08-2014_13-30- 38-.asec file Erasing old IMEI. It can take some time. Please wait... Phone will restart now. Please don't disconnect cable! Firmware compiled date: Dec 24 2013 Firmware compiled time: 00:00:00 Firmware released date: Feb 13 2014 Firmware released time: 21:32:10 SW version: M9615A-CEFWTAZM-4.0.17135 Found phone on COM8 Repairing NVM for GT-I9505 phone... Write IMEI failed Selected firmware file: GT-I9505_for_Unlock_and_IMEI_repair.oct Please put the phone into Download Mode and connect USB cable. To put GT-I9505 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing MDM section... MDM section has been written successfully. Firmware writing successfully completed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9505 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM8 Phone connection failed Connecting to phone on COM7 Phone connection failed Connecting to phone on COM9 Phone connection failed No diagnostic ports found! Connecting to phone on COM3 Phone connection failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM8 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Mar 28 2013 Firmware compiled time: 09:00:00 Firmware released date: Apr 12 2013 Firmware released time: 00:04:45 Incorrect IMEI SW version: M9615A-CEFWTAZM-4.0.17062 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM8 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Mar 28 2013 Firmware compiled time: 09:00:00 Firmware released date: Apr 12 2013 Firmware released time: 00:04:45 SW version: M9615A-CEFWTAZM-4.0.17062 Old IMEI: 004400-15-202000-0 New IMEI: 357634-05-930182-5 Creating NVM backup Reading NVM done! ADB server killed. Firmware compiled date: Thu Feb 13 20:47:45 KST 2014 PDA version: I9505XXUFNB8 CSC version: I9505OXAFNB8 SW version: I9505XXUAMDC Phone IMEI: Unknown Phone SN: RZ1F11X965V Android version: 4.4.2 (KOT49H) Cheking Root Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-GT-I9505-12-08-2014_13-38-08-.asec file Erasing old IMEI. It can take some time. Please wait... Phone will restart now. Please don't disconnect cable! Firmware compiled date: Mar 28 2013 Firmware compiled time: 09:00:00 Firmware released date: Apr 12 2013 Firmware released time: 00:04:45 SW version: M9615A-CEFWTAZM-4.0.17062 Found phone on COM8 Repairing NVM for GT-I9505 phone... IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) |
The Following User Says Thank You to rushad22 For This Useful Post: |
