04-19-2015, 06:13 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: Sri Lanka , Kandy Age: 34
Member: 763865 Status: Offline Sonork: Cvlvertcharges Thanks Meter: 123 | gt-i9515 imei null null repaire secrity Welcome to Octoplus/Octopus Box Samsung software version 1.8.9 ----------------------------------------------------------------------------------- To connect GT-I9515 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM72 Selected model: GT-I9515 Detected phone model: GT-I9515 Firmware compiled date: Fri Sep 26 17:59:00 KST 2014 PDA version: I9515XXU1ANI3 CSC version: I9515YJV1ANK1 SW version: Unknown Phone IMEI: Unknown Android version: 4.4.2 (KOT49H) Reading info... Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM39 Selected model: GT-I9515 Detected phone model: GT-I9515 Firmware compiled date: Fri Sep 26 17:59:00 KST 2014 PDA version: I9515XXU1ANI3 CSC version: I9515YJV1ANK1 SW version: Unknown Phone IMEI: Unknown Android version: 4.4.2 (KOT49H) Reading info... Phone was not found on the selected port! Last edited by Octopus box; 04-19-2015 at 09:17. |
The Following User Says Thank You to a.w.m.wafaz For This Useful Post: |
04-19-2015, 06:14 | #2 (permalink) |
Member: 763865 Status: Offline Sonork: Cvlvertcharges Thanks Meter: 123 | Platform: Samsung Android Selected port: COM39 Selected model: GT-I9515 Operation was canceled Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM39 Selected model: GT-I9515 Selected file: C:\Users\SHT\Downloads\cert-gt-i9515_352168062519086_rf8f7069gkw.cert Detected phone model: GT-I9515 Firmware compiled date: Fri Sep 26 17:59:00 KST 2014 PDA version: I9515XXU1ANI3 CSC version: I9515YJV1ANK1 SW version: Unknown Phone IMEI: Unknown Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Phone connected successfully Writing new phone IMEI... Writing Certificate failed |
04-19-2015, 09:19 | #3 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | As You can see from your Software log, phone's modem part is damaged: Quote:
It is not possible to repair IMEI (write IMEI Certificate), if phone's modem part is damaged. Please re-flash the phone with different firmwares and after writing each firmware check, whether modem is correct (not Unknown). And only then (when phone's modem part will be correct) perform the "Write Cert" operation. | |
