12-23-2014, 16:54 | #1 (permalink) |
No Life Poster Join Date: Aug 2011 Location: in Heart of someone
Member: 1640158 Status: Offline Sonork: 100.1615555 Thanks Meter: 138 | GT-N7102 there is problem to write flash file [Solved] ----------------------------------------------------------------------------------- To connect GT-N7102 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Connect usb cable to phone. 6. Go to dial window. 7. Enter *#9090# number. 8. Set speed to 115200. 9. Go to dial window. 10. Enter "*#7284#" number. 11. Set "UART" radio button to "MODEM" value. 12. Set "USB" radio button to "PDA" value 13. Press "Read Info" in software. Selected firmware file: SM-G7102_for_Unlock_and_Repair_IMEI_ 4.4.2.oct Please put the phone into Download Mode and connect USB cable. To put GT-N7102 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on File has been created for a different phone model. Last edited by Octopus box; 12-24-2014 at 09:16. |
12-23-2014, 17:04 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | What is your device model exactly, GT-N7102 or SM-G7102? If your device is GT-N7102, why have You selected special firmwares for SM-G7102? |
12-23-2014, 19:14 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | If want to write special firmware into SM-G7102 phone - You need to select SM-G7102 model in Software, not SM-N7102. |
12-24-2014, 08:49 | #5 (permalink) | |
Member: 1640158 Status: Offline Sonork: 100.1615555 Thanks Meter: 138 | Quote:
Welcome to Octoplus/Octopus Box Samsung software version 1.7.8 ----------------------------------------------------------------------------------- To connect GT-I9505 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-G7102 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM17 Selected model: SM-G7102 Reading info, please wait... Detected phone model: SM-G7102 Firmware compiled date: Mon Oct 6 21:06:20 KST 2014 PDA version: G7102DDUBNJ2 CSC version: G7102ODDBNJ1 SW version: G7102DDUBNI1 Phone IMEI: 352310061266661 Phone SN: 00000000000 Android version: 4.4.2 (KOT49H) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM17 Selected model: SM-G7102 Reading info, please wait... Detected phone model: SM-G7102 Firmware compiled date: Mon Oct 6 21:06:20 KST 2014 PDA version: G7102DDUBNJ2 CSC version: G7102ODDBNJ1 SW version: G7102DDUBNI1 Phone IMEI: 352310061266661 Phone SN: 00000000000 Android version: 4.4.2 (KOT49H) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM17 Selected model: SM-G7102 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM27 Mode: Normal Phone model: SM-G7102 Firmware compiled date: Sep 03 2014 Firmware compiled time: 06:00:00 Firmware released date: Sep 19 2014 Firmware released time: 18:10:33 Phone IMEI: 352310-06-126666-1 SW version: M8626A-AAAANAZM-1.0.4072 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM27 Selected model: SM-G7102 Mode: Normal Phone model: SM-G7102 Firmware compiled date: Sep 03 2014 Firmware compiled time: 06:00:00 Firmware released date: Sep 19 2014 Firmware released time: 18:10:33 Phone IMEI: 352310-06-126666-1 SW version: M8626A-AAAANAZM-1.0.4072 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM27 Selected model: SM-G7102 Mode: Normal Phone model: SM-G7102 Firmware compiled date: Sep 03 2014 Firmware compiled time: 06:00:00 Firmware released date: Sep 19 2014 Firmware released time: 18:10:33 Phone IMEI: 352310-06-126666-1 SW version: M8626A-AAAANAZM-1.0.4072 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM27 Selected model: SM-G7102 Mode: Normal Phone model: SM-G7102 Firmware compiled date: Sep 03 2014 Firmware compiled time: 06:00:00 Firmware released date: Sep 19 2014 Firmware released time: 18:10:33 Phone IMEI: 352310-06-126666-1 SW version: M8626A-AAAANAZM-1.0.4072 Creating NVM backup Reading NVM done! Repairing NVM for SM-G7102 phone... NVM repair completed successfully To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM27 Selected model: SM-G7102 Reading info... Phone was not found on the selected port! Writing QCN failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM27 Selected model: SM-G7102 Reading info... Phone was not found on the selected port! Writing QCN failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM27 Selected model: SM-G7102 Reading info... Mode: Normal Firmware compiled date: Sep 03 2014 Firmware compiled time: 06:00:00 Firmware released date: Sep 19 2014 Firmware released time: 18:10:33 SW Version: M8626A-AAAANAZM-1.0.4072 Send SPC... SPC send successfully Writing QCN... Writing NV items... NV items write successfully Writing NV SIM1 items... NV SIM1 items write successfully Writing NV SIM2 items... NV SIM2 items write successfully Wrting EFS... EFS write successfully Writing provisioning items... Provisioning items write successfully. Writing QCN done QCN write successfully Please, restart the phone to apply changes | |
