04-18-2016, 17:38 | #1 (permalink) |
Junior Member Join Date: Mar 2014 Location: tunis
Member: 2146344 Status: Offline Thanks Meter: 7 | GT-N7105 IMEI \ à& repaired with sucess ERROR : 18/04/2016 16:53:56 > Access violation at address 009B746C in module 'OctoplusSamsung.exe'. Read of address 00000004 INFO : 18/04/2016 16:53:56 > Set up system language English (file: English.ini) INFO : 18/04/2016 16:53:56 > Welcome to Octoplus/Octopus Box Samsung software version 2.2.4 INFO : 18/04/2016 16:54:01 > ----------------------------------------------------------------------------------- INFO : 18/04/2016 16:54:01 > To connect GT-N7105 phone you have to perform the following steps: INFO : 18/04/2016 16:54:01 > 1. Disconnect USB cable from phone. INFO : 18/04/2016 16:54:01 > 2. Go to Menu->Settings->Developer options. INFO : 18/04/2016 16:54:01 > 3. Turn on "USB Debugging" option. INFO : 18/04/2016 16:54:01 > 4. When message is appear press "Yes". INFO : 18/04/2016 16:54:01 > 5. Go to dial window. INFO : 18/04/2016 16:54:01 > 6. Enter "*#7284#" number. INFO : 18/04/2016 16:54:01 > 7. Set "UART" radio button to "MODEM" value. INFO : 18/04/2016 16:54:01 > 8. Go to "Qualcomm USB Settings". INFO : 18/04/2016 16:54:01 > 9. Select "DM+MODEM+ADB". INFO : 18/04/2016 16:54:01 > 10. Press Home button. INFO : 18/04/2016 16:54:01 > 11. Go to dial window. INFO : 18/04/2016 16:54:01 > 12. Enter "*#9090#" number. INFO : 18/04/2016 16:54:01 > 13. Select "DM/UM over HSIC". INFO : 18/04/2016 16:54:01 > 14. Restart phone. INFO : 18/04/2016 16:54:01 > 15. Press "Read Info" in software. INFO : 18/04/2016 16:54:04 > ----------------------------------------------------------------------------------- INFO : 18/04/2016 16:54:05 > Platform: Samsung Android INFO : 18/04/2016 16:54:05 > Selected port: COM3 INFO : 18/04/2016 16:54:05 > Selected model: GT-N7105 ERROR : 18/04/2016 16:54:05 > Proper android device not found. Make shure that "USB debug" option on the device is turned on. INFO : 18/04/2016 16:54:05 > Performed by 2.2.4 software version INFO : 18/04/2016 16:54:09 > ----------------------------------------------------------------------------------- INFO : 18/04/2016 16:54:10 > Platform: Samsung Android INFO : 18/04/2016 16:54:10 > Selected port: COM3 INFO : 18/04/2016 16:54:10 > Selected model: GT-N7105 INFO : 18/04/2016 16:54:10 > Reading info, please wait... WARN : 18/04/2016 16:54:12 > Please, press "OK" button on the phone to allow USB debugging.. ERROR : 18/04/2016 16:54:12 > Proper android device not found. Make shure that "USB debug" option on the device is turned on. INFO : 18/04/2016 16:54:15 > Performed by 2.2.4 software version INFO : 18/04/2016 16:55:07 > ----------------------------------------------------------------------------------- INFO : 18/04/2016 16:55:07 > Platform: Samsung Android INFO : 18/04/2016 16:55:07 > Selected port: COM3 INFO : 18/04/2016 16:55:07 > Selected model: GT-N7105 INFO : 18/04/2016 16:55:10 > Phone was not found on the selected port! INFO : 18/04/2016 16:55:10 > Searching for USB diagnostic port... INFO : 18/04/2016 16:55:10 > Connecting to phone on COM33 INFO : 18/04/2016 16:55:19 > Mode: Emergency WARN : 18/04/2016 16:55:19 > Phone connection failed WARN : 18/04/2016 16:55:19 > No diagnostic ports found! INFO : 18/04/2016 16:55:19 > Connecting to phone on COM4 WARN : 18/04/2016 16:55:20 > Phone connection failed INFO : 18/04/2016 16:55:20 > Performed by 2.2.4 software version INFO : 18/04/2016 16:57:56 > ----------------------------------------------------------------------------------- INFO : 18/04/2016 16:57:57 > Platform: Samsung Android INFO : 18/04/2016 16:57:57 > Selected port: COM3 INFO : 18/04/2016 16:57:57 > Selected model: GT-N7105 INFO : 18/04/2016 16:57:58 > ADB server killed. INFO : 18/04/2016 16:57:59 > Detected phone model: /logcolorGT-N7105\logcolor INFO : 18/04/2016 16:57:59 > Firmware compiled date: /logcolorFri May 16 14:20:54 KST 2014\logcolor INFO : 18/04/2016 16:57:59 > PDA version: /logcolorN7105XXUFNE3\logcolor INFO : 18/04/2016 16:57:59 > CSC version: /logcolorN7105OXXFNE1\logcolor INFO : 18/04/2016 16:57:59 > SW version: /logcolorN7105XXUFND3\logcolor INFO : 18/04/2016 16:58:00 > Phone SN: /logcolor00000000000\logcolor INFO : 18/04/2016 16:58:00 > Android version: /logcolor4.4.2 (KOT49H)\logcolor INFO : 18/04/2016 16:58:00 > Country: /logcolorFrance\logcolor INFO : 18/04/2016 16:58:00 > HW platform: /logcolorexynos4\logcolor INFO : 18/04/2016 16:58:00 > HW Chip: /logcolorsmdk4x12_prime\logcolor INFO : 18/04/2016 16:58:00 > HW Modem: /logcolorMDM9215M\logcolor INFO : 18/04/2016 16:58:00 > Codename: /logcolort0ltexx\logcolor INFO : 18/04/2016 16:58:00 > Checking Root: INFO : 18/04/2016 16:58:00 > Phone is Rooted. INFO : 18/04/2016 16:58:01 > Reading security backup, please wait... INFO : 18/04/2016 16:59:13 > Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung\BACKUP\Security-GT-N7105-18-04-2016_16-58-00-.asec file INFO : 18/04/2016 16:59:14 > Wiping EFS... INFO : 18/04/2016 17:00:03 > EFS wipe successfully WARN : 18/04/2016 17:00:04 > Phone will restart now. Please don't disconnect cable! INFO : 18/04/2016 17:00:04 > Wipe security successfully complete. INFO : 18/04/2016 17:00:04 > Performed by 2.2.4 software version INFO : 18/04/2016 17:01:39 > ----------------------------------------------------------------------------------- INFO : 18/04/2016 17:01:39 > Platform: Samsung Android INFO : 18/04/2016 17:01:39 > Selected port: COM3 INFO : 18/04/2016 17:01:39 > Selected model: GT-N7105 WARN : 18/04/2016 17:01:39 > To put GT-N7105 into Download Mode, You have to perform the following steps: WARN : 18/04/2016 17:01:39 > 1. Reconnect the battery. WARN : 18/04/2016 17:01:39 > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 18/04/2016 17:01:39 > 3. When phone turns on, press "Volume+" key. INFO : 18/04/2016 17:01:40 > Repairing EFS... INFO : 18/04/2016 17:01:40 > Searching for a phone. Please wait... INFO : 18/04/2016 17:02:30 > EFS Repair successfully INFO : 18/04/2016 17:02:30 > Performed by 2.2.4 software version INFO : 18/04/2016 17:03:03 > ----------------------------------------------------------------------------------- INFO : 18/04/2016 17:03:03 > Platform: Samsung Android INFO : 18/04/2016 17:03:03 > Selected port: COM3 INFO : 18/04/2016 17:03:04 > Selected model: GT-N7105 INFO : 18/04/2016 17:03:34 > Mode: Emergency INFO : 18/04/2016 17:03:35 > Phone was not found on the selected port! INFO : 18/04/2016 17:03:35 > Searching for USB diagnostic port... INFO : 18/04/2016 17:03:35 > Connecting to phone on COM35 INFO : 18/04/2016 17:04:04 > Mode: Emergency WARN : 18/04/2016 17:04:04 > Phone connection failed INFO : 18/04/2016 17:04:04 > Connecting to phone on COM34 INFO : 18/04/2016 17:04:05 > Mode: Normal INFO : 18/04/2016 17:04:06 > Phone model: GT-N7105 INFO : 18/04/2016 17:04:06 > Firmware compiled date: Apr 16 2014 INFO : 18/04/2016 17:04:06 > Firmware compiled time: 16:43:01 INFO : 18/04/2016 17:04:06 > Firmware released date: Apr 16 2014 INFO : 18/04/2016 17:04:06 > Firmware released time: 16:43:01 INFO : 18/04/2016 17:04:06 > SW version: M9615ACEHWMAZD179599 INFO : 18/04/2016 17:04:06 > Old IMEI: 004400-15-202000-0 INFO : 18/04/2016 17:04:06 > New IMEI: Unknown ERROR : 18/04/2016 17:04:06 > Please, enter the new IMEI INFO : 18/04/2016 17:04:06 > Performed by 2.2.4 software version INFO : 18/04/2016 17:04:20 > ----------------------------------------------------------------------------------- INFO : 18/04/2016 17:04:20 > Platform: Samsung Android INFO : 18/04/2016 17:04:20 > Selected port: COM34 INFO : 18/04/2016 17:04:21 > Selected model: GT-N7105 INFO : 18/04/2016 17:04:21 > Mode: Normal INFO : 18/04/2016 17:04:21 > Phone model: GT-N7105 INFO : 18/04/2016 17:04:21 > Firmware compiled date: Apr 16 2014 INFO : 18/04/2016 17:04:21 > Firmware compiled time: 16:43:01 INFO : 18/04/2016 17:04:21 > Firmware released date: Apr 16 2014 INFO : 18/04/2016 17:04:21 > Firmware released time: 16:43:01 INFO : 18/04/2016 17:04:21 > SW version: M9615ACEHWMAZD179599 INFO : 18/04/2016 17:04:21 > Old IMEI: 004400-15-202000-0 INFO : 18/04/2016 17:04:21 > New IMEI: 353845-05-275471-1 INFO : 18/04/2016 17:04:22 > Creating NVM backup INFO : 18/04/2016 17:07:51 > Reading NVM done! INFO : 18/04/2016 17:07:52 > ADB server killed. INFO : 18/04/2016 17:07:53 > Detected phone model: /logcolorGT-N7105\logcolor INFO : 18/04/2016 17:07:53 > Firmware compiled date: /logcolorFri May 16 14:20:54 KST 2014\logcolor INFO : 18/04/2016 17:07:53 > PDA version: /logcolorN7105XXUFNE3\logcolor INFO : 18/04/2016 17:07:53 > CSC version: /logcolorN7105OXXFNE1\logcolor INFO : 18/04/2016 17:07:53 > SW version: /logcolorN7105XXUFND3\logcolor INFO : 18/04/2016 17:07:54 > Phone SN: /logcolor00000000000\logcolor INFO : 18/04/2016 17:07:54 > Android version: /logcolor4.4.2 (KOT49H)\logcolor INFO : 18/04/2016 17:07:54 > Country: /logcolorFrance\logcolor INFO : 18/04/2016 17:07:54 > HW platform: /logcolorexynos4\logcolor INFO : 18/04/2016 17:07:54 > HW Chip: /logcolorsmdk4x12_prime\logcolor INFO : 18/04/2016 17:07:54 > HW Modem: /logcolorMDM9215M\logcolor INFO : 18/04/2016 17:07:54 > Codename: /logcolort0ltexx\logcolor INFO : 18/04/2016 17:07:54 > Cheking Root INFO : 18/04/2016 17:07:55 > Reading security backup, please wait... INFO : 18/04/2016 17:08:06 > Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung\BACKUP\Security-GT-N7105-18-04-2016_17-07-55-.asec file INFO : 18/04/2016 17:08:06 > Erasing old IMEI. It can take some time. Please wait... WARN : 18/04/2016 17:08:27 > Phone will restart now. Please don't disconnect cable! INFO : 18/04/2016 17:09:05 > Firmware compiled date: Apr 16 2014 INFO : 18/04/2016 17:09:05 > Firmware compiled time: 16:43:01 INFO : 18/04/2016 17:09:05 > Firmware released date: Apr 16 2014 INFO : 18/04/2016 17:09:05 > Firmware released time: 16:43:01 INFO : 18/04/2016 17:09:05 > SW version: M9615ACEHWMAZD179599 INFO : 18/04/2016 17:09:05 > Found phone on COM34 INFO : 18/04/2016 17:09:06 > Repairing NVM for GT-N7105 phone... INFO : 18/04/2016 17:09:13 > IMEI successfully repaired. WARN : 18/04/2016 17:09:13 > To finish the operation, please restart the phone via phone's menu. INFO : 18/04/2016 17:09:13 > Performed by 2.2.4 software version INFO : 18/04/2016 17:14:05 > ----------------------------------------------------------------------------------- INFO : 18/04/2016 17:14:05 > Platform: Samsung Android INFO : 18/04/2016 17:14:06 > Selected port: COM34 INFO : 18/04/2016 17:14:06 > Selected model: GT-N7105 INFO : 18/04/2016 17:14:07 > Mode: Normal INFO : 18/04/2016 17:14:07 > Phone model: GT-N7105 INFO : 18/04/2016 17:14:07 > Firmware compiled date: Apr 16 2014 INFO : 18/04/2016 17:14:07 > Firmware compiled time: 16:43:01 INFO : 18/04/2016 17:14:07 > Firmware released date: Apr 16 2014 INFO : 18/04/2016 17:14:07 > Firmware released time: 16:43:01 INFO : 18/04/2016 17:14:07 > Phone IMEI: 353845-05-275471-1 INFO : 18/04/2016 17:14:07 > SW version: M9615ACEHWMAZD179599 INFO : 18/04/2016 17:14:07 > Performed by 2.2.4 software version INFO : 18/04/2016 17:14:17 > ----------------------------------------------------------------------------------- INFO : 18/04/2016 17:14:17 > Platform: Samsung Android INFO : 18/04/2016 17:14:17 > Selected port: COM34 INFO : 18/04/2016 17:14:17 > Selected model: GT-N7105 INFO : 18/04/2016 17:14:18 > Mode: Normal INFO : 18/04/2016 17:14:18 > Phone model: GT-N7105 INFO : 18/04/2016 17:14:18 > Firmware compiled date: Apr 16 2014 INFO : 18/04/2016 17:14:18 > Firmware compiled time: 16:43:01 INFO : 18/04/2016 17:14:18 > Firmware released date: Apr 16 2014 INFO : 18/04/2016 17:14:18 > Firmware released time: 16:43:01 INFO : 18/04/2016 17:14:18 > Phone IMEI: 353845-05-275471-1 INFO : 18/04/2016 17:14:18 > SW version: M9615ACEHWMAZD179599 INFO : 18/04/2016 17:14:18 > Performed by 2.2.4 software version Last edited by Octopus box; 04-18-2016 at 17:55. |
