04-17-2015, 09:43 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: 66 Townsend Ave Age: 38
Member: 770210 Status: Offline Sonork: No Thanks Meter: 46 | GT-S5570 Stuck logo Samsung ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM26 Selected model: GT-S5570 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM26 Mode: Emergency Please put the phone into Download Mode and connect USB cable. To put GT-S5570 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" +"Power"+''Home" keys. Searching for a phone. Please wait... Found phone on Firmware write started. Writing mibib section... mibib section has been written successfully. Writing qcsbl section... qcsbl section has been written successfully. Writing oemsbl section... oemsbl section has been written successfully. Writing amss section... amss section has been written successfully. Writing arm11boot section... arm11boot section has been written successfully. Writing boot.img section... boot.img section has been written successfully. Writing recovery.img section... recovery.img section has been written successfully. Writing system.rfs section... system.rfs section has been written successfully. Writing csc.rfs section... csc.rfs section has been written successfully. Please, restart the phone to apply changes Firmware writing successfully completed. please help |
04-17-2015, 09:45 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Fully charge phone's battery by using external charger, make Factory data reset and wipe cache partition and try to write different firmwares. |
04-17-2015, 10:08 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to re-flash the phone with different firmwares without resetting. If this will not help, try to write Full flash via Jtag. If the problem is still the same - check HW. |
04-17-2015, 10:21 | #9 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Quote:
04-17-2015, 10:25 | #10 (permalink) |
Major Poster Join Date: Apr 2012 Location: spain
Member: 1749539 Status: Offline Sonork: srn_sorinel Thanks Meter: 0 | hi try a hard reset with bottons combination. hold and press together Home button + Power button, until you see Samsung logo.if noting hapens after hard reset can be from the cable of the touchscreen.i have this problem with a samsung galaxy trend lite flashing all the firmware every thing good but stock on samsung logo and after change the touchscreen works fine.thanks and sorry for my english i am from romania. |
04-17-2015, 10:42 | #12 (permalink) | |
Member: 770210 Status: Offline Sonork: No Thanks Meter: 46 | Quote:
04-17-2015, 10:46 | #13 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | To work with Jtag, You should have Jtag Box. |
