04-01-2016, 22:31 | #1 (permalink) |
Junior Member Join Date: Aug 2015
Member: 2443205 Status: Offline Thanks Meter: 1 | [HELP] I9300 Nulled Imei Need Octopus Support Reason of Nulled imei is Wrong firmware flash... Octopus Console shows every task completed... Help Me.. |
04-02-2016, 11:51 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,417 | Hello. Please perform "Read Info" operation from "Android/EFS manager" tab of the Software and post here, or send us in private message, full Software log of the operation. |
04-02-2016, 16:42 | #3 (permalink) |
Member: 2443205 Status: Offline Thanks Meter: 1 | Here it is Platform: Samsung Android Selected port: COM20 Selected model: GT-I9300 Reading info, please wait... Detected phone model: GT-I9300 Firmware compiled date: Tue May 21 18:14:15 KST 2013 PDA version: I9300XXUFME7 CSC version: I9300OXAFME7 SW version: Unknown Android version: 4.2.2 (JDQ39) Performed by 2.2.2 software version |
04-03-2016, 04:07 | #4 (permalink) | |
No Life Poster Join Date: May 2015
Member: 2395490 Status: Offline Thanks Meter: 515 | Quote:
You can do a Downgrade to 4.1.2 and then with the octoplus make a Networ repair. This can help. Or if you cant downgrade then upgrade to 4.3 and then use the I9300_Repair_efs.tar from the octoplus support. I hope this can help you. | |
04-03-2016, 22:16 | #6 (permalink) | |
I hope this can help you. https://www.youtube.com/watch?v=hiU5kpWf0D4 | |
04-04-2016, 11:21 | #7 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,417 | As You can see from Software log, phone's modem part is damaged: Quote:
You should re-flash the device with different firmwares one by one and check, whether modem is correct (not Unknown). And only then (when phone's modem part will be correct) perform "Repair EFS" and "Repair IMEI" operations. It is not possible to repair IMEI, if phone's modem part is damaged. If after writing of all firmwares, which You have, phone's baseband is still null or unknown (SW version is Unknown) - most likely, this is HW problem (problem with eMMC flash chip). | |
04-05-2016, 01:45 | #8 (permalink) |
Member: 2443205 Status: Offline Thanks Meter: 1 | Does flashing Repair Firmware Will help diagnose this problem..?? Coz dialing *#1234# (Version Info) indicates CP is unknown...: AP : I9300XXEMG4 CP : Unknown CSC : I9300OXAEMG4.. |
