04-15-2015, 16:59 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: persian Age: 43
Member: 777729 Status: Offline Sonork: 100.1616470 Thanks Meter: 824 | Help to unlock t217a <at&t> [Solved] ----------------------------------------------------------------------------------- ------------------------------------------------------- Platform: Samsung Android Selected port: COM23 Selected model: SM-T217A Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-T217A Firmware compiled date: Wed Aug 21 01:10:50 KST 2013 PDA version: T217AUCUAMHC CSC version: T217AATTAMHC SW version: T217AUCUAMHC Phone IMEI: 357366051738726 Phone SN: R31DB10NL2P Android version: 4.2.2 (JDQ39) Reading info... Phone was not found on the selected port! Phone unlocking failed need active dm+adb but no phone app in this ver... Last edited by Octopus box; 04-16-2015 at 06:11. |
04-15-2015, 17:52 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please do the next: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to Calculator application. Enter "(+30012012732+" number, to get phone dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "[1]DM/DUM over HS-USB" value. 13. Restart phone. 14. Connect the phone directly to PC. 14. Press "Read Info" on the "Main" tab of the Software. Try to perform "Unlock" and "Read Codes". Post here full Software log of all performed operations. |
04-15-2015, 18:13 | #3 (permalink) |
Member: 777729 Status: Offline Sonork: 100.1616470 Thanks Meter: 824 | Welcome to Octoplus/Octopus Box Samsung software version 1.9.2 ----------------------------------------------------------------------------------- To connect SM-T217A phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to Calculator application. Enter "(+30012012732+" number, to get phone dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "[1]DM/DUM over HS-USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-T217A Reading info, please wait... Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-T217A Firmware compiled date: Wed Aug 21 01:10:50 KST 2013 PDA version: T217AUCUAMHC CSC version: T217AATTAMHC SW version: T217AUCUAMHC Phone IMEI: 357366051738726 Phone SN: R31DB10NL2P Android version: 4.2.2 (JDQ39) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-T217A Reading info... Mode: Normal Firmware compiled date: Jul 23 2013 Firmware compiled time: 07:00:00 Firmware released date: Aug 21 2013 Firmware released time: 01:47:45 SW Version: M8930B-AAAATAZM-5.0.060093 Reading QCN... Send SPC... Reading mobile property... Mobile property read successfully Reading feature mask... Feature mask read successfully Reading roaming list 0 Reading roaming list 0 read successfully Reading NV items... NV items read successfully Reading NV SIM1 items... NV SIM1 items read successfully Reading NV SIM2 items... NV SIM2 items read successfully Reading NV items... NV items read successfully Reading EFS... EFS read successfully Reading provisioning items... Provisioning items read successfully Reading QCN done! QCN read successfully ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-T217A Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-T217A Firmware compiled date: Wed Aug 21 01:10:50 KST 2013 PDA version: T217AUCUAMHC CSC version: T217AATTAMHC SW version: T217AUCUAMHC Phone IMEI: 357366051738726 Phone SN: R31DB10NL2P Android version: 4.2.2 (JDQ39) Reading info... Mode: Normal Firmware compiled date: Jul 23 2013 Firmware compiled time: 07:00:00 Firmware released date: Aug 21 2013 Firmware released time: 01:47:45 SW Version: M8930B-AAAATAZM-5.0.060093 Reading QCN... Send SPC... Reading mobile property... Mobile property read successfully Reading feature mask... Feature mask read successfully Reading roaming list 0 Reading roaming list 0 read successfully Reading NV items... NV items read successfully Reading NV SIM1 items... NV SIM1 items read successfully Reading NV SIM2 items... NV SIM2 items read successfully Reading NV items... NV items read successfully Reading EFS... EFS read successfully Reading provisioning items... Provisioning items read successfully Reading QCN done! Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\QCN-SM-T217A-357366051738726-15-04-2015_20-34-25- .qcn file Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-T217A-357366051738726-15-04-2015_20-35- 58-.asec file Wiping EFS... EFS wipe successfully Phone will restart now. Please don't disconnect cable! Searching for a phone. Please wait... Reading info... Mode: Normal Firmware compiled date: Jul 23 2013 Firmware compiled time: 07:00:00 Firmware released date: Aug 21 2013 Firmware released time: 01:47:45 SW Version: M8930B-AAAATAZM-5.0.060093 Send SPC... SPC send successfully Writing QCN... Writing NV items... NV items write successfully Writing NV SIM1 items... NV SIM1 items write successfully Writing NV SIM2 items... NV SIM2 items write successfully Wrting EFS... EFS write successfully Writing provisioning items... Provisioning items write successfully. Writing QCN done Wipe security successfully complete. Phone will restart now. Please don't disconnect cable! Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) |
The Following User Says Thank You to sirnavid2010 For This Useful Post: |
