04-12-2015, 17:17 | #1 (permalink) |
No Life Poster Join Date: Apr 2014 Location: Worldwide
Member: 2174901 Status: Offline Sonork: 100.1671257 Thanks Meter: 1,248 | How to fix sensor problem in GT-I9060i today we will fix that in simple way Samsung Galaxy Grand Neo Plus GT-I9060I you need to download file from here : Dev-Host - i9060i fix sensor by Hosam Kashto.rar - The Ultimate Free File Hosting / File Sharing Service 1) install super su 2) install flashfiy 3) move boot.img form fix sensor folder to device 4) open flashfiy apk then grant for root 5) choose boot image 6) then you have choose where you have put boot.img file after reset phone the sensor will be work again Last edited by Octopus box; 04-13-2015 at 07:26. |
The Following 2 Users Say Thank You to hosam kashto For This Useful Post: |
04-15-2015, 21:38 | #3 (permalink) |
Member: 2174901 Status: Offline Sonork: 100.1671257 Thanks Meter: 1,248 | Flashfiy not support all flash version Try rashr if any problem when you select boot image from flashfiy |
The Following User Says Thank You to hosam kashto For This Useful Post: |
11-17-2015, 02:04 | #5 (permalink) |
Insane Poster Join Date: Nov 2015
Member: 2487681 Status: Offline Thanks Meter: 6 | You must ensure that sensitive crashes because of the virus across logged in Safe Mode, the problem remained that this situation also Fmhkltk Hardware أرسلت من HUAWEI P7-L10 بإستخدام تاباتلك |
11-17-2015, 09:16 | #6 (permalink) |
No Life Poster Join Date: May 2012 Location: Firmwares
Member: 1761687 Status: Offline Sonork: 100.1669047 Thanks Meter: 494 | why not use prerooted firmware to root this model and stay away from this problem? if anyone want i can make a prerooted firmware for this |
11-17-2015, 17:00 | #7 (permalink) |
Member: 2174901 Status: Offline Sonork: 100.1671257 Thanks Meter: 1,248 | the final kernal avoid all problem just flash in pda part http://www.mediafire.com/download/3p...i_root.tar.rar |
04-27-2016, 10:45 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please perform operations, for which You've needed to root the phone, then reflash the phone. Check whether WiFi will be working correctly after writing of a firmware. |
04-28-2016, 20:19 | #13 (permalink) |
Freak Poster Join Date: Mar 2005 Location: ALEX MY BIG LOVE Age: 45
Member: 129706 Status: Offline Thanks Meter: 23 | i flash the phone no network after that root and repair network network ok and wifi ok after that repair sensor after repair sensor wifi stop thanx |
04-29-2016, 10:59 | #14 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to find and use another root solution for the phone. Currently no other way to fix the problem with sensor caused by root. |
