04-19-2016, 09:07 | #1 (permalink) |
No Life Poster Join Date: Dec 2010 Location: pakistan
Member: 1456426 Status: Offline Sonork: 100.1625000 Thanks Meter: 104 | How to unlock SM-T337T [Solved] ----------------------------------------------------------------------------------- To connect SM-T337T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to Calculator application. Enter "(+30012012732+" number, to get phone dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "[1]DM/DUM over HS-USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-T337T Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM79 Mode: Emergency Phone connection failed No diagnostic ports found! Connecting to phone on COM8 Phone connection failed Performed by 2.2.4 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-T337T Please, press "OK" button on the phone to allow USB debugging.. Operation was canceled Performed by 2.2.4 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-T337T Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-T337T Firmware compiled date: Wed Jun 18 23:04:46 KST 2014 PDA version: T337TUVU1ANF4 CSC version: T337TTMB1ANF4 SW version: T337TUVU1ANF4 Phone IMEI: 355580060277839 Phone SN: RF2FC08FZEV Android version: 4.4.2 (KOT49H) Country: USA HW platform: msm8226 HW Chip: MSM8926 HW Modem: MSM8926 Codename: milletltetmo Updating DIAG confing... DIAG confing is succesfully enabled. Performed by 2.2.4 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-T337T Reading info, please wait... Detected phone model: SM-T337T Firmware compiled date: Wed Jun 18 23:04:46 KST 2014 PDA version: T337TUVU1ANF4 CSC version: T337TTMB1ANF4 SW version: T337TUVU1ANF4 Phone IMEI: 355580060277839 Phone SN: RF2FC08FZEV Android version: 4.4.2 (KOT49H) Country: USA HW platform: msm8226 HW Chip: MSM8926 HW Modem: MSM8926 Codename: milletltetmo Performed by 2.2.4 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-T337T Reading info... Phone was not found on the selected port! Phone unlocking failed Performed by 2.2.4 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-T337T Reading info... Phone was not found on the selected port! Phone unlocking failed Performed by 2.2.4 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-T337T Reading info... Phone was not found on the selected port! Phone unlocking failed Performed by 2.2.4 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-T337T Reading info... Phone was not found on the selected port! Phone unlocking failed Performed by 2.2.4 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM8 Selected model: SM-T337T Reading info... Phone was not found on the selected port! Phone unlocking failed Performed by 2.2.4 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM8 Selected model: SM-T337T Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM79 Mode: Emergency Phone connection failed No diagnostic ports found! Connecting to phone on COM8 Phone connection failed Performed by 2.2.4 software version Last edited by Octopus box; 11-16-2018 at 05:37. |
04-19-2016, 10:43 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please make Factory Reset, then perform all of the following steps: 1. Disconnect USB cable from tab. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to Calculator application. Enter (+30012012732+ number, to get phone dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "[1]DM/DUM over HS-USB" value. 13. Connect the tab directly to PC. 14. Press "Read Info" on "Main" tab of the Software. When tab's info will be read correctly from "Main" tab of the Software - perform "Unlock"/"Fast Unlock" operation. |
04-19-2016, 11:53 | #3 (permalink) |
Member: 1456426 Status: Offline Sonork: 100.1625000 Thanks Meter: 104 | Selected port: COM21 Selected model: SM-T337T Detected phone model: SM-T337T Firmware compiled date: Wed Jun 18 23:04:46 KST 2014 PDA version: T337TUVU1ANF4 CSC version: T337TTMB1ANF4 SW version: T337TUVU1ANF4 Phone IMEI: 355580060277839 Phone SN: RF2FC08FZEV Android version: 4.4.2 (KOT49H) Country: USA HW platform: msm8226 HW Chip: MSM8926 HW Modem: MSM8926 Codename: milletltetmo Rebooting phone in Download Mode... Phone successfully rebooted in Download Mode. Performed by 2.2.4 software version Selected firmware file: CF-Auto-Root-milletltetmo-milletltetmo-smt337t.oct Please put the phone into Download Mode and connect USB cable. To put SM-T337T into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing RECOVERY section... RECOVERY section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Firmware writing successfully completed. Performed by 2.2.4 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-T337T Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM21 Mode: Normal Phone model: SM-T337T Firmware compiled date: Jun 02 2014 Firmware compiled time: 14:00:00 Firmware released date: Jun 18 2014 Firmware released time: 19:26:03 Phone IMEI: 355580-06-027783-9 SW version: MPSS.DI.2.0.c8-00065-M8926DAAAANAZM-1 Performed by 2.2.4 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM21 Selected model: SM-T337T Reading info... Mode: Normal Firmware compiled date: Jun 02 2014 Firmware compiled time: 14:00:00 Firmware released date: Jun 18 2014 Firmware released time: 19:26:03 SW Version: MPSS.DI.2.0.c8-00065-M8926DAAAANAZM-1 Detected phone model: SM-T337T Firmware compiled date: Wed Jun 18 23:04:46 KST 2014 PDA version: T337TUVU1ANF4 CSC version: unknown SW version: T337TUVU1ANF4 Phone SN: RF2FC08FZEV Android version: 4.4.2 (KOT49H) Country: USA HW platform: msm8226 HW Chip: MSM8926 HW Modem: MSM8926 Codename: milletltetmo Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as Security-SM-T337T-19-04-2016_15-50-32 file Unlocking phone... Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu. Performed by 2.2.4 software version |
11-16-2018, 05:36 | #5 (permalink) | ||
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Quote:
