04-15-2015, 06:07 | #1 (permalink) |
Junior Member Join Date: Sep 2014
Member: 2256367 Status: Offline Thanks Meter: 1 | I need to change imei N910t cert file... thanks all I need to change imei N910t cert file Last edited by Octopus box; 04-15-2015 at 06:42. |
04-15-2015, 06:45 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Quote:
1. All Certificates files, which we have, are present in the Support Area (press "Go to Support" button at "Support & Options" tab in the Software) in the folder "Samsung/FOR UNLOCK ANDREPAIR/Certificates/". 2. Currently it is impossible to edit IMEI in the IMEI Certificate file and get working IMEI Certificate. | |
04-15-2015, 08:09 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | You can try to unlock this device via writing IMEI Certificate. Note, in this case, phone's IMEI will be changed to the IMEI from the IMEI certificate file. To write IMEI Certificate, do the next: 1. Root the device. 2. Make Wipe Security. 3. Write IMEI Certificate. |
