04-22-2016, 01:59 | #1 (permalink) |
Junior Member Join Date: Apr 2016
Member: 2559467 Status: Offline Thanks Meter: 0 | I need to file SM- a300m .qcn and .efs Last edited by Octopus box; 04-23-2016 at 11:31. |
04-22-2016, 18:03 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | You can try to use Cert file of SM-A300F from the Support Area, it is compatible with SM-A300M. |
04-22-2016, 18:17 | #5 (permalink) |
Member: 2559467 Status: Offline Thanks Meter: 0 | still leaving only emergency calls, and you load the a300f .cert but I can not solve the problem, the previous certificate was reported , you load several certificates and I can not get out of emergency call |
04-23-2016, 11:32 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Unfortunately we don't have these backups at the moment. You can read QCN from another SM-A300M, which works correctly in your region, then use it for your phone. |
05-27-2016, 19:16 | #8 (permalink) |
Junior Member Join Date: Oct 2013
Member: 2049294 Status: Offline Thanks Meter: 0 | Why you keep asking to use those certificates from support? All of them are blacklist. I don't understand. If you want to sell the certificates, then sell them. Sorry if I'm rude, but I want to use Octoplus in full and not be held back because the certificates don't work. |
05-28-2016, 12:09 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Support Area contains all Cert files, which we have at the moment. We are not selling Cert files. If some of Cert files are blacklisted in your region - You can try to find and use others. We are uploading new Cert files as we receive them. |
