08-15-2018, 16:02 | #1 (permalink) |
No Life Poster Join Date: Oct 2014 Location: Algérie Age: 45
Member: 2269857 Status: Offline Thanks Meter: 364 | I need flash file for SM-J710F [Answered] pls i ned flashe files for repare may phone Welcome to Octoplus Box Samsung software version 2.6.9 Old log files will be deleted Totally 0 files were deleted ----------------------------------------------------------------------------------- To connect SM-J710F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected BOOT file: C:\Users\acer\Desktop\J710FXXU4BQL3 _J710FOXY4BQL3_7.0_walytech.com\BL_J710FXXU4BQL3 _CL12710698_QB16134837_REV03_user_low_ship.tar.md5 Selected AP file: C:\Users\acer\Desktop\J710FXXU4BQL3 _J710FOXY4BQL3_7.0_walytech.com\AP_J710FXXU4BQL3 _CL12710698_QB16134837_REV03_user_low_ship_meta.ta r.md5 Selected CP file: C:\Users\acer\Desktop\J710FXXU4BQL3 _J710FOXY4BQL3_7.0_walytech.com\CP_J710FXXU4BQL3 _CP8372068_CL12710698_QB16134837_REV03 _user_low_ship.tar.md5 Selected CSC file: C:\Users\acer\Desktop\J710FXXU4BQL3 _J710FOXY4BQL3_7.0_walytech.com\CSC_OXY_J710FOXY4B QL3 _CL12710698_QB16134837_REV03_user_low_ship.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-J710F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing PARAM section... PARAM section has been written successfully. Writing CM section... CM section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing USERDATA section... USERDATA section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Writing Firmware Failed Performed by 2.6.9 Software version. Last edited by Octopus box; 08-15-2018 at 16:43. |
08-15-2018, 16:43 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,427 | What is the problem/state of your device exactly? What do You want to repair exactly? What firmware is in your device now and what firmware do You need exactly? |
08-15-2018, 22:02 | #7 (permalink) |
Freak Poster Join Date: Apr 2006 Location: Tacna-Peru
Member: 256299 Status: Offline Thanks Meter: 18 | Just flash the "boot" section of the same firmware, and the phone will turn on. 1- Full flash 2- Flash boot This already happened to me before or use odin |
08-16-2018, 10:22 | #8 (permalink) | |
Member: 2269857 Status: Offline Thanks Meter: 364 | Quote:
----------------------------------------------------------------------------------- To connect SM-J710F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected firmware file: J710FXXU3BQHE_J710FOJV3BQHE_XSG_Android_7.0.oct Please put the phone into Download Mode and connect USB cable. To put SM-J710F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOT section... BOOT section has been written successfully. Firmware writing successfully completed. Performed by 2.7.0 Software version. | |
08-16-2018, 10:36 | #9 (permalink) |
Member: 2269857 Status: Offline Thanks Meter: 364 | 007> Added!! <ID:0/007> Odin engine v(ID:3.1207).. <ID:0/007> File analysis.. <ID:0/007> SetupConnection.. <ID:0/007> Initialzation.. <ID:0/007> Set PIT file.. <ID:0/007> DO NOT TURN OFF TARGET!! <ID:0/007> Get PIT for mapping.. <ID:0/007> Firmware update start.. <ID:0/007> NAND Write Start!! <ID:0/007> SingleDownload. <ID:0/007> sboot.bin <ID:0/007> param.bin <ID:0/007> FAIL! <ID:0/007> <ID:0/007> Complete(Write) operation failed. <OSM> All threads completed. (succeed 0 / failed 1) |
08-18-2018, 10:36 | #11 (permalink) |
Member: 2269857 Status: Offline Thanks Meter: 364 | Welcome to Octoplus Box Samsung software version 2.7.0 ----------------------------------------------------------------------------------- To connect SM-J710F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected AP file: D:\J710FXXU3AQD1_J710FOJW3AQD1 _J710FXXU3AQD3_HOME.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-J710F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing CM section... CM section has been written successfully. Writing Firmware Failed Performed by 2.7.0 Software version. Selected AP file: D:\J710FXXU3AQD1_J710FOJW3AQD1 _J710FXXU3AQD3_HOME.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-J710F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing Firmware Failed Performed by 2.7.0 Software version. Selected AP file: D:\J710FXXU3AQD1_J710FOJW3AQD1 _J710FXXU3AQD3_HOME.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-J710F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Writing CP_DEBUG section... CP_DEBUG section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Writing Firmware Failed Performed by 2.7.0 Software version. Selected AP file: D:\J710FXXU3AQD1_J710FOJW3AQD1 _J710FXXU3AQD3_HOME.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-J710F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Writing CP_DEBUG section... CP_DEBUG section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing Firmware Failed Performed by 2.7.0 Software version. |
