04-17-2015, 00:55 | #1 (permalink) |
No Life Poster Join Date: May 2005 Location: CANADA Age: 42
Member: 149415 Status: Offline Sonork: 100.1609895 Thanks Meter: 77 | i337 repair imei Failed Selected port: COM10 Selected model: SGH-I337M Detected phone model: SGH-I337M Firmware compiled date: Fri May 2 21:24:14 KST 2014 PDA version: I337MVLUFNE1 CSC version: I337MOYAFNE2 SW version: Unknown Phone IMEI: Unknown Android version: 4.4.2 (KOT49H) Cheking Root Phone is Rooted Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SGH-I337M-16-04-2015_19-47-32-.asec file Deactivating MSL... MSL deactivate successfully Phone will restart now. Please don't disconnect cable! After phone being rebooted and powered on perform the following steps: 1. Disconnect USB cable. 2. Wait 1-2 minutes. 3. Connect phone via UART cable to Box. Connecting to phone, please wait... Found phone on COM38 Phone connected successfully Writing new phone IMEI... IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) still nul/nul |
04-17-2015, 06:30 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | As You can see from your Software log, phone's modem part is damaged: Quote:
It is not possible to repair IMEI, if phone's modem part is damaged. Please re-flash the phone with different firmwares and after writing each firmware check, whether modem is correct (not Unknown). And only then (when phone's modem part will be correct) perform the "Repair IMEI" operation. | |
04-17-2015, 15:02 | #3 (permalink) |
Member: 149415 Status: Offline Sonork: 100.1609895 Thanks Meter: 77 | I use this firmware for all my i337m need flash its original firmware downloaded from samsungfirmware do you have any idea which firmware can I use ? thanks |
04-17-2015, 15:04 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to write different firmwares from the Support Area and after writing each firmware, check, whether modem is correct (not Unknown). |
