05-28-2015, 13:50 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: sri lanka Age: 35
Member: 716976 Status: Offline Sonork: 100.1674578 Thanks Meter: 108 | I8552 samsung logo only Welcome to Octoplus/Octopus Box Samsung software version 1.9.6 Selected firmware file: I8552XXAMDB_I8552ODDAMD9_INU_Adnroid_ 4.1.2.oct Please put the phone into Download Mode and connect USB cable. To put GT-I8552 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing Firmware Failed Please put the phone into Download Mode and connect USB cable. To put GT-I8552 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing Firmware Failed |
05-28-2015, 14:57 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,418 | Hello. Please fully charge phone's battery and try to re-flash the phone with different firmwares. If problem will remain the same with different firmwares, then, most likely, your phone has HW problem. |
05-28-2015, 15:02 | #3 (permalink) | |
No Life Poster Join Date: Jan 2010 Location: Kushtia,Bangladesh Age: 36
Member: 1217358 Status: Offline Sonork: 100.1605541 Thanks Meter: 156 | Quote:
The Following User Says Thank You to alpona_su For This Useful Post: |
