04-19-2015, 08:23 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: world
Member: 573962 Status: Offline Sonork: 100.1603021 Thanks Meter: 480 | i9103 flashing error pls check [Solved] ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9103 Repairing... To connect GT-I9103 phone, please perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume UP"+"Home" for 10 second. 3. Insert USB cable. Searching phone... Phone found. Sending loaders... Loader send successfuly. Creating Boot Config Table section Section Boot Config Table creat successfully Creating Partition Table section Section Partition Table creat successfully Creating Fastboot section Section Fastboot creat successfully Creating Master Boot Record section Section Master Boot Record creat successfully Creating System section Section System creat successfully Creating EFS section Section EFS creat successfully Creating SOS section Section SOS creat successfully Creating Linux kernel section Section Linux kernel creat successfully Creating APP section Section APP creat successfully Creating CAC section Section CAC creat successfully Creating MSC section Section MSC creat successfully Creating MDM section Section MDM creat successfully Creating User data A section Section User data A creat successfully Creating OTA section Section OTA creat successfully Creating HID section Section HID creat successfully Creating GPT section Section GPT creat successfully Formating Boot Config Table section Section Boot Config Table format successfully Formating Partition Table section Section Partition Table format successfully Formating Fastboot section Section Fastboot format successfully Formating Master Boot Record section Section Master Boot Record format successfully Formating System section Section System format successfully Formating EFS section Section EFS format successfully Formating SOS section Section SOS format successfully Formating Linux kernel section Section Linux kernel format successfully Formating APP section Section APP format successfully Formating CAC section Section CAC format successfully Formating MSC section Section MSC format successfully Formating MDM section Section MDM format successfully Formating User data A section Section User data A format successfully Formating OTA section Section OTA format successfully Formating HID section Section HID format successfully Formating GPT section Section GPT format successfully Updating data, plaese wait... Updating data successfully completed. Phone successfuly repair, please write firmware, make Factory reset and enter corect IMEI Phone repair successfuly after flash phone via support aria flash file Please, select firmware file first! Selected firmware file: I9103XWLP8_I9103ODDLP6_I9103DDLP3 _HOME.oct Please put the phone into Download Mode and connect USB cable. To put GT-I9103 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing MDM section... MDM section has been written successfully. Writing Firmware Failed |
04-19-2015, 09:38 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Fully charge phone's battery by using external charger, connect the phone directly to PC motherboard USB port (don't use any USB hubs, this is important) and try to write firmware again. Try to write different firmwares. |
04-19-2015, 10:51 | #4 (permalink) |
Member: 573962 Status: Offline Sonork: 100.1603021 Thanks Meter: 480 | i have allready fully charge battery and no extrnal hub. before flashing phone problem not open gallery. problem solved with change charjing clip |
