04-15-2015, 15:48 | #1 (permalink) |
Junior Member Join Date: Apr 2015
Member: 2379435 Status: Offline Thanks Meter: 5 | I9300 Writing IMEI failed after "executing exploit" i tried to change the firmware, re-rooted many times, made hard reset, started all again, but could not pass the "executing exploit" task. IMEI on phone shows null/null. Octopus log: "Plataforma: Samsung Android Porto seleccionado: COM7 Modelo seleccionado: GT-I9300 Modelo do telefone detectado: GT-I9300 Data de criação do firmware: Thu May 15 20:52:48 KST 2014 PDA version: I9300UBUGNE1 CSC version: I9300ZTOUGNE1 Versão do SW: Unknown IMEI do telefone: Unknown Android version: 4.3 (JSS15J) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP\Security-GT-I9300-Unknown15-04-2015_10-39-34- . asec file Cheking security type... New security type is detected IMEI antigo: Unknown Novo IMEI: 355409-04-651290-5 Repairing IMEI ... Executing exploit... Write IMEI failed". I'm trying to check another firmware, this time from support area, but the website doen't wanna open. It may be my connection. What should i do next? |
04-15-2015, 17:58 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. As You can see from your Software log, phone's modem part is damaged: Quote:
You should re-flash the device with different firmwares and check, whether modem is correct (not Unknown). And only then (when phone's modem part will be correct) perform "Repair EFS" and "Repair IMEI" operations. It is not possible to repair IMEI, if phone's modem part is damaged. If after of writing all firmwares, which You have, phone's baseband is still null or unknown (SW version is Unknown) - most likely, this is HW problem (problem with eMMC flash chip). | |
04-18-2015, 15:46 | #3 (permalink) |
Member: 2379435 Status: Offline Thanks Meter: 5 | I tried 2 other firmwares and several prodecures, again and again, and the SW Version continued "unknown", so IMEI Re-Writing always failed, even repairing network, EFS and everything. As i said, I tried several procedures... I gave this up. It must be hardware problem. Thanks for the support, mate! |
