04-24-2016, 07:35 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: mt brazil
Member: 211017 Status: Offline Thanks Meter: 312 | I9300I freeze logo samsung e:failed to mount / cache e:failed to mount /cache /recovery e:failed to mount /data ..... all error Welcome to Octoplus/Octopus Box Samsung software version 2.2.5 ----------------------------------------------------------------------------------- To connect GT-I9505 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect GT-I9300I phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM12 Selected model: GT-I9300I Searching for a phone. Please wait... Read KeyID was canceled Performed by 2.2.5 software version Selected firmware file: AP_I9300IUBUANG3_2721944_REV00 _user_low_ship_MULTI_CERT.oct Please put the phone into Download Mode and connect USB cable. To put GT-I9300I into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing PIT section... PIT section has been written successfully. Writing SBL1 section... SBL1 section has been written successfully. Writing ABOOT section... ABOOT section has been written successfully. Writing RPM section... RPM section has been written successfully. Writing TZ section... TZ section has been written successfully. Writing DBI section... DBI section has been written successfully. Writing APNHLOS section... APNHLOS section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing PERSIST section... PERSIST section has been written successfully. Writing MODEM section... MODEM section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. Performed by 2.2.5 software version |
04-24-2016, 19:41 | #2 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Wipe Factory reset and Cache from Recovery and Reflash. If get same Error, try with Other Stock Rom for this phone P.Code with Odin, always Wipe Factory reset and cache from Recovery Mode. Post result BR allumts |
04-25-2016, 10:44 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. As suggested mr.allumts, please try to make Factory Reset and Wipe cache partition from Recovery Mode, then try to write different firmwares. |
