04-20-2015, 11:19 | #1 (permalink) |
Freak Poster Join Date: Sep 2010
Member: 1390215 Status: Offline Thanks Meter: 11 | I9305 LTE unlocking Wipe Reflash 4.3 from support Root Make steeps from software. And have this log. Code: Bienvenido en Octoplus/Octopus Box Samsung software versión 1.9.2 ----------------------------------------------------------------------------------- To connect GT-I9305 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "MODEM" value. 8. Go to "Qualcomm USB Settings". 9. Select "RNDIS+DM+MODEM". 10. Enter "*#9090#" number. 11. Select DM/DUM over HS-USB. 12. Press Home button. 13. Go to dial window. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM45 Modelo seleccionado: GT-I9305 Modo: Normal Modelo del teléfono: GT-I9305 Fecha de creación del firmware: Dec 21 2012 Tiempo de compilación del firmware: 03:00:00 Fecha de salida del firmware: Jan 6 2014 Tiempo de salida del firmware: 15:37:36 IMEI del teléfono: 353575-05-185695-7 Versión del SW: M9615ACEHWMAZD179599 Liberando el teléfono... Reading security failed La liberación del teléfono ha sido fallada |
04-20-2015, 11:51 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Make Factory data reset, wipe cache partition, root the phone with another Software/Exploit and perform the Unlock operation again. You need press "Ok/Allow/Grant" button on every pop-up dialogue, which may appear on phone's screen during the operation. Post here the result. |
