04-25-2016, 14:12 | #1 (permalink) |
Freak Poster Join Date: Aug 2011 Location: nepal
Member: 1635479 Status: Offline Thanks Meter: 122 | i9500 baseband unknown 5.0.1 help??? |
04-25-2016, 14:17 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please try to do exactly the next: 1. Make Repair EFS. 2. Re-flash the phone. 3. Make Repair IMEI (write service IMEI from the Software list, not any IMEI). 4. Re-flash the phone again. 5. Re-start the phone, search and select network manually. Post here result and full Software log with all of your actions. |
05-05-2016, 09:29 | #3 (permalink) |
Crazy Poster Join Date: Jan 2007
Member: 426997 Status: Offline Thanks Meter: 2 | I9500 Imei 00449.. Hi, I followed all the steps. Please try to do exactly the next: 1. Make Repair EFS. 2. Re-flash the phone. 3. Make Repair IMEI (write service IMEI from the Software list, not any IMEI). 4. Re-flash the phone again. 5. Re-start the phone, search and select network manua I did the EFS repair, n flash Welcome to Octoplus/Octopus Box Samsung software version 2.2.4 ----------------------------------------------------------------------------------- To connect GT-I9500 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM7 Selected model: GT-I9500 To put GT-I9500 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Repairing EFS... Searching for a phone. Please wait... Phone found. EFS Repair successfully Performed by 2.2.4 software version Selected firmware file: I9500XXUHOH6_I9500OJVHOG3_LYS_Android_5.0.1 (1).oct Please put the phone into Download Mode and connect USB cable. To put GT-I9500 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. on the software below it shows done here is the log CSC version: I9500OJVHOG3 SW version: I9500XXUHOG2 Phone SN: RF1D45EJGGR Android version: 5.0.1 (LRX22C) Country: KSA HW platform: exynos5 HW Chip: exynos5410 HW Modem: XMM6360 Codename: ja3gxx Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP\Security-GT-I9500-Unknown04- 05-2016_19-18-11-.asec file Cheking security type... New security type is detected Executing exploit... Exploit has been executed successfully Old IMEI: Unknown New IMEI: 352993-05-004637-4 Repairing IMEI ... Repairing network. Please wait, this can take some time... Network is successfully repaired Phone will restart now. Please don't disconnect cable! IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu. Performed by 2.2.4 software version. after this i flashed again Please put the phone into Download Mode and connect USB cable. To put GT-I9500 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. Performed by 2.2.4 software version I restart the phone. With sim card inserted phone shows. (sIM NETWORK UNLOCK pIN) iMEI IS STILL 00449... What is it that i am doing wrong. thanks |
05-06-2016, 12:16 | #6 (permalink) |
Member: 426997 Status: Offline Thanks Meter: 2 | I9500 imei 00499 fixed Thanks guys for the reply. Hi, i9500 imei fixed. In the backup folder i found the security file (Security-GT-I9500-29-04-2016_08-19-18.asec) 1. On the software got to write security 2. I selected this file. 3.After security write finished 4.Restart the phone. Imei is back to normal here is the log Welcome to Octoplus/Octopus Box Samsung software version 2.2.4 ----------------------------------------------------------------------------------- To connect GT-I9500 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: GT-I9500 Detected phone model: GT-I9500 Firmware compiled date: Tue Aug 25 19:15:41 KST 2015 PDA version: I9500XXUHOH6 CSC version: I9500OJVHOG3 SW version: I9500ZCUJOA3 Phone SN: RF1D45EJGGR Android version: 5.0.1 (LRX22C) Country: KSA HW platform: exynos5 HW Chip: exynos5410 HW Modem: XMM6360 Codename: ja3gxx Writing security backup, please wait... Phone will restart now. Please don't disconnect cable! Security write successfully. Performed by 2.2.4 software version |
