11-07-2013, 12:47 | #1 (permalink) |
Freak Poster Join Date: Feb 2007 Location: pakistan
Member: 445943 Status: Offline Thanks Meter: 25 | i9505 can't unlock, pls help [Solved] ----------------------------------------------------------------------------------- To connect GT-I9505 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Builds numbers" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Close window. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM114 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Mar 28 2013 Firmware compiled time: 09:00:00 Firmware released date: May 30 2013 Firmware released time: 01:50:32 Phone IMEI: 357506-########### SW Version: M9615A-CEFWTAZM-4.0.17062 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM114 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Mar 28 2013 Firmware compiled time: 09:00:00 Firmware released date: May 30 2013 Firmware released time: 01:50:32 Phone IMEI: 357506-######### SW Version: M9615A-CEFWTAZM-4.0.17062 Unlocking phone... Reading security failed Phone unlocking failed Last edited by Octopus box; 11-07-2013 at 13:54. |
11-07-2013, 13:06 | #2 (permalink) | |
Freak Poster Join Date: Dec 2008
Member: 917355 Status: Offline Thanks Meter: 25 | Quote:
Have fun!!!!!!!!!!!!!!!!!!!!!! | |
11-07-2013, 13:21 | #3 (permalink) |
Member: 445943 Status: Offline Thanks Meter: 25 | Welcome to Octoplus/Octopus Box Samsung software version 1.4.0 ----------------------------------------------------------------------------------- To connect GT-I9505 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Builds numbers" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Close window. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. Selected firmware file: For_Unlock_GT-I9505.oct Please switch your phone to the download mode and connect it to a PC. To put GT-I9505 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing MDM section... MDM section has been written successfully. Firmware writing successfully completed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I9505 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM114 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Mar 28 2013 Firmware compiled time: 09:00:00 Firmware released date: Apr 12 2013 Firmware released time: 00:04:45 Phone IMEI: 357506-####### SW Version: M9615A-CEFWTAZM-4.0.17062 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM114 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Mar 28 2013 Firmware compiled time: 09:00:00 Firmware released date: Apr 12 2013 Firmware released time: 00:04:45 Phone IMEI: 357506-######### SW Version: M9615A-CEFWTAZM-4.0.17062 Unlocking phone... Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) |
11-07-2013, 13:21 | #4 (permalink) |
