11-07-2013, 06:35 | #1 (permalink) |
No Life Poster Join Date: Dec 2007 Location: .........
Member: 665025 Status: Offline Thanks Meter: 44 | i9505 can't unlock, pls help team,. [Solved] have downloaded unlock i9505 from support, success flashing and success unlocking logs but the device still asking for network lock,. also tried read codes and enter manually, the device says that successfully unlock but after reboot, still ask for network lock,. Welcome to Octoplus/Octopus Box Samsung software version 1.4.0 ----------------------------------------------------------------------------------- To connect GT-I9505 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Builds numbers" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Close window. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. Selected firmware file: For_Unlock_GT-I9505.oct Please switch your phone to the download mode and connect it to a PC. To put GT-I9505 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing MDM section... MDM section has been written successfully. Firmware writing successfully completed. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM17 Selected model: GT-I9505 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM36 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Mar 28 2013 Firmware compiled time: 09:00:00 Firmware released date: Apr 12 2013 Firmware released time: 00:04:45 Phone IMEI: 356845-05-610873-9 SW Version: M9615A-CEFWTAZM-4.0.17062 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM36 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Mar 28 2013 Firmware compiled time: 09:00:00 Firmware released date: Apr 12 2013 Firmware released time: 00:04:45 SW Version: M9615A-CEFWTAZM-4.0.17062 Old IMEI: 356845-05-610873-9 New IMEI: 356845-05-610873-9 Please, enter the new IMEI ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM36 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Mar 28 2013 Firmware compiled time: 09:00:00 Firmware released date: Apr 12 2013 Firmware released time: 00:04:45 Phone IMEI: 356845-05-610873-9 SW Version: M9615A-CEFWTAZM-4.0.17062 Unlocking phone... Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM36 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Mar 28 2013 Firmware compiled time: 09:00:00 Firmware released date: Apr 12 2013 Firmware released time: 00:04:45 Phone IMEI: 356845-05-610873-9 SW Version: M9615A-CEFWTAZM-4.0.17062 Creating NVM backup Reading NVM done! Repairing NVM for GT-I9505 phone... NVM repair completed successfully Please, restart the phone to apply changes ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM36 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Mar 28 2013 Firmware compiled time: 09:00:00 Firmware released date: Apr 12 2013 Firmware released time: 00:04:45 Phone IMEI: 356845-05-610873-9 SW Version: M9615A-CEFWTAZM-4.0.17062 Unlocking phone... Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM36 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Mar 28 2013 Firmware compiled time: 09:00:00 Firmware released date: Apr 12 2013 Firmware released time: 00:04:45 Phone IMEI: 356845-05-610873-9 SW Version: M9615A-CEFWTAZM-4.0.17062 Reading phone unlock codes. It can take some time, please wait... Connecting to server... Connect successfully to server Checking smart card... Smart card successfully checked Checking operation... Operation successfully checked NCK unlock code: *#7465625*638*29697479# NSCK unlock code: *#7465625*782*00000000# SPCK unlock code: *#7465625*77*00000000# pls help team,.. Last edited by Octopus box; 11-09-2013 at 12:22. |
11-07-2013, 08:24 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please try to enter unlockig code again, then make Repair NVM, then make Factory Reset and say us the result, whether the phone still asks network code. |
11-07-2013, 12:26 | #3 (permalink) |
Member: 665025 Status: Offline Thanks Meter: 44 | Welcome to Octoplus/Octopus Box Samsung software version 1.4.0 ----------------------------------------------------------------------------------- To connect GT-S5830 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#9090#" number. 7. Set "Diag config" to "USB" value. 8. Restart phone. 9. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect GT-I9505 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Builds numbers" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Close window. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM17 Selected model: GT-I9505 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM36 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Mar 28 2013 Firmware compiled time: 09:00:00 Firmware released date: Apr 12 2013 Firmware released time: 00:04:45 Phone IMEI: 356845-05-610873-9 SW Version: M9615A-CEFWTAZM-4.0.17062 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM36 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Mar 28 2013 Firmware compiled time: 09:00:00 Firmware released date: Apr 12 2013 Firmware released time: 00:04:45 Phone IMEI: 356845-05-610873-9 SW Version: M9615A-CEFWTAZM-4.0.17062 Creating NVM backup Reading NVM done! Repairing NVM for GT-I9505 phone... NVM repair completed successfully Please, restart the phone to apply changes ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM36 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Mar 28 2013 Firmware compiled time: 09:00:00 Firmware released date: Apr 12 2013 Firmware released time: 00:04:45 Phone IMEI: 356845-05-610873-9 SW Version: M9615A-CEFWTAZM-4.0.17062 still in sim invalid and asking for lock code,. actually after flashing the unlock_i9505, the device lost its signal even with its original carrier sim,. how can i bring back the signal and also unlock it,. locked with GLOBE philippines,. |
11-07-2013, 12:39 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please try to reflash the phone with different firmware, then repeat unlock and post results. |
11-08-2013, 03:01 | #5 (permalink) | |
Member: 665025 Status: Offline Thanks Meter: 44 | Quote:
I9505XXUAMDI_I9505TSIAMD8 I9505XXUAME2_VFGAMDC I9505XXUBMGA_OXABMGA I9505XXUAMDM_OXAAMDM still no luck,.huhuhuhuh | |
11-08-2013, 10:31 | #7 (permalink) |
Member: 665025 Status: Offline Thanks Meter: 44 | pls help,. ive already flash it with 4.3 version, success but imei null, unknown baseband,. huhuhu,. pls help me guys how to bring it back even in normal or locked on its carrier,. |
11-09-2013, 12:18 | #10 (permalink) |
Member: 665025 Status: Offline Thanks Meter: 44 | DONE with this procedure: 1-stay on 4.3 version bcoz u can't downgrade it,. -result: imei null/unknown baseband 2-flash unlock_i9505 from support -result: imei back to normal and normal baseband -but still no signal on all sim,.. -but it can detect now by octo sftware 3-root device 4-repair security-ime became 0044,..etc,.. 5-repair imei 6-signal and unlock done,. PROBLEM: fluctuating signal when lte/cdma/gsm selected -steady signal only on GSM network,. but the problem is, my customer always uses mobile internet, and it has lower internet on GSM network,. can someone again help me to fix the signal with lte/cdma/gsm selection,.. |
