04-20-2015, 11:48 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Do the next: 1. Enable "USB Debugging" option. 2. Connect the phone directly to PC. 3. Perform "Read Info" operation from "Android/EFS manager" tab of the Software. Post here full Software log of "Read Info" operation. |
04-20-2015, 11:57 | #3 (permalink) |
Freak Poster Join Date: Jul 2011 Location: algeria
Member: 1608543 Status: Offline Thanks Meter: 8 | Detected phone model: GT-I9505 Firmware compiled date: Thu May 30 01:05:23 KST 2013 PDA version: I9505XXUBMEA CSC version: I9505OXXBMF1 SW version: Unknown Phone IMEI: Unknown Phone SN: RF1D45QY9FJ Android version: 4.2.2 (JDQ39) |
04-20-2015, 12:05 | #4 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | As You can see from this Software log, modem part is damaged in your device: Quote:
At first, try re-flash the device with different firmwares and check, whether modem is correct (not Unknown). It is not possible to repair IMEI, if phone's modem part is damaged. | |
04-20-2015, 12:17 | #6 (permalink) |
Freak Poster Join Date: Mar 2005 Location: turikye geziy antip Age: 44
Member: 124496 Status: Offline Thanks Meter: 19 | Install the modem file will work, but if you can not solve the problem answering disassembly and modem |
The Following User Says Thank You to matrex80 For This Useful Post: |
04-21-2015, 09:02 | #7 (permalink) |
Member: 1608543 Status: Offline Thanks Meter: 8 | i flash many time with other firmwars and wont turn on it show after samsung logo i have this "system software not authorized by samsung has been fount on your phone" Found phone on Firmware write started. Writing ABOOT section... ABOOT section has been written successfully. Writing TZ section... TZ section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing MDM section... MDM section has been written successfully. Writing APNHLOS section... APNHLOS section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. |
04-21-2015, 09:27 | #8 (permalink) |
Freak Poster Join Date: Apr 2015 Location: IN INDIA
Member: 2372600 Status: Offline Sonork: 100.1663659,ICQ-670897523 Thanks Meter: 49 | Hi, if you try some firmware but imei & baseband null ,it is hw problem |
The Following User Says Thank You to Octopusindia For This Useful Post: |
04-21-2015, 11:59 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to write all available firmwares one by one. If after writing all firmwares problem will remain the same, then, most likely, this is HW problem. |
