10-13-2013, 09:31 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | @ spy112 Hello. What is the state of your phone exactly? Why IMEI is Null (after which actions it became Null)? At first, try to re-flash the phone with the firmware "9505XXUBMF8_I9505OJVBMF3_United_Arab_Emirates_(Et isalat)_Android_4.2.2.oct" from the Support Area and then try to make Repair IMEI. Then post the result here. |
10-14-2013, 08:29 | #4 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: cameroon
Member: 260658 Status: Offline Thanks Meter: 184 | Quote:
thk's in advance | |
10-14-2013, 08:56 | #5 (permalink) |
Member: 260658 Status: Offline Thanks Meter: 184 | my phone only show emergengy mode see log please: Welcome to Octoplus/Octopus Box Samsung software version 1.3.7 ----------------------------------------------------------------------------------- To connect SC-01C phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When the message appears press "Yes". 5. Connect USB cable to the phone. 6. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect GT-I9505 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Builds numbers" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options->About Device. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Close window. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM11 Selected model: GT-I9505 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM21 Mode: Emergency ----------------------------------------------------------------------------------- -When i launch on tab Android/EFS manager an clip info, it show this log: Platform: Samsung Android Selected port: COM20 Selected model: GT-I9505 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM21 Mode: Emergency Platform: Samsung Android Selected port: COM21 Selected model: GT-I9505 Reading info, please wait... Detected phone model: GT-I9505 Firmware compiled date: Tue Aug 13 13:30:03 KST 2013 Phone SN: R21D47RFGFR Android version: 4.2.2 (JDQ39) please help to unlock this phone |
10-14-2013, 09:15 | #6 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please try to connect your phone via USB (and, if the phone doesn't connect via USB cabele, connect the phone via Samsung Micro UART C3303k cable). To connect GT-I9505 phone via USB cable you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Builds numbers" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options->About Device. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Close window. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "[1]DM/DUN over HS-USB" value. 13. Restart phone. 14. Press "Read Info" in software. To connect GT-I9505 phone via UART cable you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Builds numbers" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options->About Device. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Close window. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "[4]DM over UART" value. 13. Restart phone. 14. Press "Read Info" in software. If the phone is successfully connected, to unlock the phone You need to downgrade phone's firmware (write "For_Unlock_GT-I9505" firmware from the Support Area) and then make Unlock. Quote:
10-15-2013, 09:08 | #7 (permalink) |
Member: 260658 Status: Offline Thanks Meter: 184 | @Sir, phone unlocked Platform: Samsung Android Selected port: COM3 Selected model: GT-I9505 Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM3 Phone connection failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Mar 28 2013 Firmware compiled time: 09:00:00 Firmware released date: Apr 12 2013 Firmware released time: 00:04:45 Phone IMEI: 356843-05-341043-0 SW Version: M9615A-CEFWTAZM-4.0.17062 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: 1309:00:00A Firmware compiled time: CEFWTAZ* Firmware released date: 1300:04:45M Firmware released time: ar 28 20 Phone IMEI: 356843-05-341043-0 SW Version: M9615A-CEFWTAZM-4.0.17062 Reading phone unlock codes. It can take some time, please wait... Connecting to server... Connect successfully to server Checking smart card... Smart card successfully checked Checking operation... Operation successfully checked NCK unlock code: *#7465625*638*95925093# NSCK unlock code: *#7465625*782*00000000# SPCK unlock code: *#7465625*77*00000000# thank you |
The Following 2 Users Say Thank You to nyakam For This Useful Post: |
