04-17-2016, 21:17 | #1 (permalink) |
No Life Poster Join Date: Mar 2002 Location: Europe, Lemberstadt Age: 53
Member: 9889 Status: Offline Thanks Meter: 50 | i9505 imei repair problem Successfully rooted via Kingo After unlock IMEI /01 *#0011#- IMEI CERTI: NA Read info from Main tab: Code: Platform: Samsung Android Selected port: COM48 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Feb 12 2015 Firmware compiled time: 22:00:00 Firmware released date: Apr 22 2015 Firmware released time: 21:56:58 Incorrect IMEI SW version: M9615A-CEFWTAZM-4.0.17191 Performed by 2.2.4 software version Code: Platform: Samsung Android Selected port: COM48 Selected model: GT-I9505 Reading info, please wait... Detected phone model: GT-I9505 Firmware compiled date: Wed Apr 22 20:50:32 KST 2015 PDA version: I9505XXUHOD7 CSC version: I9505EVRHOD1 SW version: I9505XXUHOD7 Phone SN: RV1D53Q58SZ Android version: 5.0.1 (LRX22C) Country: UK HW platform: msm8960 HW Chip: apq8064 HW Modem: MDM9215M Codename: jfltexx Code: Platform: Samsung Android Selected port: COM48 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Feb 12 2015 Firmware compiled time: 22:00:00 Firmware released date: Apr 22 2015 Firmware released time: 21:56:58 SW version: M9615A-CEFWTAZM-4.0.17191 Old IMEI: 004400-15-202000-0 New IMEI: 356844-05-xxxxxx-9 Write IMEI failed Performed by 2.2.4 software version Try write "GT-i9505_for_Unlock_and_IMEI_repair" Code: Selected firmware file: GT-I9505_for_Unlock_and_IMEI_repair.oct Please put the phone into Download Mode and connect USB cable. To put GT-I9505 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing Firmware Failed Performed by 2.2.4 software version |
04-18-2016, 10:45 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please fully charge phone's battery, then try to write "GT-i9505_for_Unlock_and_IMEI_repair" firmware again. |
04-18-2016, 12:15 | #3 (permalink) |
Member: 9889 Status: Offline Thanks Meter: 50 | add charging bat and try flashing again Code: Selected firmware file: GT-I9505_for_Unlock_and_IMEI_repair.oct Please put the phone into Download Mode and connect USB cable. To put GT-I9505 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing MDM section... MDM section has been written successfully. Writing Firmware Failed Performed by 2.2.4 software version after restart battery PC connection on lcd what correct steps now - reflashing stock firmware or ? |
04-18-2016, 13:35 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to reflash the phone with "i9505xxuhoj2_i9505oxahoj2_dbt_android_5.0.1" firmware from the Support Area, then check whether it powers on correctly. Try to perform "Repair IMEI" operation again after reflashing. Post here the result. |
04-20-2016, 19:11 | #5 (permalink) |
Member: 9889 Status: Offline Thanks Meter: 50 | i cant flash any of files frim support i tried flash by odin original tar firmware - allways getting error (pit not selected) <ID:0/051> Added!! <ID:0/051> Odin v.3 engine (ID:51).. <ID:0/051> File analysis.. <ID:0/051> SetupConnection.. <ID:0/051> Initialzation.. <ID:0/051> Get PIT for mapping.. <ID:0/051> There is no PIT partition. <OSM> All threads completed. (succeed 0 / failed 1) <ID:0/051> Removed!! <ID:0/051> Added!! phone still access download mode any idea? |
04-21-2016, 10:34 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | What problem with writing of "i9505xxuhoj2_i9505oxahoj2_dbt_android_5.0.1" firmware from the Support Area You've faced exactly? Please post here full Software log of operation. |
04-21-2016, 11:27 | #7 (permalink) |
Member: 9889 Status: Offline Thanks Meter: 50 | Code: Selected firmware file: i9505xxuhoj2_i9505oxahoj2_dbt_android_ 5.0.1.oct Please put the phone into Download Mode and connect USB cable. To put GT-I9505 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing Firmware Failed Performed by 2.2.4 software version phone still stay in DM looks like bootloader totally locked?? |
04-21-2016, 12:07 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to re-install Samsung USB drivers, try to use different USB ports of PC motherboard for connection. |
04-21-2016, 16:58 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please check phone's HW. If problem remains the same on another PC during attempts to write a firmware with Octoplus Samsung Software and with Odin - most likely device has HW issues. |
