04-24-2016, 03:03 | #1 (permalink) |
Freak Poster Join Date: Apr 2009 Location: morocco
Member: 1012961 Status: Offline Thanks Meter: 37 | imei nul note3 n900 how to repair Please ----------------------------------------------------------------------------------- To connect SM-N900 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM20 Selected model: SM-N900 Searching for a phone. Please wait... ADB server killed. Phone found. Firmware compiled date: Fri Dec 18 00:53:07 KST 2015 PDA version: N900XXUEBOL2 CSC version: N900OJVEBOL1 SW version: Unknown Phone IMEI: Unknown Phone SN: RF1D96R0VSE Android version: 5.0 (LRX21V) Performed by 2.2.3 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM20 Selected model: SM-N900 Detected phone model: SM-N900 Firmware compiled date: Fri Dec 18 00:53:07 KST 2015 PDA version: N900XXUEBOL2 CSC version: N900OJVEBOL1 SW version: Unknown Phone SN: RF1D96R0VSE Android version: 5.0 (LRX21V) Checking Root: Phone is not Rooted. Write IMEI failed Performed by 2.2.3 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM20 Selected model: SM-N900 Please, press "OK" button on the phone to allow USB debugging.. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Write IMEI failed Performed by 2.2.3 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM20 Selected model: SM-N900 Please, press "OK" button on the phone to allow USB debugging.. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Write IMEI failed Performed by 2.2.3 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM20 Selected model: SM-N900 Please, press "OK" button on the phone to allow USB debugging.. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Write IMEI failed Performed by 2.2.3 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM20 Selected model: SM-N900 Please, press "OK" button on the phone to allow USB debugging.. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Write IMEI failed Performed by 2.2.3 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM20 Selected model: SM-N900 Detected phone model: SM-N900 Firmware compiled date: Fri Dec 18 00:53:07 KST 2015 PDA version: N900XXUEBOL2 CSC version: N900OJVEBOL1 SW version: Unknown Phone SN: RF1D96R0VSE Android version: 5.0 (LRX21V) Checking Root: Phone is Rooted. Reading security backup, please wait... Phone will restart now. Please don't disconnect cable! After phone being rebooted and powered on perform the following steps: 1. Disconnect USB cable. 2. Wait for 1-2 minutes. 3. Connect phone via UART cable to the Box. 4. Note: phone screen must be active Connecting to phone, please wait... IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu. Performed by 2.2.3 software version i have change imei succse but not done |
04-24-2016, 19:48 | #4 (permalink) | ||
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
With Modem damaged you can repair phone, so try flashing other Fws if cannot repair most time can be Hw issue, (Modem Damaged). NOTE: another tools Not get Miracle, if you have "Sw:Unknown" (modem issue), Any Box in the world can repair you phone via Sw in this condition BR allumts Last edited by Octopus box; 04-25-2016 at 10:46. | ||
The Following User Says Thank You to allumts For This Useful Post: |
04-25-2016, 10:48 | #5 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. mr.allumts is correct. As You can see from Software log, phone's modem part is damaged: Quote:
You should re-flash the device with different firmwares one by one and check, whether modem is correct (not Unknown). And only then (when phone's modem part will be correct) perform and "Write Cert" operation. It is not possible to repair IMEI, if phone's modem part is damaged. If after writing of all firmwares, which You have, phone's baseband is still null or unknown (SW version is Unknown) - most likely, this is HW problem (problem with eMMC flash chip). Also, please use the latest Software version. | |
