Impossible to remove account google hi i try with octopus without success, i try to flash it with diferent firmware without sucess Welcome to Octoplus/Octopus Box Samsung software version 2.2.5 ----------------------------------------------------------------------------- To connect SM-J700F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected firmware file: J700FZTU1APA3_J700FZZT1APA3_J700FZTU1APA3_HOME.oct Please put the phone into Download Mode and connect USB cable. To put SM-J700F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing CM section... CM section has been written successfully. Writing Firmware Failed Performed by 2.2.5 software version Display : sw rev. check fail. device : 2; binary:1 oficial firmware for this phone is : Product code BRI PDA J700FZTU1APA3 CSC J700FZZT1APA3 |
Hello. Unfortunately currently no stable solution for FRP lock removal for SM-J700F with new firmwares. Problem with reset of FRP lock can occur if phone has latest firmware. Samsung disabled ability to remove FRP lock in latest firmwares. You can try to use solution suggested by mr.khudda1234 here: http://forum.gsmhosting.com/vbb/f684...46/index2.html Another solution was suggested by mr.calvinpower here: http://forum.gsmhosting.com/vbb/f684...oblem-2080233/ |
phone dont accept any firmware u can give m a good firmware to ret plz oficial firmware for this phone is : Product code BRI PDA J700FZTU1APA3 CSC J700FZZT1APA3 |
Currently we can't say with which firmware exactly You will be able to reflash the phone safely, to be able to remove lock. |
im asking for firmware compatible to flash it i dont need now remove LOCK |
You can use "J700FXXU2APC4_J700FOJV2APC3_XSG_Android_5.1.1 " firmware from the Support Area. |
all flash file from support is tested Any flash work Display : sw rev. check fail. device : 2; binary:1 Samsung Galaxy J7 (SM-J700F/DH) |
Please post here full Software log of writing of a "J700FXXU2APC4_J700FOJV2APC3_XSG_Android_5.1.1 " firmware. |
Welcome to Octoplus/Octopus Box Samsung software version 2.2.5 ----------------------------------------------------------------------------- To connect SM-J700F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected firmware file: J700FXXU1AOI1_J700FOJV1AOI1 _XSG_Android_5.1.1.oct Please put the phone into Download Mode and connect USB cable. To put SM-J700F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing CM section... CM section has been written successfully. Writing Firmware Failed Performed by 2.2.5 software version |
im still waiting answer or Currently we dont have solution, |
Try to write "J700FXXU2APD6_J700FOJV2APD1_TUR_Android_5.1.1 " firmware from the Support Area. This is the latest of available firmwares for SM-J700F. |
