10-19-2020, 11:47 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: EGYPT
Member: 601566 Status: Offline Sonork: 100.1637134 Thanks Meter: 551 | j200h imei repaire failed [Answered] Card S/N : 300098656 ----------------------------------------------------------------------------------- To connect SM-G7102 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-J200H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- WorkID: 0012481E Platform: Samsung Android Selected port: COM10 Selected model: SM-J200H Operation: Repair IMEI A Please, press "OK" button on the phone to allow USB debugging. Detected phone model: SM-J200H Firmware compiled date: Tue Feb 2 15:37:23 KST 2016 PDA version: J200HXXU0APB1 CSC version: J200HOJV0APB2 SW version: J200HXXU0APB1 Build number: Android version: 5.1.1 (LMY48B) Sales code: XSG Country: UAE HW platform: sc8830 HW Chip: SC7730SE HW Modem: SC7730SE Security patch level: 2016-02-01 SIM 1 status: absent SIM 2 status: absent Codename: j23gdd Checking Root: Phone is Rooted. Detecting security type...failed Write IMEI failed Performed by 3.0.0.1 Software version. |
10-19-2020, 16:40 | #3 (permalink) |
Member: 601566 Status: Offline Sonork: 100.1637134 Thanks Meter: 551 | Welcome to Octoplus Box Samsung software version 3.0.0.1 Card S/N : 300098656 ----------------------------------------------------------------------------------- To connect SM-G7102 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-J200H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- WorkID: 0012A19C Platform: Samsung Android Selected port: COM10 Selected model: SM-J200H Operation: Repair IMEI A Proper android device not found. Make sure that "USB debug" option on the device is turned on. Write IMEI failed Performed by 3.0.0.1 Software version. ----------------------------------------------------------------------------------- To connect SM-J200H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- WorkID: 0012A1CC Platform: Samsung Android Selected port: COM10 Selected model: SM-J200H Operation: Repair IMEI A Please, press "OK" button on the phone to allow USB debugging. Proper android device not found. Make sure that "USB debug" option on the device is turned on. Write IMEI failed Performed by 3.0.0.1 Software version. ----------------------------------------------------------------------------------- To connect SM-J200H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- WorkID: 0012A1E2 Platform: Samsung Android Selected port: COM10 Selected model: SM-J200H Operation: Repair IMEI A Detected phone model: SM-J200H Firmware compiled date: Mon Sep 14 19:41:05 KST 2015 PDA version: J200HXXU0AOIB CSC version: J200HOJV0AOIB SW version: J200HXXU0AOI9 Build number: Android version: 5.1.1 (LMY48B) Sales code: XSG Country: UAE HW platform: sc8830 HW Chip: SC7730SE HW Modem: SC7730SE SIM 1 status: absent SIM 2 status: absent Codename: j23gdd Checking Root: Phone is Rooted. Detecting security type...failed Write IMEI failed Performed by 3.0.0.1 Software version. |
10-19-2020, 19:48 | #4 (permalink) |
Member: 601566 Status: Offline Sonork: 100.1637134 Thanks Meter: 551 | Welcome to Octoplus Box Samsung software version 3.0.0.1 Card S/N : 300098656 ----------------------------------------------------------------------------------- To connect SM-J200H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- WorkID: 0012DFEB Platform: Samsung Android Selected port: COM10 Selected model: SM-J200H Operation: Repair IMEI A Please, press "OK" button on the phone to allow USB debugging. Detected phone model: SM-J200H Firmware compiled date: Mon Nov 13 22:32:54 KST 2017 PDA version: J200HXXU0AQK2 CSC version: J200HOJV0AQK1 SW version: J200HXXU0AQK1 Build number: Android version: 5.1.1 (LMY48B) Sales code: XSG Country: UAE HW platform: sc8830 HW Chip: SC7730SE HW Modem: SC7730SE Security patch level: 2017-08-01 SIM 1 status: absent SIM 2 status: absent Codename: j23gdd Checking Root: Phone is Rooted. Detecting security type...failed Write IMEI failed Performed by 3.0.0.1 Software version. |
10-20-2020, 16:10 | #6 (permalink) |
Member: 601566 Status: Offline Sonork: 100.1637134 Thanks Meter: 551 | this is 4 firmware Welcome to Octoplus Box Samsung software version 3.0.0.3 Card S/N : 300098656 ----------------------------------------------------------------------------------- To connect SM-J200H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- WorkID: 0013CD88 Platform: Samsung Android Selected port: COM10 Selected model: SM-J200H Operation: Repair IMEI A Please, press "OK" button on the phone to allow USB debugging. Proper android device not found. Make sure that "USB debug" option on the device is turned on. Write IMEI failed Performed by 3.0.0.3 Software version. ----------------------------------------------------------------------------------- WorkID: 0013CD9E Platform: Samsung Android Selected port: COM10 Selected model: SM-J200H Operation: Repair IMEI A Please, press "OK" button on the phone to allow USB debugging. Proper android device not found. Make sure that "USB debug" option on the device is turned on. Write IMEI failed Performed by 3.0.0.3 Software version. ----------------------------------------------------------------------------------- WorkID: 0013CDAD Platform: Samsung Android Selected port: COM10 Selected model: SM-J200H Operation: Repair IMEI A Please, press "OK" button on the phone to allow USB debugging. Proper android device not found. Make sure that "USB debug" option on the device is turned on. Write IMEI failed Performed by 3.0.0.3 Software version. ----------------------------------------------------------------------------------- WorkID: 0013CDBA Platform: Samsung Android Selected port: COM10 Selected model: SM-J200H Operation: Repair IMEI A Detected phone model: SM-J200H Firmware compiled date: Wed Sep 5 16:13:50 KST 2018 PDA version: J200HXXS0ARI1 CSC version: J200HOJV0ARE1 SW version: J200HXXU0ARE1 Build number: Android version: 5.1.1 (LMY48B) Sales code: XSG Country: UAE HW platform: sc8830 HW Chip: SC7730SE HW Modem: SC7730SE Security patch level: 2017-08-01 SIM 1 status: absent SIM 2 status: absent Codename: j23gdd Checking Root: Phone is Rooted. Detecting security type...failed Write IMEI failed Performed by 3.0.0.3 Software version. |
