04-26-2016, 00:25 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Cuba
Member: 346150 Status: Offline Sonork: 100.1661091 Thanks Meter: 429 | Loop N910P after Reset FRP Plataforma: Samsung Android Puerto seleccionado: COM9 Modelo seleccionado: SM-N910T To put SM-N910T into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock..success Resetting EE lock..success Resetting Samsung Account lock..not supported Reset operation completed! Performed by 2.2.4 software version Afeter loop many times, will falsh 3 times the phone and alwis loop the phone. The version firmware is N910PVPS4COK1_N910PSPT4COK1_5.1.1 |
04-26-2016, 10:46 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Try to root the phone, then check whether it powers on correctly. If problem will remain - try to make Factory Reset and Wipe cache partition from Recovery Mode. Reflash the phone with different firmware, if will be needed. |
04-26-2016, 11:50 | #5 (permalink) |
Member: 346150 Status: Offline Sonork: 100.1661091 Thanks Meter: 429 | I have already flashed with different versions, before and after to flash will make the wipe N910PVPS4COK1 5.1.1 N910PVPU4COJ6 5.1.1 N910PVPU4COG5 5.1.1 TWRP openrecovery-twrp-2.8.1.1-trltespr.img.tar is tested and work 1000% |
04-26-2016, 15:01 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to do exactly the next: 1. Reflash the phone with "N910PVPU4COJ6_N910PSPT4COJ6_SPR_Android_5.1.1 " firmware from the Support Area. 2. Root the phone. Check whether phone powers on correctly. Post here the result. |
04-26-2016, 17:49 | #10 (permalink) | |
Member: 346150 Status: Offline Sonork: 100.1661091 Thanks Meter: 429 | Quote:
----------------------------------------------------------------------------------- To connect SM-N910P phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. Seleccione el archivo de firmware: Please put the phone into Download Mode and connect USB cable. To put SM-N910P into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Escribiendo la sección ABOOT... L a sección ABOOT ha sido escrita con éxito Escribiendo la sección SBL1... L a sección SBL1 ha sido escrita con éxito Escribiendo la sección RPM... L a sección RPM ha sido escrita con éxito Escribiendo la sección TZ... L a sección TZ ha sido escrita con éxito Escribiendo la sección DBI... L a sección DBI ha sido escrita con éxito Escribiendo la sección APNHLOS... L a sección APNHLOS ha sido escrita con éxito Escribiendo la sección BOOT... L a sección BOOT ha sido escrita con éxito Escribiendo la sección RECOVERY... L a sección RECOVERY ha sido escrita con éxito Escribiendo la sección SYSTEM... L a sección SYSTEM ha sido escrita con éxito Escribiendo la sección CACHE... L a sección CACHE ha sido escrita con éxito Escribiendo la sección MODEM... L a sección MODEM ha sido escrita con éxito La escritura del firmware ha sido completada con éxito Performed by 2.2.1 software version The same error in Recovery Mode dm-verity verification failed... | |
